- parasutistul
- 266 mesaje
- din 12 Mai 2004
- Calibra 1994 C25XE V6
parasutistul
- Mesaje scrise: 266
- Masina: Calibra 1994 C25XE V6
- Calibra-Turbo
- 128 mesaje
- din 01 Jun 2005
- Germany
Calibra-Turbo
- Mesaje scrise: 128
- Cont inregistrat: 01 Jun 2005
- parasutistul
- 266 mesaje
- din 12 Mai 2004
parasutistul
- parasutistul
- 266 mesaje
- din 12 Mai 2004
parasutistul
- parasutistul
- 266 mesaje
- din 12 Mai 2004
parasutistul
- Calibra-Turbo
- 128 mesaje
- din 01 Jun 2005
- Germany
Calibra-Turbo
the problem you have is that you can not be sure that the second hand sensor you have installed is ok or not.To find out I would have done it this way.
If you only have code 17 then you can be sure that the front knock sensor is ok.So change both knock sensors (the front one against the rear one)and reset the ecu.When engine light comes again read the fault code.If it shows code 16 you can be sure that the knock sensor is damaged.If code 17 comes again then something else is damaged and not the knock sensor itself.Then you can start checking the other things that are written in the source you found.
- parasutistul
- 266 mesaje
- din 12 Mai 2004
parasutistul
- Calibra-Turbo
- 128 mesaje
- din 01 Jun 2005
- Germany
Calibra-Turbo
- parasutistul
- 266 mesaje
- din 12 Mai 2004
parasutistul
- parasutistul
- 266 mesaje
- din 12 Mai 2004
parasutistul
- parasutistul
- 266 mesaje
- din 12 Mai 2004
parasutistul
cortez- Mesaje scrise: 18
- Cont inregistrat: 04 Feb 2005
- dancuciureanu
- Moderator
- 16,465 mesaje
- Agila 2001 Z10XE + Z12XE
dancuciureanu
- Mesaje scrise: 16,465
Cauta la sh unul identic si nu te mai uita la cod ca o sa mearga sigur.
Singurii parametri importanti ar fi gama de frecventa (cam 30Hz-25kHz) si sensibilitatea (cam 25-40mV/g).
Cam toti sunt identici si nu ai probleme,
Succes
- parasutistul
- 266 mesaje
- din 12 Mai 2004
parasutistul
- deleted-4904
- 43 mesaje
- din 13 Feb 2007
deleted-4904
- Mesaje scrise: 43
- Cont inregistrat: 13 Feb 2007
