- cipickao
- 113 mesaje
- din 13 Feb 2011
- Zafira 2007 Z19DTL
cipickao
- Mesaje scrise: 113
- Masina: Zafira 2007 Z19DTL
- Cont inregistrat: 13 Feb 2011
Am si eu o problema la Opel Astra G,motor 1,8,z18xe.an fab 2001.La prima pornire a masinii porneste dar se opreste dupa 3-4 secunde.A doua oare cind ii dau la cheie porneste bine dar se opreste dupa 3-4 sec,la a treia cheie porneste merge intrerupt motorul cam 15 sec dupa care totul merge normal fara sa mai faca alte probleme.Daca mai pornesc masina pe parcursul zilei porneste perfect fara sa se opreasca.
Imi da doua erori 0460 si 1650.
Va rog ceva sfaturi in acesta problema.Multumesc anticipat.
- adware_man
- 1,724 mesaje
- din 01 Oct 2008
- Astra 2002 Y20DTH
adware_man
- Mesaje scrise: 1,724
- Masina: Astra 2002 Y20DTH
- Cont inregistrat: 01 Oct 2008
Salut!
P0460 - Fuel Level Sensor Circuit Malfunction The PCM monitors the fuel level input (FLI) circuit for electrical failure. The test fails when the signal moves outside the minimum or maximum allowable calibrated parameters for a specified fuel fill percentage in the fuel tank. Empty fuel tank
Fuel pump (FP) module stuck open
Incorrectly installed fuel gauge
Damaged instrument cluster
CASE GND circuit open
FLI shorted to VPWR
Damaged PCM
Overfilled fuel tank
Fuel pump (FP) module stuck closed
Damaged fuel gauge
FLI circuit open
FLI circuit shorted to CASE GND or PWR GND
CSE GND shorted to VPWR
Monitor FLI PID and FLI V PID in key ON engine RUNNING. FLI PID at 25% fill (with non matching fuel gauge) and FLI V PID less than 0.90 volts [for FLI PID at 75% fill (with non matching fuel gauge) and FLI V PID greater than 2.45 volts] indicates a hard fault.
P1650 - Driver 2-Input Hi Voltage.
Cred ca te-am lamurit ))
FLI shorted to VPWR
Damaged PCM
Damaged fuel gauge
FLI circuit open
- cipickao
- 113 mesaje
- din 13 Feb 2011
cipickao
- adware_man
- 1,724 mesaje
- din 01 Oct 2008
- Astra 2002 Y20DTH
adware_man
- cipickao
- 113 mesaje
- din 13 Feb 2011
cipickao
- adware_man
- 1,724 mesaje
- din 01 Oct 2008
- Astra 2002 Y20DTH
adware_man
- cipickao
- 113 mesaje
- din 13 Feb 2011
cipickao
Am gasit o traducere aproximativa in romana dar este destul de confuza..
P0460 - nivel de senzor circuitului de combustibil Defecþiune PCM monitorizeazã nivelul de intrare de combustibil (FLI) Circuit electric pentru eºec. The test fails when the signal moves outside the minimum or maximum allowable calibrated parameters for a specified fuel fill percentage in the fuel tank. Testul eºueazã atunci când se mutã de semnal în afara parametrilor minime sau maxime admise calibrat pentru un combustibil specificat completaþi procentuale în rezervorul de combustibil. Empty fuel tank Rezervor de combustibil goale
Fuel pump (FP) module stuck open Pompa de combustibil (FP) modul blocat deschis
Incorrectly installed fuel gauge Instalat incorect ecartament de combustibil
Damaged instrument cluster Distruse, instrumentelor de bord,
CASE GND circuit open CASE GND circuit deschis
FLI shorted to VPWR Scurtcircuitat la VPWR FLI
Damaged PCM Distruse, PCM
Overfilled fuel tank Supraîncãrcate cisternã pentru combustibil
Fuel pump (FP) module stuck closed Pompa de combustibil (FP) modul blocat închis
Damaged fuel gauge Distruse de combustibil gabaritul
FLI circuit open FLI circuit deschis
FLI circuit shorted to CASE GND or PWR GND FLI scurtcircuitat la GND CASE sau GND PWR de circuit
CSE GND shorted to VPWR CSE scurtcircuitat la GND VPWR
Monitor FLI PID and FLI V PID in key ON engine RUNNING. Monitor FLI PID ºi FLI V PID-cheie în ON de funcþionare a motorului. FLI PID at 25% fill (with non matching fuel gauge) and FLI V PID less than 0.90 volts [for FLI PID at 75% fill (with non matching fuel gauge) and FLI V PID greater than 2.45 volts] indicates a hard fault. FLI PID la 25% umple (cu ecartament de combustibil care nu sunt potrivite) ºi FLI V PID mai puþin de 0.90 volþi [pentru FLI BIP la umplere de 75% (cu ecartament de combustibil care nu sunt potrivite) ºi FLI PID V este mai mare 2.45 volþi] indicã o defecþiune greu.
- adware_man
- 1,724 mesaje
- din 01 Oct 2008
- Astra 2002 Y20DTH
adware_man
Adrian37
- Mesaje scrise: 10
- Cont inregistrat: 07 Nov 2011
cipickao a scris:Am si eu o problema la Opel Astra G,motor 1,8,z18xe.an fab 2001.La prima pornire a masinii porneste dar se opreste dupa 3-4 secunde.A doua oare cind ii dau la cheie porneste bine dar se opreste dupa 3-4 sec,la a treia cheie porneste merge intrerupt motorul cam 15 sec dupa care totul merge normal fara sa mai faca alte probleme.Daca mai pornesc masina pe parcursul zilei porneste perfect fara sa se opreasca.
P0460 înseamnã :
Senzorul de nivel de combustibil este montat în rezervorul de combustibil si indica nivelul. Senzorul detecteazã un nivel de combustibil în rezervorul de combustibil si transmite un semnal la ECM. Se compune din douã pãrþi, una este floatul mecanice ºi cealaltã parte este un rezistor variabil. Senzor de ieºire indica nivel modificand tensiunea în funcþie miscarile flotorului. Simptomele posibile sunt – indicatorul MIL aprins - nivel de combustibil funcþioneaza necorespunzãtor.
Cauze posibile - ansamblul sau conectori (circuitul senzorului este deschis sau scurtcircuitat) - senzor de nivel de combustibil poate sã fie defect.
- cipickao
- 113 mesaje
- din 13 Feb 2011
cipickao
Wizard
- Mesaje scrise: 47
- Masina: Corsa 2008 Z13DT
- Cont inregistrat: 23 Aug 2011
- iulian1971
- 7,067 mesaje
- din 21 Dec 2006
- Astra 2008 Z19DTH
- Ilfov
iulian1971
- Mesaje scrise: 7,067
- Masina: Astra 2008 Z19DTH
Wizard
- Mesaje scrise: 47
- iulian1971
- 7,067 mesaje
- din 21 Dec 2006
- Astra 2008 Z19DTH
- Ilfov
iulian1971
Wizard
- Mesaje scrise: 47
- iulian1971
- 7,067 mesaje
- din 21 Dec 2006
- Astra 2008 Z19DTH
- Ilfov
iulian1971
katto
- Mesaje scrise: 44
- Masina: Astra 2001 z16xe
- Cont inregistrat: 05 Mai 2011
katto
- Mesaje scrise: 44
katto
- Mesaje scrise: 44
Wizard
- Mesaje scrise: 47
am sa incerc o curatare a mufelor...
masina are un comportament normal..doar ca ma "pune pe ganduri " beculetul masina cu cheita care apare cel mai frecvent la turatie mare (peste 4000 rpm) sau cand am multi consumatori porniti (noaptea, cu faruri, muzica, clima)
initial cand am observat prima oara ca martorul clipeste aveam bateria pe duca..foarte slaba..am umblat asa o vreme iar apoi am schimbat-o cu una mai mare (72 Ah) sa fie... (electricianul mi-a recomandat, ca am multi consumatori si atunci sa poata duce..)
martorul a continuat sa apara..mai rar parca..dar tot aparea...
dupa o luna mi-a cazut bobina de inductie..aparea martorul cu cheita si apoi imediat check engine si esp...Am gasit erori 0303 si 0353 ceea ce era clar de la bobina.
dupa schimbarea bobinei am fost sigur ca martorul nu va mai aparea..dar supriza..
azi am zis sa intreb pe forum..poate cineva a rezolvat eroarea asta 1650..mi se pare dubioasa..
sa fie de la pompa de benzina?
