- cronny
- 528 mesaje
- din 29 Apr 2006
- Corsa 2003 z12xe
cronny
- Mesaje scrise: 528
- Masina: Corsa 2003 z12xe
- Cont inregistrat: 29 Apr 2006
- dancuciureanu
- Moderator
- 16,465 mesaje
- din 26 Jun 2006
- Agila 2001 Z10XE + Z12XE
dancuciureanu
- Mesaje scrise: 16,465
- LEXXX
- 1,019 mesaje
- din 25 Jan 2005
- Astra 2004 Z18XE
LEXXX
- Mesaje scrise: 1,019
- Masina: Astra 2004 Z18XE
- Cont inregistrat: 25 Jan 2005
- dancuciureanu
- Moderator
- 16,465 mesaje
- din 26 Jun 2006
dancuciureanu
- bertone
- 2,289 mesaje
- din 13 Jun 2005
- buzau
bertone
- Mesaje scrise: 2,289
- Cont inregistrat: 13 Jun 2005
Vad ca cei cu Opeluri mai sportive ( Calibra , Beertone sau alte masini cu motoare maricele pe benzina ) tot pun Castrol RS in masina .
Asta are vascozitate de 10W60 .
Intrebare :
Pentru o masina exploatata la turatii mari n-ar trebyui mai degraba pus un 5W30 sau 5 W40 ( ca e mai subtire si lucreaza mai rapid ) decat un 10W60 ?
Plus ca 10W este semisintetic , nu full fata de celalalt . Si tot ca un plus in conditii de iarna la porniri la rece e mai bun cel cu 5W .
De ce Castrol RS costa mai mult de Castrol Softec ? E aniormal ca un ulei semi sa coste mai mult decat unul full .
Ma lamuriti si pe mine , va rog ! 😕
Am mai gasit o Calibra pe forum care merge cu 10W60...
- maiandrei
- 4,710 mesaje
- din 20 Dec 2004
- Insignia 2018 B20DTH
maiandrei
- Mesaje scrise: 4,710
The engine oil should be at operating temperature when performing an oil change (above 80 °C).
The engine oil should be completely drained from the engine.
For this reason, the draining (siphoning) should take as long as possible.
Oil consumption
All engines consume oil. We differentiate between:
- constructive oil consumption (points at which lubricated parts move within components and where leakage is unavoidable) and
- oil loss (as a result of leaking components and connections, which represent faults and lead to follow-up orders (sealing).
Top up engine oil
Engine oil can be refreshed by topping up the oil as required. Despite this however, the oil change intervals specified by the manufacturer must be observed. Oils from different manufacturers and of different types can be mixed. However, oil of an inferior grade should not be used.
Additional additives
The use of additional additives can lead to damage and cancellation of the warranty.
Opel therefore strongly advises you not to use additional engine oil additives.
extras din TIS
- razvu77
- 201 mesaje
- din 13 Nov 2005
- Astra 1995 C20XE
razvu77
- Mesaje scrise: 201
- Masina: Astra 1995 C20XE
- Cont inregistrat: 13 Nov 2005
funky
- Mesaje scrise: 10
- Masina: Vectra 1995 C18NZ
- Cont inregistrat: 04 Sep 2006
- @dyS
- 747 mesaje
- din 27 Jun 2005
- Astra 1995 C14NZ
- Valcea
@dyS
- Mesaje scrise: 747
- Masina: Astra 1995 C14NZ
- Cont inregistrat: 27 Jun 2005
nb21
- Mesaje scrise: 23
- Cont inregistrat: 23 Jun 2006
rraayy_11
- Mesaje scrise: 23
- Masina: Vectra 1993 1.8i
- Cont inregistrat: 24 Aug 2006
- cont-sters-1898
- 233 mesaje
- din 28 Feb 2006
cont-sters-1898
- Mesaje scrise: 233
- Cont inregistrat: 28 Feb 2006
rraayy_11
- Mesaje scrise: 23
- maiandrei
- 4,710 mesaje
- din 20 Dec 2004
maiandrei
- cont-sters-1898
- 233 mesaje
- din 28 Feb 2006
cont-sters-1898
- AIR_jhanes
- 106 mesaje
- din 13 Jul 2006
- Astra 2000 ey7
- Ploiesti
AIR_jhanes
- Mesaje scrise: 106
- Masina: Astra 2000 ey7
- Cont inregistrat: 13 Jul 2006
- adrian.preda
- 52 mesaje
- din 19 Nov 2006
- Corsa 2001 Z12XE
adrian.preda
- Mesaje scrise: 52
- Masina: Corsa 2001 Z12XE
- Cont inregistrat: 19 Nov 2006
Am vazut ca fostul propietar i-a bagat aral 5W40 si 10W40, dupa anotimp.
Eu am luat Valvoline Synpower 5W40. Acum are 87000km masina si merge bine.
Ieri pe la 4:30 am reusti sa ajung la service sa-i fac schimbul dar.... pe 30NOV e sf. Andrei care e patronul Galatiului - sarbatorile galatiului - si azi e 1dec - ziua romaniei - asa ca pana luni am pus uleiul in masina, dar nu in motor ci in portbagaj , asa ca sa se obisnuiasca cu Corsa.
Ce parere aveti despre Valvoline?
- 1.7dti_edition2000
- 533 mesaje
- din 28 Aug 2006
- Astra 2000 y17dt
1.7dti_edition2000
- Mesaje scrise: 533
- Masina: Astra 2000 y17dt
- Cont inregistrat: 28 Aug 2006
bar0n
- Mesaje scrise: 37
- Cont inregistrat: 13 Dec 2005
Intrebare :
Pentru o masina exploatata la turatii mari ar trebui tocmai ulei gros sa se puna, altfel se va consuma foarte repede. Te asigur ca Castrol Formula RS 10W-60 este ulei sintetic, nu semi. Costa mai mult decat softec pentru ca e mai bun. Softec are 5W-30, 5W-40 maxim, deci o plaja mica de temperaturi comparat cu 10W-60.
- alex_arhire
- 988 mesaje
- din 10 Sep 2006
- Astra 2001 Z20LET
alex_arhire
- Mesaje scrise: 988
- Masina: Astra 2001 Z20LET
- Cont inregistrat: 10 Sep 2006
