ENE AUREL
- Mesaje scrise: 11
- Masina: Vectra 1995 x 20xev
- Cont inregistrat: 01 Sep 2007
- murzick
- 1,007 mesaje
- din 10 Dec 2006
- Vectra 2001 Z18XE
murzick
- Mesaje scrise: 1,007
- Masina: Vectra 2001 Z18XE
LE: Ti se aprinde becul "Check Engine"?
- Remus Cristea
- 330 mesaje
- din 24 Feb 2008
- Vectra 1997 x20xev
Remus Cristea
- Mesaje scrise: 330
- Masina: Vectra 1997 x20xev
- Cont inregistrat: 24 Feb 2008
- Remus Cristea
- 330 mesaje
- din 24 Feb 2008
Remus Cristea
- fnf bogdan fnf
- 447 mesaje
- din 07 Dec 2007
- Astra 2001 Y20DTH
fnf bogdan fnf
- Mesaje scrise: 447
- Masina: Astra 2001 Y20DTH
- Cont inregistrat: 07 Dec 2007
- Remus Cristea
- 330 mesaje
- din 24 Feb 2008
Remus Cristea
- murzick
- 1,007 mesaje
- din 10 Dec 2006
- Vectra 2001 Z18XE
murzick
Camshaft - ax cu came
Crankshaft - arbore cotit
P0335 - Incorrect RPM Signal:
- The control unit did not recognise 58 teeth pulses between the synchronisation marks on the crankshaft pulley
- Time is implausible while a tooth gap is recognised.
- With trouble code P0335 stored and engine speed greater than 8000 rpm, trouble code P0340 (camshaft sensor fault) is additionally stored.
(Short circuit to ground or circuit interruption)
(Short circuit of signal lead to oscillator lead)
(Intermittent problems in the signal leads)
- Above conditions must be fulfilled for at least 3.5 s .
Replacement Value:
- Camshaft emergency operation
- The crankshaft position, engine speed and spark timing are calculated from the camshaft signal. The engine speed is limited to 4512 rpm.
Effect:
- If trouble code P0335 is stored in addition to trouble code P0340 , injection and ignition are locked.
Note:
- "Emergency Mode" remains activated until the next ignition OFF.
Concerned Terminals:
- 16, 24, 29
Verifica senzorul arborelui cotit.
- Remus Cristea
- 330 mesaje
- din 24 Feb 2008
Remus Cristea
- Remus Cristea
- 330 mesaje
- din 24 Feb 2008
Remus Cristea
- dancuciureanu
- Moderator
- 16,464 mesaje
- Agila 2001 Z10XE + Z12XE
dancuciureanu
- Mesaje scrise: 16,464
Mergi la intilnire https://www.clubopel.com/vie...678&start=480 si djtaotao iti face el o diagnoza sigura.
- Remus Cristea
- 330 mesaje
- din 24 Feb 2008
Remus Cristea
- Bogeyman
- 234 mesaje
- din 25 Mai 2007
- Ascona 1985
Bogeyman
- Mesaje scrise: 234
- Masina: Ascona 1985
- Cont inregistrat: 25 Mai 2007
- murzick
- 1,007 mesaje
- din 10 Dec 2006
- Vectra 2001 Z18XE
murzick
- dancuciureanu
- Moderator
- 16,464 mesaje
dancuciureanu
Testerele "universale" cum este acest Brainbee (de altfel si KTS lui Bosch) sunt pline de greseli.
P0335 Crankshaft position sensor "A" circuit high input
P0335 Crankshaft position sensor "A" circuit low input
P0335 Crankshaft position sensor "A" circuit malfunction
P0335 Crankshaft Position Sensor "A" Circuit Open
P0340 Camshaft position sensor circuit malfunction
P0340 Camshaft position sensor circuit high input
P0340 Camshaft Position Sensor Signal Missing
P0340 Camshaft Position Sensor Circuit Range/Performance
P0340 Camshaft position sensor circuit low input
ENE AUREL
- Mesaje scrise: 11
ENE AUREL
- Mesaje scrise: 11
- Remus Cristea
- 330 mesaje
- din 24 Feb 2008
Remus Cristea
ENE AUREL
- Mesaje scrise: 11
- Remus Cristea
- 330 mesaje
- din 24 Feb 2008
Remus Cristea
- Remus Cristea
- 330 mesaje
- din 24 Feb 2008
Remus Cristea
