wryy09
- Mesaje scrise: 5
- Masina: Astra 2006 Z19DTH
- Cont inregistrat: 13 Apr 2022
Buna ziua ! Detin o Astra H 1.9 Cdti twintop si astazi a pornit am lasat-o sa se incalzeasca si dupa cinci minute sa oprit si nici ca a mai pornit...
Mentionez ca atunci cand dau la automat acul turometrului nu se ridica ca deobicei invarte de o iau draci dar acul nu se ridica cum facea deobicei.
Am urmatoarele coduri de eroare stocata : ECN040004 , 033529 , 148104 , 148204, 052004, 20750F dar sunt aici de vreo 7k masina avand o problema cu prima pornire dar niciodata nu sa oprit dupa ce a pornit
PS: Am citit pe forum intrebarile voastre gen : Acul turometrului se ridica cand dai la automat dar nu si raspunsul
MODEL: Astra 2006
MOTOR: Z19DTH
MODEL: Astra 2006
MOTOR: Z19DTH
- corsablue
- 2,791 mesaje
- din 18 Feb 2008
- Corsa 2005 Z13DT
corsablue
- Mesaje scrise: 2,791
- Masina: Corsa 2005 Z13DT
033529 - Crankshaft Position Sensor
Din acest motiv nu indica nimic acul turometrului.
Pare nitica distributie terminata...
Dar nu crede ce scriu eu.
P2075 Swirl Level Sensor Circuit Voltage Range/Performance B-024
P2075 Swirl Level Sensor Circuit Frequency Range/Performance C-018
P2075 Swirl Level Sensor Malfunction C-018
P2075 Swirl Level Sensor Circuit Open or High Voltage C-018
P2075 Swirl Level Sensor Circuit Low Voltage B-024
P2075 Swirl Level Sensor Circuit Range/Performance C-018
P2075 Swirl Level Control Solenoid Valve Stuck B-033
P2075 Swirl Level Control Solenoid Valve Frequency Range/Performance C-018P2075 Swirl Level Control Solenoid Powerstage High Temperature C-018
148104 & 148204
P1481 Fan Control 1 Circuit High Voltage Engine Cooling B-004
P1481 Fan Control 1 Circuit Low Voltage Engine Cooling B-004
P1481 Fan Control 1 Circuit Open Engine Cooling C-003
P1481 Fan Control 1 Powerstage High Temperature Engine Cooling C-003
P1482 Fan Control 2 Circuit High Voltage Engine Cooling B-004
P1482 Fan Control 2 Circuit Low Voltage Engine Cooling B-004
P1482 Fan Control 2 Circuit Open Engine Cooling C-003
P1482 Fan Control 2 Powerstage High Temperature Engine Cooling C-003
Informatii preluate de aici: https://www.astraownersnetwo...codes-mean.77817/
Ultima modificare făcută de corsablue la Mie 13 Apr, 2022 4:04 pm
148104 & 148204
wryy09
- Mesaje scrise: 5
Multumesc de raspuns! Distributia am schimbat o in urma cu 7k km... masina a stat circa o luna pe dreapta si de atunci daca o las mai mult de doua zile nepornita porneste ff. greu ea avand check engine ul aprins dar tot timpu se ridica acul turometrului in incercarea de pornire.. azi a pornit la prima cheie sa oprit si nu a mai vrut deloc
- corsablue
- 2,791 mesaje
- din 18 Feb 2008
- Corsa 2005 Z13DT
corsablue
wryy09
- Mesaje scrise: 5
- corsablue
- 2,791 mesaje
- din 18 Feb 2008
- Corsa 2005 Z13DT
corsablue
wryy09
- Mesaje scrise: 5
Multumesc de info ! Tocmai asta e ideea ca nu vreau sa arunc cu bani aiurea ..credeam ca astea sunt codurile de eroare cele care le am citit eu cu acceleratia si frana apasate
Ma mira foarte tare sa fi sarit distributia avand in vedere ca cei 7k i am facut intr-o luna eu facand circa 250km pe zi si ea sare de la punct cand este pe loc..
wryy09
- Mesaje scrise: 5
- iulian1971
- 7,066 mesaje
- din 21 Dec 2006
- Astra 2008 Z19DTH
- Ilfov
iulian1971
- Mesaje scrise: 7,066
- Masina: Astra 2008 Z19DTH
