- dany_ionutz
- 453 mesaje
- din 22 Oct 2008
- Vectra 2003 2.2 dti 125cp
- Suceava
dany_ionutz
- Mesaje scrise: 453
- Masina: Vectra 2003 2.2 dti 125cp
- Cont inregistrat: 22 Oct 2008
- CristianTM
- 3,701 mesaje
- din 15 Mar 2006
- Insignia A Fastback 2010 A20DTH
- Timisoara
CristianTM
- Mesaje scrise: 3,701
- Masina: Insignia A Fastback 2010 A20DTH
- lucio
- 782 mesaje
- din 29 Aug 2008
- Signum 2006 Z19DTH
- Neamt
lucio
- Mesaje scrise: 782
- Masina: Signum 2006 Z19DTH
- Cont inregistrat: 29 Aug 2008
- dany_ionutz
- 453 mesaje
- din 22 Oct 2008
- Suceava
dany_ionutz
- lucio
- 782 mesaje
- din 29 Aug 2008
- Neamt
lucio
acelasi model il am si eu.sper sa ma ajute cineva care a mai facut operatiunea
Poate la tine merge si la mine e intepenita.La tine nu a sarit cromul de pe partea centrala ?
- dany_ionutz
- 453 mesaje
- din 22 Oct 2008
- Suceava
dany_ionutz
mie nu mi-a sarit cromul.la mine s-a julit pielea de pe maneta
- lucio
- 782 mesaje
- din 29 Aug 2008
- Neamt
lucio
- CristianTM
- 3,701 mesaje
- din 15 Mar 2006
- Timisoara
CristianTM
- CristianTM
- 3,701 mesaje
- din 15 Mar 2006
- Timisoara
CristianTM
- lucio
- 782 mesaje
- din 29 Aug 2008
- Neamt
lucio
- crystyxcw
- 282 mesaje
- din 05 Jan 2008
- Vectra 2003 Z19DTH
crystyxcw
- Mesaje scrise: 282
- Masina: Vectra 2003 Z19DTH
- Cont inregistrat: 05 Jan 2008
The following guide is taken from September 04 issue of Total Vauxhall magazine as part of their project signum series of articles.
STEPS 1 -3
Step 1
Prize off plastic top with a screwdriver, which will reveal the gearknob itself underneath, and the leather stitched around the outside.
Step 2
We used a junuir hacksaw to cut the plastic and leather off around the gearknob. Take your time, and use some masking tape if you want to avoid making a mess of the rest of your interior.
Step 3
The aluminium core is held on the shaft by a tight fitting spline. Saw off the aluminuim or gently heat it and pull it off. Sawing it off is safer as long as you're careful not to damage the levers shaft. We cut down the centre and along one side, then split with a hammer and chisel.
STEPS 4 - 6
Step 4
With the aluminium core off, slide the new knob on after removing any swarf. Theres a grub screw at the back of the knob which secures it to the levers shaft.
Step 5
All that remains is to fit the plastic top. Clean the surface, then apply the supplied adhesive and fit the top. You can tape into in place for extra security as the adhesive takes 6 hours to dry properly.
Step 6
Now you're done. Make sure the knob is totally secure before you drive off.
- dany_ionutz
- 453 mesaje
- din 22 Oct 2008
- Suceava
dany_ionutz
- crystyxcw
- 282 mesaje
- din 05 Jan 2008
crystyxcw
- CristianTM
- 3,701 mesaje
- din 15 Mar 2006
- Timisoara
CristianTM
- lucio
- 782 mesaje
- din 29 Aug 2008
- Neamt
lucio
- dany_ionutz
- 453 mesaje
- din 22 Oct 2008
- Suceava
dany_ionutz
O seara placuta tuturor!
la 183500km cred si eu sa se roada pielea de pe maneta.si plasticul are cateva zgarieturi dar nu ma deranjeaz.
tarpanu
- Mesaje scrise: 6
- Masina: Vectra 2003 y20dth
- Cont inregistrat: 16 Mar 2010
- challange30
- 40 mesaje
- din 28 Jun 2010
- Vectra 2005
challange30
- Mesaje scrise: 40
- Masina: Vectra 2005
- Cont inregistrat: 28 Jun 2010
Omega
- Mesaje scrise: 95
- Masina: Vectra 2007 z16xep
- Cont inregistrat: 30 Sep 2007
Stiu ca mai sunt si alte modele pe piata, am si eu aceeasi problema cu pielea de pe partea dreapta care s-a ciupit initial, apoi s-a despicat si arata urat. Caut de ceva vreme una la fel (tot din piele) pentru ca nu-s dispus sa platesc sute de lei pentru o piesa de care nu am nevoie.
In dezmembrari vor la fel sa vanda si aia.
laur69
- Mesaje scrise: 56
- Masina: Vectra 2005 Z19DT
- Cont inregistrat: 15 Mar 2007
C-am atata e una noua . Scumpa .
Dar eu am optat pentru una din aluminiu ( adevarat este ca nu arata asa de bine ca cea originala ) dar am dat pe ea 25 Ron . pentru cei care vor sa-si ia una sa fie atenti la grosimea bazei pe exterior (ca sa poata intra in mansarier). Interiorul pe ax e reglabil.
