  2. Discuții generale
  • arson
  • Mesaje scrise: 162
  • Masina: Astra 2001 Y 2.0 DTH
  • Cont inregistrat: 27 Aug 2005
in iulie anul trecut am vazut in vama bechet, pe sensul de intrare in tara, un VW Touareg TDI cu inscriptia 12W. l-am intrebat pe proprietar ce semnifica si mi-a zis ca masina e unicat in tara si ca are 390 CP. acum ce nu inteleg: stiu ca VW are pe passat, de exemplu, un motor in 6 cilindri in V. ce ar trebui sa cred despre inscriptia 12 W ??? aud pareri?
  • virgil
  • Mesaje scrise: 273
  • Masina: Astra 2002 Y17DT
  • Cont inregistrat: 12 Mar 2005
trebuie sa crezi ca are un motor cu 12 cil in w (dublu v)
  • LEXXX
  • Mesaje scrise: 1,019
  • Masina: Astra 2004 Z18XE
E un motor care exista si pe Phaeton si pe cea mai tare versiune de Passat, e evoluat din V6-le FSI, practic sunt doua astfel de motoare unite.... Sincer sa fiu pe Touareg as prefera V10-le diesel..... Jeremy Clarkson tragea copaci in padure cu el, atat de mult i-a placut cuplul de autocamion....
  • arson
@virgil
si cum ar arata un motor in W? in V e de inteles,am vazut un passat variant in V6, dar in W??? cun se cupleaza bielele pe arbore?
  • AcidMan
  • Mesaje scrise: 641
  • Masina: Astra 2005 Z14XEP
  • Cont inregistrat: 16 Apr 2004
The W engine is an engine configuration in which the cylinder banks resemble the letter W in the same way a V engine resembles the letter V. There have been three entirely different implementations of this concept: one with three banks of cylinders, one with four banks, and one with two banks of cylinders and two crankshafts.
The Volkswagen Group (VAG) created the first successful automotive W engine with the introduction of their W12. It combined two narrow-angle VR6 engines around a single crankshaft for a total of four banks of cylinders. For this reason, the four-bank configuration is sometimes, and more accurately, referred to as a "VV" ("vee-vee" or "double-vee") to distinguish it from the traditional three-bank "W" design.
The W-12 is used in the Volkswagen Phaeton, the Audi A8 and the Bentley Continental GT - though in the latter application, the engine has been highly modified by Bentley and fitted with twin KKK turbochargers. As a result, it produces considerably more power than the original version. The narrow (15°) angle between bank pairs makes this resemble a V12 engine, in that it has just two cylinder heads and two sets of camshafts.
VAG went on to produce a W16 engine prototype which produced 623 horsepower (465 kW) for the Bentley Hunaudières concept car. A quad-turbocharged version of this engine went into production in 2005 powering the 1001hp Bugatti Veyron 16.4. A W8 engine was also produced for use in the VW Passat.
The major advantage of these engines is packaging, that is, they contain high numbers of cylinders but are relatively compact.
http://en.wikipedia.org/wiki/W_engine
  • rudareanu
  • Mesaje scrise: 87
  • Masina: Vectra 2003 Z18XE
  • Cont inregistrat: 15 Apr 2006
prima data am vazut (in poze) motor in W pe un Bugatti.
Daca gasesti o poza, poate te mai lamuresti un pic, deoarece motorul este sub haion.
  • foca montana
  • Mesaje scrise: 843
  • Masina: Vectra 2005 Z19DTH
rudareanu a scris:prima data am vazut (in poze) motor in W pe un Bugatti.
pai Bugati din cate stiu eu apartine grupului VAG
  • Cali...nV6
  • Mesaje scrise: 519
  • Cont inregistrat: 24 Apr 2004
eu stiam ca Passat numai W8 exista ....nu W12
  • LEXXX
ai dreptate, dar m-am documentat prea tarziu.....
  • AcidMan
am vazut un a8 w12, cred ca un a6 cu motorul asta ar fi criminal ...
  • arson
asemenea, un A8 quattro W12 intr-o benzinarie langa graz, deci, se poate!
  • andrea
  • Mesaje scrise: 18
  • Masina: Vectra 1998 x16szr
  • Cont inregistrat: 01 Sep 2006
acesta este un motor 12w VW
  • jonny
  • 483 mesaje
  • din 24 Apr 2005
  • Astra 2001 Z16SE
  • Cluj-Napoca, Romania
  • jonny
  • Mesaje scrise: 483
  • Masina: Astra 2001 Z16SE
  • Cont inregistrat: 24 Apr 2005
slabutz zic eu... asa in gluma
  • pascaru_val
  • Mesaje scrise: 1,388
  • Masina: Astra 2006 Z17DTL
Un A8 pe care scria W12 in fatza si 6.0 L in spate am vazut si eu pe Dorobanti cu nr de Bucuresti de mi-au ramas ochii lipiti, nu ma asteptam sa vad la noi in tara asa ceva. Din documentatie vad ca are doar 450 CP.
Veyron are W16, 1001 CP si 1250 Nm deci se poate si mai mult.
  • alex_arhire
  • Mesaje scrise: 988
  • Masina: Astra 2001 Z20LET
A8`ul ala din Piata Dorobanti l`am vazut si eu. Era chiar de vanzare pana de curand. 😃 Exista V12 TDI, are 500 CP; acest motor se poate pune si pe Audi Q7. La benzina, e W12. S`a ales configuratia in W pt. ca ocupa mai putin loc in compartimentul motor si are o functionare mult mai silentioasa.
La Veyron, unghiul V`urilor mici e de 15 grade, iar cel al V`ului mare e de 90 de grade. Baietii au tb. sa inventeze nush ce fel de sistem care supraveghezeaza daca toate pistoanele functioneaza normal pt. ca la un un nr. asa de mare de cilindrii, nefunctionarea unuia dintre ele nu s`ar putea face observata.
Pe Passat, cel mai mare motor a fost un W8, pare`mi`se ca de 4.2 l si vreo 300 CP care era cuplat la tractiunea integrala 4Motion.
Cam aceleasi motoare le are si Phaeton`ul. V10 TDI avea 333 CP; eu as alege un V8 4.2 TDI 326 CP; e mult mai rafinat si mai "economic", in plus cantareste si mult mai putin.
  • octav13
  • Mesaje scrise: 2,057
pascaru_val a scris:Un A8 pe care scria W12 in fatza si 6.0 L in spate am vazut si eu pe Dorobanti cu nr de Bucuresti de mi-au ramas ochii lipiti, nu ma asteptam sa vad la noi in tara asa ceva. Din documentatie vad ca are doar 450 CP.
veyrom are 4(patru)turbocompresoare,cate unu pt.fiecare rand de cilindri;de aici provine puterea mai mare si cuplu
  • dragoshelu
  • Mesaje scrise: 20
  • Cont inregistrat: 20 Oct 2006
andrea a scris:
vai de mine ce motor...am ramas... 😕 mascaaa...nu stiam de asa ceva!😛
  • martynel
  • Mesaje scrise: 165
  • Masina: Astra 2003
  • Cont inregistrat: 12 Dec 2006
Imi pun si eu la Astra W12:) si o sa am schimbatorul de viteza pe bancheta din spate si eu o sa stau in porbagaj!
