wryy09
- Mesaje scrise: 5
- Masina: Astra 2006 Z19DTH
- Cont inregistrat: 13 Apr 2022
Mentionez ca atunci cand dau la automat acul turometrului nu se ridica ca deobicei invarte de o iau draci dar acul nu se ridica cum facea deobicei.
Am urmatoarele coduri de eroare stocata : ECN040004 , 033529 , 148104 , 148204, 052004, 20750F dar sunt aici de vreo 7k masina avand o problema cu prima pornire dar niciodata nu sa oprit dupa ce a pornit
PS: Am citit pe forum intrebarile voastre gen : Acul turometrului se ridica cand dai la automat dar nu si raspunsul
MODEL: Astra 2006
MOTOR: Z19DTH
- corsablue
- 2,957 mesaje
- din 18 Feb 2008
corsablue
- Mesaje scrise: 2,957
Din acest motiv nu indica nimic acul turometrului.
Pare nitica distributie terminata...
Dar nu crede ce scriu eu.
P2075 Swirl Level Sensor Circuit Voltage Range/Performance B-024
P2075 Swirl Level Sensor Circuit Frequency Range/Performance C-018
P2075 Swirl Level Sensor Malfunction C-018
P2075 Swirl Level Sensor Circuit Open or High Voltage C-018
P2075 Swirl Level Sensor Circuit Low Voltage B-024
P2075 Swirl Level Sensor Circuit Range/Performance C-018
P2075 Swirl Level Control Solenoid Valve Stuck B-033
P2075 Swirl Level Control Solenoid Valve Frequency Range/Performance C-018P2075 Swirl Level Control Solenoid Powerstage High Temperature C-018
148104 & 148204
P1481 Fan Control 1 Circuit High Voltage Engine Cooling B-004
P1481 Fan Control 1 Circuit Low Voltage Engine Cooling B-004
P1481 Fan Control 1 Circuit Open Engine Cooling C-003
P1481 Fan Control 1 Powerstage High Temperature Engine Cooling C-003
P1482 Fan Control 2 Circuit High Voltage Engine Cooling B-004
P1482 Fan Control 2 Circuit Low Voltage Engine Cooling B-004
P1482 Fan Control 2 Circuit Open Engine Cooling C-003
P1482 Fan Control 2 Powerstage High Temperature Engine Cooling C-003
Informatii preluate de aici: https://www.astraownersnetwo...codes-mean.77817/
Ultima modificare făcută de corsablue la Mie 13 Apr, 2022 5:04 pm
wryy09
- Mesaje scrise: 5
- corsablue
- 2,957 mesaje
- din 18 Feb 2008
corsablue
wryy09
- Mesaje scrise: 5
- corsablue
- 2,957 mesaje
- din 18 Feb 2008
corsablue
wryy09
- Mesaje scrise: 5
Ma mira foarte tare sa fi sarit distributia avand in vedere ca cei 7k i am facut intr-o luna eu facand circa 250km pe zi si ea sare de la punct cand este pe loc..
wryy09
- Mesaje scrise: 5
- iulian1971
- 7,053 mesaje
- din 21 Dec 2006
- Ilfov
iulian1971
- Mesaje scrise: 7,053
