- dragos_costy87
- 73 mesaje
- din 15 Nov 2006
- Astra 2001 Y 17 DT
dragos_costy87
- Mesaje scrise: 73
- Masina: Astra 2001 Y 17 DT
- Cont inregistrat: 15 Nov 2006
Pyroman
- Mesaje scrise: 67
- Masina: Astra 2003 1.6 16V, 74 kw 101 CP,Z 16 XE
- Cont inregistrat: 19 Jul 2006
- Drogas
- 1,258 mesaje
- din 11 Sep 2006
Drogas
- Mesaje scrise: 1,258
- xcuseme
- 1,444 mesaje
- din 26 Aug 2006
- Astra 2002 Isuzu Y17DT 16v 55kW
xcuseme
- Mesaje scrise: 1,444
- Masina: Astra 2002 Isuzu Y17DT 16v 55kW
- Cont inregistrat: 26 Aug 2006
Intra mai usor ca inainte, dar cand e rece afara tot mai agata din cand in cand. Problema asta este data si in TIS, cu tot cu remediu... se schimba niste piese pe acolo... dar nu m-am interesat ce anume.
Sunt momente in care aproape ca trebuie sa opresc ca sa intre 1-a... si alte dati intra extrem de usor chiar si la 10-15km/h.
Atasez si ce zic baietii din TIS:
Field Remedy: 1653
Subject: F23 transmission - Bad cold shifting behaviour in 1st and 2nd gear
Models: Engines: Option:
Astra-G 1998...2004,Zafira 1999...2004,Speedster 2001...2004,VX220 2001...2004,Vectra-B 1998...2004,Vectra-C 2002...2004,Signum 2003...2004 All,All,All,All,All,All,All F23 Transmission
Complaint: Some customer complain about bad cold shifting behaviour in 1st and 2nd gear. The gearshift mechanism is correctly adjusted and clutch system is bleeded.
Cause: Tolerances of toothing of the sliding gear.
Production: Introduction of transmission with modified siding gear as of transmission number Gxx03240969 in calendar week 41 / 2003.
Remedy:
In case of customer complaint the sliding gear has to be replaced by
using the Repair Kit, Partno.: 9201451 / Catalogno.: 16 07 013. There
is no need to replace the entire transmission.
FunctionalGroup: K - Clutch/Transmission
Complaint Group: 08 - Hard to operate
Trouble Code: None
si de asemenea pentru cutiile F17
Subject: F17 Transmission - Insufficient 1-2 and 3-2 shifting behavior under cold conditions
Corsa-C 2001...2003,Astra-G 1998...2003,Zafira 1999...2003,Vectra-B 1996...2002 All,All,All,All F17 Transmission
Complaint: It might be possible that - even if the transmission is correctly adjusted- a stiff and/or inexact shift mechanism occurs especially at cold conditions. As the transmission oil becomes warmer the shifting behavior improves. This is definitely not a transmission damage, the durability of the transmission is not affected.
Cause: Problem might be caused by: - Sliding gears are out of tolerance. - Feathering at the synchronizers. - Oil stiffness.
Production: Modified sliding gears have been implemented in production since June 2002 with transmission number A10721F17.
Remedy:
In case of customer complaint install a modified sliding gear for gear
for 1st and 2nd gear. The mentioned part is available through P&A under
the following Partnumber: 13123502 / Catalognumber: 90 07 140.
For further parts please refer to EPC (if required).
Note:
Up to transmission number A09091F17 ----> the following parts must be
replaced together:
- Main shaft, 1st and 2nd transmission gear, synchronizer,
modified sliding gear.
As of transmission number A09191F17 ----> the following parts must be
replaced together:
- Modified sliding gear and synchronizer (only if required).
It is not necessary to replace the transmission end plate or the
transmission assy.
Trouble Code: No
Cred ca operatiunea in sine e destul de complicata si nu se merita intervenit.
Si inca o problema cu zgomote ciudate in viteza 1 si 2 la cutiile F23:
Field Remedy: 1398
Subject: Transmission - F23 rattling noises in 1. / 2. gear
Astra-G 1999...2002,Zafira 1999...2002,Vectra-B 1999...2002 Z22SE| Z20LET| Y20DTH| X20XER| X20DTL| X20XEV,Z22SE| Z20LET| Y20DTH| X20DTL,Z22SE| Y26SE| Y20DTH| X20DTL| X20DTH| X20XEV| X25XE| 16LZ2| C20SEL F23 Transmission
Complaint: Transmission rattling at low engine speed in 1st and 2nd gear.
Cause: The noises are produced by engine vibrations and tolerances of the Synchronizer Rings of 3rd and 4th gear. The noises do not influence the life of transmission.
Production: From MY 2002 on a new process with modified transmission tolerances is implemented in production.
Remedy:
Installation of a Repair-Kit.
Installation of well springs into the synchromesh body of the 3rd and 4th
gear.
Note:
Before installation of the Repair-Kit carry out Field Remedy 1267
"Tranmission - F23 Rattling Noise" to eleminate the noises.
If the noises cannot be eleminated by carrying out Field Remedy 1267
proceed after the following description.
Working Procedure:
1. Remove manual Transmission
- see working procedure "Transmission, Remove and Install (F 23)",
group "K", in the Service Instruction of the corresponding carline.
2. Remove Drive Shaft
- see working procedure "Illustration: Drive Shaft, Remove and Install
(F 23)", group "K", in the Service Instruction of the corresponding
carline.
Note:
The installation of the Repair-Kit is specified in the working procedure
"Drive Shaft, Disassemble and Reassemble (F 23)", group "K", of the
corresponding Service Instruction.
On this occasion the complete synchromesh body and all bearings will be
replaced.
Additional will be installed well springs between synchronizer rings and
the gear wheel.
3. Install Drive Shaft
carline.
4. Install manual Transmission
Spare-Parts: Part-No.: Catalog-No.:
Repair Kit 9 201 452 16 07 014
Complaint Group: 14 - Noises or Vibrations
Trouble Code: Non
- dragos_costy87
- 73 mesaje
- din 15 Nov 2006
dragos_costy87
- Mesaje scrise: 73
- 1.7dti_edition2000
- 533 mesaje
- din 28 Aug 2006
- Astra 2000 y17dt
1.7dti_edition2000
- Mesaje scrise: 533
- Masina: Astra 2000 y17dt
- Cont inregistrat: 28 Aug 2006
Practic se pune la pct mort,se ambreiaza si se accelereaza un pic (sau mai mult,depinde de situatie,ideea e de egalizare a turatiei arboriilor din cutie),apoi se debreiaza si se cupleaza a I-a.
- ice01astra
- 602 mesaje
- din 28 Jun 2006
- Astra 1995 C16NZ
- Hunedoara
ice01astra
- Mesaje scrise: 602
- Masina: Astra 1995 C16NZ
- Cont inregistrat: 28 Jun 2006
- dragos_costy87
- 73 mesaje
- din 15 Nov 2006
dragos_costy87
- Mesaje scrise: 73
- ice01astra
- 602 mesaje
- din 28 Jun 2006
- Astra 1995 C16NZ
- Hunedoara
ice01astra
- dragos_costy87
- 73 mesaje
- din 15 Nov 2006
dragos_costy87
- Mesaje scrise: 73
- ice01astra
- 602 mesaje
- din 28 Jun 2006
- Astra 1995 C16NZ
- Hunedoara
ice01astra
Stimate dragos_costy87,
Nu pot sa iti spun cat de bucuros sunt sa aflu faptul ca te-am putut ajuta ! Sper sa iti rezolvi problema cat mai curand posibil, iar ptr asta iti doresc mult succes !
Cu respect,
Mircea !
- Drogas
- 1,258 mesaje
- din 11 Sep 2006
Drogas
- claudiu-cld
- 6,510 mesaje
- din 13 Sep 2006
- Astra 2000 y17dt
claudiu-cld
- Mesaje scrise: 6,510
- Cont inregistrat: 13 Sep 2006
- Drogas
- 1,258 mesaje
- din 11 Sep 2006
Drogas
- Sezran
- 1,183 mesaje
- din 01 Jun 2004
Sezran
- Mesaje scrise: 1,183
- Cont inregistrat: 01 Jun 2004
- dragos_costy87
- 73 mesaje
- din 15 Nov 2006
dragos_costy87
- Mesaje scrise: 73
- Sezran
- 1,183 mesaje
- din 01 Jun 2004
Sezran
- catalin-g3
- 88 mesaje
- din 27 Feb 2006
- Ascona 1985
catalin-g3
- Mesaje scrise: 88
- Masina: Ascona 1985
- Cont inregistrat: 27 Feb 2006
- 533 mesaje
- din 28 Aug 2006
- Astra 2000 y17dt
1.7dti_edition2000
- dragos_costy87
- 73 mesaje
- din 15 Nov 2006
dragos_costy87
- Mesaje scrise: 73
