- mizileanudaniel
- 11 mesaje
- din 22 Jul 2012
- Vectra 2004 Z19DT
mizileanudaniel
- Mesaje scrise: 11
- Masina: Vectra 2004 Z19DT
- Cont inregistrat: 22 Jul 2012
- iulian1971
- 7,054 mesaje
- din 21 Dec 2006
- Ilfov
iulian1971
- Mesaje scrise: 7,054
- mizileanudaniel
- 11 mesaje
- din 22 Jul 2012
- Vectra 2004 Z19DT
mizileanudaniel
- Mesaje scrise: 11
- alex_paval
- 619 mesaje
- din 22 Aug 2009
- Signum 2005 Z19DTH
- Bacau
alex_paval
- Mesaje scrise: 619
- Masina: Signum 2005 Z19DTH
- Cont inregistrat: 22 Aug 2009
- mizileanudaniel
- 11 mesaje
- din 22 Jul 2012
- Vectra 2004 Z19DT
mizileanudaniel
- Mesaje scrise: 11
DB77AAA
OP-COM - CAN Communication Window> 2004|Vectra-C / Signum|Engine|Z 19 DT
Read Info...
Identifier: 0x0710
VIN: W0L0ZCF6848056779
Hardware number:81011448
Motor type: Z19DT
Part Number:55189629
Software version number: MJLMS100_S
Hardware manufacturer number: 0281011448
Software Number: 1037370816P319_O74
Programming Date: 20040402
Hardware key number: S000310542
System description: BOSCH0100
Type approval number: B04018
Variant programming: 0x00004588
Alpha code: LL
Hardware manufacturer system name: EDC16
ECU variant coding: 0x0000F801
Total number of fault codes: 2
P0340 - Range/Performance
(2😎 - Present(Arborele cu came Senzorul de poziþie Circuit Range /Performance)
P1483 - Fan Control 3 Circuit Open
(04) - Present(Fan Control 3 circuit deschis)
andi_cimpean- Suspendat
- 391 mesaje
- din 07 Aug 2007
- Astra 2002 Z14XE
- Calarasi
andi_cimpean- Mesaje scrise: 391
- Masina: Astra 2002 Z14XE
- Cont inregistrat: 07 Aug 2007
- alex_paval
- 619 mesaje
- din 22 Aug 2009
- Bacau
alex_paval
- mizileanudaniel
- 11 mesaje
- din 22 Jul 2012
- Vectra 2004 Z19DT
mizileanudaniel
- Mesaje scrise: 11
- iulian1971
- 7,054 mesaje
- din 21 Dec 2006
- Ilfov
iulian1971
- mizileanudaniel
- 11 mesaje
- din 22 Jul 2012
- Vectra 2004 Z19DT
mizileanudaniel
- Mesaje scrise: 11
- iulian1971
- 7,054 mesaje
- din 21 Dec 2006
- Ilfov
iulian1971
Schimba, de proba, senzorul de la axul cu came. Prima eroare e cauzata de acest senzor, vezi cum merge cu alt senzor si daca e cazul il schimbi definitiv.
Daca vrei sa rezolvi problema poti merge la colegul [editat], in Tatarani, langa Ploiesti, il gasesti aici pe forum.
Spor la treaba.
- mizileanudaniel
- 11 mesaje
- din 22 Jul 2012
- Vectra 2004 Z19DT
mizileanudaniel
- Mesaje scrise: 11
- mizileanudaniel
- 11 mesaje
- din 22 Jul 2012
- Vectra 2004 Z19DT
mizileanudaniel
- Mesaje scrise: 11
- mizileanudaniel
- 11 mesaje
- din 22 Jul 2012
- Vectra 2004 Z19DT
mizileanudaniel
- Mesaje scrise: 11
- eremiaiulian
- 92 mesaje
- din 12 Mai 2011
- Vectra 2004 y20dth
eremiaiulian
- Mesaje scrise: 92
- Masina: Vectra 2004 y20dth
- Cont inregistrat: 12 Mai 2011
Liv68
- Mesaje scrise: 10
- Masina: Vectra 2003 Y20DTH
- Cont inregistrat: 01 Nov 2006
Si eu cu acelasi cod de eroare - P1483.
Am fost si la Opel la Rm. Valcea, dar am plecat aproape la fel cum am venit (doar cu mai putini bani in buzunar).
Au turat masina indelung si au concluzionat ca treapta 3 ventilator racire functioneaza normal - asa ca mi-au dat un raspuns echivoc: "- E posibil sa fie o intrerupere de conductori electrici sau chiar sa dea computerul o falsa eroare !"
A reusit cineva dintre colegi sa remedieze aceasta eroare ?
- iulian1971
- 7,054 mesaje
- din 21 Dec 2006
- Ilfov
iulian1971
Daca au turat motorul ca sa vada daca functioneaza ventilatorul cred ca ai gresit service-ul.
Incearca s-ajungi la o diagnoza aici:
https://www.clubopel.com/viewtopic.php?t=95882
Liv68
- Mesaje scrise: 10
- gabiboldeanu
- 41 mesaje
- din 28 Mar 2011
- Astra 2000 X18XE1
gabiboldeanu
- Mesaje scrise: 41
- Masina: Astra 2000 X18XE1
- Cont inregistrat: 28 Mar 2011
- gabiboldeanu
- 41 mesaje
- din 28 Mar 2011
- Astra 2000 X18XE1
gabiboldeanu
- Mesaje scrise: 41
