VTirca
- Mesaje scrise: 29
- Masina: Corsa 2012 A12xer
- Cont inregistrat: 26 Apr 2019
MODEL: Corsa 2012
MOTOR: A12xer
TDevice
- Mesaje scrise: 9
- Cont inregistrat: 14 Aug 2020
Termostatul cred ca deschide mai tarziu in jur de 107 grade,iar ventilatorul cred ca pleaca pe la 108-110grade. Cel putin la mine asa este si asa m-am speriat si eu la inceput. Important est sa pui lichid de racire roz care cred ca va avea punctul de fierbere in circuit pe la 120 grade.
- bezart
- 187 mesaje
- din 05 Nov 2012
- Corsa 2012 12 XER
bezart
- Mesaje scrise: 187
- Masina: Corsa 2012 12 XER
- Cont inregistrat: 05 Nov 2012
- bezart
- 187 mesaje
- din 05 Nov 2012
- Corsa 2012 12 XER
bezart
- Mihai.P
- 339 mesaje
- din 05 Feb 2015
- Astra 2005 Z17DTH
Mihai.P
- Mesaje scrise: 339
- Masina: Astra 2005 Z17DTH
- Cont inregistrat: 05 Feb 2015
- bezart
- 187 mesaje
- din 05 Nov 2012
- Corsa 2012 12 XER
bezart
Pure Water: 0 C / 32 F - 100 C / 212 F
50/50 mix of C2H6O2/Water: -37 C / -35 F - 106 C / 223 F
70/30 mix of C2H6O2/Water: -55 C / -67 F - 113 C / 235 F
The temperature of the coolant can sometimes reach 250 to 275 F (121 to 135 C). Even with ethylene glycol added, these temperatures would boil the coolant, so something additional must be done to raise its boiling point.
The cooling system uses pressure to further raise the boiling point of the coolant. Just as the boiling temperature of water is higher in a pressure cooker, the boiling temperature of coolant is higher if you pressurize the system. Most cars have a pressure limit of 14 to 15 pounds per square inch (psi), which raises the boiling point another 45 F (25 C) so the coolant can withstand the high temperatures.
Doar antigelul nu e suficient..adauga doar 6 grade. Este nevoie de presurizarea sistemului.
- Mihai.P
- 339 mesaje
- din 05 Feb 2015
- Astra 2005 Z17DTH
Mihai.P
- pantalon
- 652 mesaje
- din 05 Apr 2015
- Corsa
pantalon
- Mesaje scrise: 652
- Masina: Corsa
- Cont inregistrat: 05 Apr 2015
- bezart
- 187 mesaje
- din 05 Nov 2012
- Corsa 2012 12 XER
bezart
- pantalon
- 652 mesaje
- din 05 Apr 2015
- Corsa
pantalon
- Masina: Corsa
VTirca
- Mesaje scrise: 29
- pantalon
- 652 mesaje
- din 05 Apr 2015
- Corsa
pantalon
- Masina: Corsa
VTirca
- Mesaje scrise: 29
- pantalon
- 652 mesaje
- din 05 Apr 2015
- Corsa
pantalon
- Masina: Corsa
- taxi43edy
- 1,185 mesaje
- din 23 Apr 2009
- Zafira 2001 Z18XE
taxi43edy
- Mesaje scrise: 1,185
- Masina: Zafira 2001 Z18XE
- Cont inregistrat: 23 Apr 2009
VTirca
- Mesaje scrise: 29
- pantalon
- 652 mesaje
- din 05 Apr 2015
- Corsa
pantalon
- Masina: Corsa
- bezart
- 187 mesaje
- din 05 Nov 2012
- Corsa 2012 12 XER
bezart
- pantalon
- 652 mesaje
- din 05 Apr 2015
- Corsa
pantalon
- Masina: Corsa
- bezart
- 187 mesaje
- din 05 Nov 2012
- Corsa 2012 12 XER
bezart
Asta e configuratorul lui Wolf..e un G12+..nimic special...de aia este presurizarea
