- Ionutzradu44
- 18 mesaje
- din 15 Oct 2013
- Vectra 1999 X20DTH
- Dolj
Ionutzradu44
- Mesaje scrise: 18
- Masina: Vectra 1999 X20DTH
- Cont inregistrat: 15 Oct 2013
- mikyboy
- 5,734 mesaje
- din 08 Dec 2006
- Insignia 2014 A20TDH
mikyboy
- Mesaje scrise: 5,734
- Ionutzradu44
- 18 mesaje
- din 15 Oct 2013
- Dolj
Ionutzradu44
- Mesaje scrise: 18
B.O.R
- Mesaje scrise: 87
- Masina: Vectra 1997 x20DTL
- Cont inregistrat: 09 Nov 2008
- Ionutzradu44
- 18 mesaje
- din 15 Oct 2013
- Dolj
Ionutzradu44
- Mesaje scrise: 18
- Ionutzradu44
- 18 mesaje
- din 15 Oct 2013
- Dolj
Ionutzradu44
- Mesaje scrise: 18
- cmarius53
- 454 mesaje
- din 28 Nov 2008
- Astra 2000 y20dth
- Ilfov
cmarius53
- Mesaje scrise: 454
- Masina: Astra 2000 y20dth
- Cont inregistrat: 28 Nov 2008
- Ionutzradu44
- 18 mesaje
- din 15 Oct 2013
- Dolj
Ionutzradu44
- Mesaje scrise: 18
- Ionutzradu44
- 18 mesaje
- din 15 Oct 2013
- Dolj
Ionutzradu44
- Mesaje scrise: 18
- alex_paval
- 619 mesaje
- din 22 Aug 2009
- Signum 2005 Z19DTH
- Bacau
alex_paval
- Mesaje scrise: 619
- Masina: Signum 2005 Z19DTH
- Cont inregistrat: 22 Aug 2009
- Ionutzradu44
- 18 mesaje
- din 15 Oct 2013
- Dolj
Ionutzradu44
- Mesaje scrise: 18
- mikyboy
- 5,734 mesaje
- din 08 Dec 2006
mikyboy
- Ionutzradu44
- 18 mesaje
- din 15 Oct 2013
- Dolj
Ionutzradu44
- Mesaje scrise: 18
System Voltage,14.16 V
Immobiliser,Active Immobiliser Signal,Received
Accelerator Position Sensor Signal,0.0 %
Idle Switch,Active
Mass Air Flow Sensor,597.1 mg/strk
Barometer Sensor,1.01 bar
Boost Pressure Command,1.85 bar
Boost Pressure,1.01 bar
Intake Air Temperature,22 °C
Coolant Temperature,30 °C
Engine Oil Temperature,24 °C
Fuel Temperature,26 °C
Brake Switch 1,Inactive
Brake Switch 2,Inactive 12V
Clutch Switch,Inactive
A/C Information Switch (Air Conditioning),Inactive 0V
Fuel Cutoff Valve,Active
Start of Delivery,20.61 °CA
Desired Injection Start,2.72 °CA
Actual Injection Start,2.69 °CA
Desired Injection Quantity,7.45 mg/strk
Injection Quantity,8.51 mg/strk
Pulse Ratio Boost Pressure Solenoid Valve,65.0 %
EGR Command (Exhaust-Gas Recirculation Command),358 mg/strk
EGR Pulse Ratio (Exhaust Gas Recirculation),1 %
Desired Engine Idle Speed,840 RPM
Engine Speed,840 RPM
Pump Speed,419 RPM
Diagnosis Glow Time Relay,Inactive
Glow Time Relay,Inactive 12V
A/C Relay (Air Conditioning),Inactive 12V
Key (I) (Set/Accelerate),Inactive
Key (R) (Set/Decelerate),Inactive
Key (O) (Switch Off),Inactive
Vehicle Speed Command,0 km/h
Vehicle Speed,0 km/h
Telltale (Check Light),Off 12V
Glow Time Telltale,Off 12V
High Pressure Diagnosis 1,0 Counts
High Pressure Diagnosis 2,0 Counts
- Ionutzradu44
- 18 mesaje
- din 15 Oct 2013
- Dolj
Ionutzradu44
- Mesaje scrise: 18
- Ionutzradu44
- 18 mesaje
- din 15 Oct 2013
- Dolj
Ionutzradu44
- Mesaje scrise: 18
- iulian1971
- 7,047 mesaje
- din 21 Dec 2006
- Ilfov
iulian1971
- Mesaje scrise: 7,047
- Ionutzradu44
- 18 mesaje
- din 15 Oct 2013
- Dolj
Ionutzradu44
- Mesaje scrise: 18
- Ionutzradu44
- 18 mesaje
- din 15 Oct 2013
- Dolj
Ionutzradu44
- Mesaje scrise: 18
