- misublu89
- 302 mesaje
- din 01 Mar 2011
- Astra 2004 Z16XEP
misublu89
- Mesaje scrise: 302
- Masina: Astra 2004 Z16XEP
- Cont inregistrat: 01 Mar 2011
si de ieri a inceput sa'mi palpaie martorul cu cheita si codul P1116-06 ''tensiune mica pe circuit ventilator termostat lichid de racire '' are cineva idee care ar putea fi problema? ce ar trebui sa schimb?
va multumesc anticipat !
- cangri
- 5,294 mesaje
- din 24 Sep 2010
cangri
- Mesaje scrise: 5,294
OBD-II Trouble Code Technical Description
Fuel Pump Primary (Control) Circuit Malfunction
What does that mean?
The fuel pump is activated by a PCM-controlled relay. Just as the name implies, a "relay" permits the transmittal of higher amperage current to the fuel pump without that current having to travel through the PCM (Powertrain Control Module). For obvious reasons it's better to not have higher amperage current anywhere near the PCM. Higher amperage current creates more heat but also in the event of a failure, can cause a PCM failure. This principal applies to any relay. The higher amperages are kept under the hood, away from sensitive areas
The relay contains basically two sides. The "control" side which is basically a coil and the "switch" side which is a set of electrical contacts. The control side (or coil side) is the low amp side. It's fed a switched ignition feed (12 volts with key on)and a ground. The ground circuit is activated by the PCM driver when appropriate. When the PCM fuel pump driver activates the relay coil, the coil acts as an electromagnet that pulls the electrical contacts closed which completes the fuel pump circuit. This closed switch allows voltage to flow on the fuel pump activation circuit, activating the pump. Whenever the key is turned on, the PCM grounds the fuel pump circuit for a few seconds, activating the fuel pump and pressurizing the system. The fuel pump won't be activated again until the PCM sees an RPM signal.
The driver in the PCM is monitored for faults. When activated the driver or ground circuit voltage should be low. When deactivated the driver/ground potential voltage should be high or near battery voltage. If the PCM sees a voltage other than what is expected, P0230 may be set.
Symptoms
Symptoms of a P0230 DTC may include:
MIL (malfunction indicator lamp) illumination
No start condition
No fuel pump operation
Fuel pump runs all the time with ignition on
Causes
Potential causes of a P0230 code include:
Short to ground on control circuit
Fuel pump control circuit open
Short to battery voltage on control circuit
Harness chafing causing one of above conditions
Bad relay
Bad PCM
Possible Solutions
Command the fuel pump on and off by using a scan tool or simply turning the ignition key on and off without starting the engine. If the fuel pump activates and deactivates, then start the vehicle and measure the current on the control (ground) circuit for a couple of minutes. It should be less than an amp and stay less than an amp.
If it doesn't then replacing the relay is a good idea at this point. If the fuel pump won't activate and deactivate, then remove the relay and visually check for discoloration due to heat or loose terminals. If okay, install a test light between the control circuit ignition feed and ground driver terminals (If you're not sure, don't attempt).
The test light should illuminate when the key is on or the fuel pump is commanded on. If it doesn't, then make sure there is voltage on one side of the coil (switched ignition feed). If voltage is present repair the open or short on the control ground circuit.
P1106 - GM Type Powertrain - Manufacturer Controlled DTC - Manufacturer Controlled
Description
MAP Sensor Circuit Intermittent High Input Conditions
Cause
No TP sensor codes set, engine running for a length of time that is determined by startup coolant temperature (the length of time ranges from 3 minutes at less than -22°F to less than a second at more than 86°F), throttle angle less than 89% with engine speed less than 1000 rpm or throttle angle less than 97% with engine speed more than 1000 rpm, then the PCM detected that the MAP input indicated over 4.9v condition present for less than 1 second
- misublu89
- 302 mesaje
- din 01 Mar 2011
- Astra 2004 Z16XEP
misublu89
suspended-9452- Suspendat
- 2,412 mesaje
- din 04 Sep 2007
- Astra 2016 B14XER
suspended-9452- Mesaje scrise: 2,412
- Masina: Astra 2016 B14XER
- misublu89
- 302 mesaje
- din 01 Mar 2011
- Astra 2004 Z16XEP
misublu89
kenji2011
- Mesaje scrise: 18
- Cont inregistrat: 06 Mar 2011
- 2,412 mesaje
- din 04 Sep 2007
- Astra 2016 B14XER
kenji2011
- Mesaje scrise: 18
adiv80
- Mesaje scrise: 8
- Cont inregistrat: 16 Feb 2008
- iulian1971
- 7,028 mesaje
- din 21 Dec 2006
- Ilfov
iulian1971
- Mesaje scrise: 7,028
adiv80
- Mesaje scrise: 8
- cmihai
- 345 mesaje
- din 19 Sep 2011
- Zafira 2014 A20DTH
- Braila
cmihai
- Mesaje scrise: 345
- Masina: Zafira 2014 A20DTH
- Cont inregistrat: 19 Sep 2011
- iulian1971
- 7,028 mesaje
- din 21 Dec 2006
- Ilfov
iulian1971
- cmihai
- 345 mesaje
- din 19 Sep 2011
- Braila
cmihai
- iulian1971
- 7,028 mesaje
- din 21 Dec 2006
- Ilfov
iulian1971
- cmihai
- 345 mesaje
- din 19 Sep 2011
- Braila
cmihai
- rhydin
- 1,367 mesaje
- din 09 Dec 2013
- Astra 2005 Z16XEP
- Hunedoara
rhydin
- Mesaje scrise: 1,367
- Masina: Astra 2005 Z16XEP
- Cont inregistrat: 09 Dec 2013
- rider1
- 725 mesaje
- din 28 Mar 2012
- Astra 2005 z14xe
rider1
- Mesaje scrise: 725
- Masina: Astra 2005 z14xe
