shaung
- Mesaje scrise: 17
- Cont inregistrat: 20 Apr 2005
- canan17ro
- 132 mesaje
- din 05 Feb 2005
- Astra 2018 16SHT
canan17ro
- Mesaje scrise: 132
- Masina: Astra 2018 16SHT
- Cont inregistrat: 05 Feb 2005
Ca atu mare vei avea consumul si masina nu va fi chiar lenesa. Eu am mers cu Astra H 1.7 CDTI de 80 de cai diesel (a fost inlocuita de acest motor de 1.3) si nu am simtit ca nu m-as descurca in trafic cu puterea.
shaung
- Mesaje scrise: 17
- canan17ro
- 132 mesaje
- din 05 Feb 2005
- Astra 2018 16SHT
canan17ro
- VIPER
- 306 mesaje
- din 22 Sep 2004
VIPER
- Mesaje scrise: 306
- Cont inregistrat: 22 Sep 2004
- turatii
- 293 mesaje
- din 05 Jun 2005
- Astra 2005 Z17DTL
turatii
- Mesaje scrise: 293
- Masina: Astra 2005 Z17DTL
- Cont inregistrat: 05 Jun 2005
shaung
- Mesaje scrise: 17
- canan17ro
- 132 mesaje
- din 05 Feb 2005
- Astra 2018 16SHT
canan17ro
Uite o fisa cu date tehnice :
http://www.autoindex.org/vers2.plt?no=12276
In aceasta lista apare numai disponibil cu 6 trepte si easytronic. 13.7 pana la suta, 172 vmax, consum mediu 4.8%.
Spune concret ce ai vrea sa mai stii.
- VIPER
- 306 mesaje
- din 22 Sep 2004
VIPER
"Engine data
Engine: 1.3 CDTI ECOTEC
Engine, location: front, transverse in front of axle, 12° inclined
Cooling system: with liquid, sealed circuit
Cylinders, number: 4
Bore (mm): 69.6
Stroke (mm): 82
Displacement (cc): 1248
Compression ratio: 18:1
Engine, type: in line; 5 main bearings
Cylinder block/head, material: cast iron/alumnium alloy
Camshaft(s), location: 2 overhead (DOHC), driven by chain
Valve train: indirect roller cam followers, hydraulic tappets
Valve, arrangement: parallel; 4 per cylinder
Valve adjustment: automatic - hydraulic
Fuel system: diesel direct injection, common rail
Fuel pump: mecanical
Emission control system: 2-way cat. conv., exhaust gas recirculation
Charger system: turbo with intercooler
Output (kW/hp CEE at 1/min): 66/90 at 4000
Specific power (kW/l; hp/l): 52.9; 72.1
Max. torque (Nm at 1/min): 200 at 17502500
Specific torque (Nm/liter): 160.3
Mean effective pressure at
max. power/max. torque (kPa): 1586.5/2014.7
Average piston speed (m/s): 10.9
Engine oil, capacity (l): 3.5
Cooling capacity (l): 5.6
Battery 12 V, capacity (Ah): 60
Alternator 14.2 V, capacity (W): 994
Performance
Top speed (km/h)* : 172
Acceleration 0-100 km/h (sec)* : 13.7
Acc. 80-120 km/h in 5th gear (sec)* : 15.6
Pass-by noise (dBA): 72
Fuel: Diesel
Fuel consumption (liter/100 km): Measured according to EU guideline 99/100/EU.
Additional equipment can lead to increased
consumption and CO2 values.
urban: 6.2
extra-urban: 4.0
total: 4.8
CO2 emission (g/km): 130
Emission class: Euro 4"
shaung
- Mesaje scrise: 17
- fm
- 175 mesaje
- din 19 Oct 2005
fm
- Mesaje scrise: 175
- Cont inregistrat: 19 Oct 2005
- turatii
- 293 mesaje
- din 05 Jun 2005
- Astra 2005 Z17DTL
turatii
Am mers si cu Astra H 1,3l CDTI 90 Cp 6 trepte si mi se pare super ok motorul in combinatie cu cutia cu 6 trepte. Daca iei insa cu cinci trepte si iti place sa alergi cat de cat, ia motorul de 1,7 CDTI. Parerea mea...
La consum nu e nici o diferenta notabila. Fiat-ul ia 5,3-5,5 mediu impins la blana (Bucuresti Arad si retur) iar Opelul Classic 5,5 tot la blana.
Ultima modificare făcută de turatii la Lun 07 Nov, 2005 4:06 pm
- VIPER
- 306 mesaje
- din 22 Sep 2004
VIPER
1.3 CDTI 66kW/90hp:
Max. torque (Nm at 1/min): 200 at 1750-2500
Gear ratios: 1st ratio: 4.27 2nd ratio: 2.16 3rd ratio: 1.3
4th ratio: 0.96 5th ratio: 0.74 6th ratio: 0.61
reverse ratio: 3.82 final drive ratio: 3.72
Performance
Fuel: Diesel
Additional equipment can lead to increased consumption and CO2 values.
urban: 6.2 / extra-urban: 4.0 / total: 4.8
1.7 CDTI 74kW/100hp
Output (kW/hp CEE at 1/min): 74/100 at 4400
Specific power (kW/l; hp/l): 43.9; 59.3
Max. torque (Nm at 1/min): 240 at 2300
Specific torque (Nm/liter): 142.3
Gear ratios: 1st ratio: 3.58 2nd ratio: 1.89 3rd ratio: 1.19
4th ratio: 0.85 5th ratio: 0.69
reverse ratio: 3.31 final drive ratio: 3.95
Performance
Top speed (km/h)* : 180
Acceleration 0-100 km/h (sec)* : 12.3
Acc. 80-120 km/h in 5th gear (sec)* : 12.5
Pass-by noise (dBA): 70
Fuel: Diesel
urban: 6.4 - 6.5 / extra-urban: 4.2 - 4.3 / total: 5.0 - 5.1
CO2 emission (g/km): 135 - 138
Un avantaj la 1.3 mi se pare transmisia cu lant, nu cu curea ca la 1.7. E si cu 35kg mai usoara decat 1.7. E si generatie mai noua...
Disclaimer: sunt pareri personale. Nu va simtiti lezati...
Ultima modificare făcută de VIPER la Lun 07 Nov, 2005 10:00 am
- sorin666
- 3,885 mesaje
- din 12 Mai 2004
- outside Manell's Land
sorin666
- Mesaje scrise: 3,885
- VIPER
- 306 mesaje
- din 22 Sep 2004
VIPER
- fm
- 175 mesaje
- din 19 Oct 2005
fm
- VIPER
- 306 mesaje
- din 22 Sep 2004
VIPER
1,3CDTi 90CP 12,704 13,620 14,036 14,286
1.3CDTi 90CP Easytronic 13,120 14,036 14,454 14,703
1,7CDTI 100CP 13,197 14,102 14,514 14,760
1,7CDTI 100CP 6 trepte 13,691 14,596 15,007 15,254
Am pus CIP pentru ca unii vor leasing. Pentru DDP adaugati TVA si acciza (pana la 1.6 parca acciza e de 1%).
- fm
- 175 mesaje
- din 19 Oct 2005
fm
- VIPER
- 306 mesaje
- din 22 Sep 2004
VIPER
- sorin666
- 3,885 mesaje
- din 12 Mai 2004
sorin666
