- nedelculeon
- 32 mesaje
- din 17 Mar 2010
- Astra 2003 y20dth
- Ialomita
nedelculeon
- Mesaje scrise: 32
- Masina: Astra 2003 y20dth
- Cont inregistrat: 17 Mar 2010
Nu stiu daca valorile inregistrate se incadreaza in parametrii normali.Atasez rezultatele testului si astept pareri despre valorile inregistrate.
Measuring blocks information:
Battery Voltage 14.1 V
Ignition Status On 12V
APP at Idle Position (Accelerator Pedal Position) Inactive
APP Sensor 1 (Accelerator Pedal Position) 1.41 V
APP Sensor 2 (Accelerator Pedal Position) 0.70 V
Calculated Pedal Position 12%
Barometric Pressure 101 kPa
Barometric Pressure 4.13 V
Boost Pressure Command 125 kPa
Boost Pressure 102 kPa
Boost Pressure 1.64 V
Mass Air Flow Sensor 301 mg/strk
Mass Air Flow Sensor 2.58 V
Intake Air Temperature 35 °C
Intake Air Temperature 1.95 V
Coolant Temperature 80 °C
Coolant Temperature 1.20 V
Engine Oil Temperature 72 °C
Engine Oil Temperature 2.48 V
Fuel Temperature 43 °C
Brake Switch 1 Inactive
Brake Switch 2 Inactive 12V
Desired Engine Idle Speed 800 RPM
Engine Speed 1.812 RPM
Injection Pump Speed 905.44 RPM
Desired Injection Start 6.6 °CA
Actual Injection Start 6.9 °CA
Actual Injection Quantity 5.1 mg/strk
A/C Information Switch Inactive
A/C Relay (Air Conditioning) Active
A/C Load Signal (Air Conditioning) 19%
A/C Pressure (Air Conditioning) 538 kPa
EGR Valve (Exhaust-Gas Recirculation) Active
EGR Position Command (Exhaust- Gas Recirculation) 24%
EGR Pulse Ratio (Exhaust Gas Recirculation) 27%
EGR Feedback (Exhaust Gas Recirculation) Incorrect
Pulse Ratio Boost Pressure Solenoid Valve 54%
Swirl Level Control Solenoid Valve Pulse Ratio 4%
Pulse Ratio Throttle Control Solenoid Valve 5%
Outside Temperature Sensor_ 12 °C
Outside Temperature Sensor_ 2.34 V
Glow Time Relay Active 0V
Diagnosis Glow Time Relay Inactive
Glow Time Telltale Off
Malfunction Indicator (MI) Off
Service Vehicle Soon (SVS) Indicator ON
Vehicle Speed 0 km/h
Clutch Switch Inactive
Cruise Control Tip Switch Not Programmed
Vehicle Speed in Cruise Control Range Not Programmed
Immobiliser Function Programmed - - -
Security Wait Time - - -
- DB77AAA
- 6,641 mesaje
- din 19 Jan 2007
- Vectra 2005 Z19DTH 200CP
- Dambovita
DB77AAA
- Mesaje scrise: 6,641
- nedelculeon
- 32 mesaje
- din 17 Mar 2010
- Astra 2003 y20dth
- Ialomita
nedelculeon
- Mesaje scrise: 32
- DB77AAA
- 6,641 mesaje
- din 19 Jan 2007
- Dambovita
DB77AAA
- nedelculeon
- 32 mesaje
- din 17 Mar 2010
- Astra 2003 y20dth
- Ialomita
nedelculeon
- Mesaje scrise: 32
Am mai curatat egr, la mine nu e cazul de membrana, al meu fiind electronic, totusi am impresia ca nu mai ma duce mult, probabil inclina secera si ramane blocata.
In principiu valorile sunt bune?
- DB77AAA
- 6,641 mesaje
- din 19 Jan 2007
- Dambovita
DB77AAA
- nedelculeon
- 32 mesaje
- din 17 Mar 2010
- Astra 2003 y20dth
- Ialomita
nedelculeon
- Mesaje scrise: 32
- iriahu
- 261 mesaje
- din 31 Mai 2008
- Omega 1998 X25td
- J"em
iriahu
- Mesaje scrise: 261
- Masina: Omega 1998 X25td
- Cont inregistrat: 31 Mai 2008
De cate ori ai reparat pompa ? Cam multe intrebari nu asa ?
Intreb mai ales pentru masuratoarea :Actual Injection Quantity 5.1 mg/strk
Cred ca 5,1 este tare mult ! Ar trebui sa fie pe la 3
Ce consum instantaneu ai la relanti ?
Stie cineva sa interpreteze toate masuratorile din aceasta testare a lui Nedelcu?
Este pe undeva scris care ar trebuii sa fie masuratorile ideale prescrise de fabricant ?
Numai bine !
- raku21
- 520 mesaje
- din 30 Mar 2008
- Astra 2000 Y20DTH
raku21
- Mesaje scrise: 520
- Masina: Astra 2000 Y20DTH
- Cont inregistrat: 30 Mar 2008
- nedelculeon
- 32 mesaje
- din 17 Mar 2010
- Astra 2003 y20dth
- Ialomita
nedelculeon
- Mesaje scrise: 32
Numai bine !
Pompa nu am reparat-o niciodata de cand am masina(14luni), in momentul achizitiei masina avea in bord 166.ooo, nu cred ca sunt reali.
Asta vara(in concediu) am consumat in 125litri de motorina si am facut 2100 de km, mers si pe munte si pe autostrada.iese undeva la 6-6,5 litri, consum mixt.Nu pot sa iti zic cat consuma la relanti pt ca nu am BC.
Ce ai vazut tu, cantitatea de motorina injectata este la turatie de aproximativ 2000 de ture.
- iriahu
- 261 mesaje
- din 31 Mai 2008
- Omega 1998 X25td
- J"em
iriahu
Prietenul Nedelcu o are acum de 5 la 2000 t/min . Dar poate poti face inca o data masuratoarea la RELANTI adica la 800-850 t/min.
Si un alt coleg este de parerea ca trebuie sa fie un nr. intre 4-10 . OK ! dar intre aceste valori pot fi multe reglari care dau si un consum diferit.
Nu a gasit nimeni scris pe TIS 2000 care ar trebui sa fie acesta valuare ? Sau poate in Auto Data ?
Nedelcu daca nu ti-e greu masoara si la relanti acesta valoare stroke/gram
La masina mea a fost de 7,2 si am crezut ca am o conducta de motorina sparta ! Asa se termina de repede motorina din rezervor. Cam 70 de litri pentru 350Km. Am inceput sa caut pana cand un destept mi-a spus "hai sa-i modificam pozitia capului" si am adus-o cam la 3,4 iar situatia s-a schimbat in bine.
Cred ca fabrica da niste propuneri de reglaj pe care profesorii dela garaj inca nu le-au descoperit.
Asa ca efortul nostru comun va fi spre binele tuturora .
Numai bine la toti !
- nedelculeon
- 32 mesaje
- din 17 Mar 2010
- Astra 2003 y20dth
- Ialomita
nedelculeon
- Mesaje scrise: 32
Momentan nu mai pot masura nimic deoarece am trimis interfata op-com la reparat.Cand voi reintra in posesia ei voi face din nou masuratori si le voi posta.Numai bine tuturor.
- raku21
- 520 mesaje
- din 30 Mar 2008
- Astra 2000 Y20DTH
raku21
- iriahu
- 261 mesaje
- din 31 Mai 2008
- Omega 1998 X25td
- J"em
iriahu
Asa ca inca mai suntem in ceata !?
Prietenul Raku25 , ce ai luat din TIS ? nu am inteles. Daca poti descarca pagina din tis cu aceste reglaje RECOMANDATE !
M-ar interesa si pentru omega 2,5td cu motor bmw ( typ motor X25TD). Poate poti scrie unde ai gasit acestea scrise. La ce capitol ,ce sub capitol ?
Sa poata gasi si alti prieteni ! Nu este nici-o crima sa ne informam uni pe alti . Pentru asta este internet !
Numai bine tuturora !
- raku21
- 520 mesaje
- din 30 Mar 2008
- Astra 2000 Y20DTH
raku21
Ps sa nu uiti sa imi dai anul fab.
- nedelculeon
- 32 mesaje
- din 17 Mar 2010
- Astra 2003 y20dth
- Ialomita
nedelculeon
- Mesaje scrise: 32
Tin sa te contrazic despre viteza motorului, ce ai citit tu
Desired Engine Idle Speed 800 RPM - este turatia de relanti
Engine Speed 1.812 RPM - turatia la care am facut testul.
- raku21
- 520 mesaje
- din 30 Mar 2008
- Astra 2000 Y20DTH
raku21
- iriahu
- 261 mesaje
- din 31 Mai 2008
- Omega 1998 X25td
- J"em
iriahu
Nu cred ca este normal sa spuna testerul ce ar vrea de fapt (sau ar astepta sa vada ) in timpul masuratorilor.
El citeste ceiace ECU "simpte" si afiseaza . Daca te axsezi pe un anumit parametru iti poate da plaja de masura (range) . Dar daca plaja este destul de larga ( cum spunea prietenul mai sus pe post 4......10strok/gr) atunci
dai cu banul pentru ceiace cauti ? Cred ca ar trebuii sa gasim cumva valori recomandate si sa incercam sa ne reglam masinile cat mai aproape de aceste valor. Nu asa baieti ?
Rakule spuneai ca este ceva scris prin Tis ? ! Afiseaza baiatule ! Nu te lasa !
- raku21
- 520 mesaje
- din 30 Mar 2008
- Astra 2000 Y20DTH
raku21
- iriahu
- 261 mesaje
- din 31 Mai 2008
- Omega 1998 X25td
- J"em
iriahu
