BogdanBOG
- Mesaje scrise: 13
- Masina: Astra 2001 Z16XE
- Cont inregistrat: 30 Mai 2011
am gasit pe forum ce inseamna dar nu stiu ce le-a provocat.bobina de inductie am schimbat-o acum vreo 6 luni cand imi dadea eroare pe cil 3.atunci a fost rezolvata problema.erorile p0351,p0352,p0353,p0354 din ce cauza le am?am scos mufa de la bobina si i-am dat o cheie fara sa-mi dau seama k nu e pusa.oare asta sa fie?chiar toata bobina nu poate sa fie "trantita" pt ca imi dadea eroare si pe celelalte pistoane,nu?masina functioneaza. ce e drept merge in 3 dar inca functioneaza.ecu iese din discutie ca a fost schimbat. daca a mai patit cineva va rog ajutati-ma.multumesc
- mihaixxx89
- 40 mesaje
- din 05 Mar 2012
- Astra 2001 Y17DT
- Dolj
mihaixxx89
- Mesaje scrise: 40
- Masina: Astra 2001 Y17DT
- Cont inregistrat: 05 Mar 2012
- mihaixxx89
- 40 mesaje
- din 05 Mar 2012
- Astra 2001 Y17DT
- Dolj
mihaixxx89
- Mesaje scrise: 40
P0351 Ignition Coil A Primary/Secondary Circuit Malfunction
OBD-II Trouble Code Technical Description
Article by
Dale Toalston
ASE Certified Technician
What does that mean?
The COP (coil on plug) ignition system is what is used on most modern engines. There is an individual coil for each cylinder that is controlled by the PCM (powertrain control module). It eliminates the need for spark plug wires by putting the coil right above the sparkplug. Two wires are dedicated to each coil. One is a battery feed usually from the power distribution center. The other wire is the coil driver circuit from the PCM. The PCM grounds/ungrounds this circuit to activate or deactivate the coil. The coil driver circuit is monitored by the PCM for faults
If an open or a short is detected in the driver circuit for coil number 1, a P0351 may set. Also, depending on the vehicle, the PCM may also shut down the fuel injector to the cylinder also.
Symptoms
Symptoms of a P0351 DTC may include:
MIL (Malfunction indicator lamp) illumination
Engine misfire may be present or intermittent
Causes
Potential causes of a P0351 code include:
Short to voltage or ground on COP driver circuit
Open on COP driver circuit
Loose connection at coil or broken connector locks
Bad Coil (COP) = bobina proasta
Faulty Powertrain Control Module
- nicoyulius
- 101 mesaje
- din 27 Jan 2011
- Neamt
nicoyulius
- Mesaje scrise: 101
- Cont inregistrat: 27 Jan 2011
- dancuciureanu
- Moderator
- 16,465 mesaje
- Agila 2001 Z10XE + Z12XE
dancuciureanu
- Mesaje scrise: 16,465
BogdanBOG
- Mesaje scrise: 13
BogdanBOG
- Mesaje scrise: 13
- AIin
- 547 mesaje
- din 04 Mar 2012
- Astra 2003 z16se
- Dolj
AIin
- Mesaje scrise: 547
- Masina: Astra 2003 z16se
- Cont inregistrat: 04 Mar 2012
BogdanBOG
- Mesaje scrise: 13
- dancuciureanu
- Moderator
- 16,465 mesaje
dancuciureanu
- Mario pinzariu
- 33 mesaje
- din 27 Nov 2009
- Zafira 2001 z16xe
- Botosani
Mario pinzariu
- Mesaje scrise: 33
- Masina: Zafira 2001 z16xe
- Cont inregistrat: 27 Nov 2009
- nicunicu
- 2,593 mesaje
- din 25 Feb 2012
- Zafira 2002 z16xe
nicunicu
- Mesaje scrise: 2,593
- Masina: Zafira 2002 z16xe
BogdanBOG
- Mesaje scrise: 13
P1405 DPFE Sensor Upstream Hose Off Or Plugged
ai aici coduri de eroare https://www.clubopel.com/lin...i-de-eroare-opel/
big_electro61- Suspendat
- 4,492 mesaje
- din 24 Oct 2008
- Astra 2008 Z13DTH
big_electro61- Mesaje scrise: 4,492
- Masina: Astra 2008 Z13DTH
- Mario pinzariu
- 33 mesaje
- din 27 Nov 2009
- Zafira 2001 z16xe
- Botosani
Mario pinzariu
- Mesaje scrise: 33
ai aici coduri de eroare https://www.clubopel.com/lin...p?url=http://www.***/ghid-tehnic/coduri-de-eroare-opel/
- luciraica
- 2,001 mesaje
- din 29 Oct 2011
luciraica
- Mesaje scrise: 2,001
MVPAndrey
- Mesaje scrise: 16
- Cont inregistrat: 30 Apr 2012
- dancuciureanu
- Moderator
- 16,465 mesaje
dancuciureanu
- jE
- 8,413 mesaje
- din 04 Jun 2006
jE
- Mesaje scrise: 8,413
daca nu crezi, cauta pe goagle
p1405 z16xe
BogdanBOG
- Mesaje scrise: 13
