adiroz
- Mesaje scrise: 14
- Masina: Astra 2008 z14xep
- Cont inregistrat: 01 Jul 2010
adiroz
- Mesaje scrise: 14
adiroz
- Mesaje scrise: 14
adiroz
- Mesaje scrise: 14
- bibu16v
- 7,164 mesaje
- din 25 Jan 2016
- Astra 1995 X16XEL
bibu16v
- Mesaje scrise: 7,164
- Masina: Astra 1995 X16XEL
O idee cum poți dezactiva anumiți senzori(ca o soluție provizorie pânã ai o rezolvare):
”Assuming it's the Vauxhall standard system: There is no way to lock the car without setting the alarm. You will have to disconnect it. This has to be done with the ignition switched on or else the internal battery sounds the alarm till flat.
However there are 2 bits on the alarm, the door sensors, and the internal movement and anti jack(tilt) sensors. If you press both the interior light buttons as you get out (should start the alarm LED flashing) and then lock within 10 seconds the movement sensors &c. are disabled, leaving just the door switches live. Being mechanical those should be ok., though the car won't be quite as secure. ”
adiroz
- Mesaje scrise: 14
adiroz
- Mesaje scrise: 14
- bibu16v
- 7,164 mesaje
- din 25 Jan 2016
- Astra 1995 X16XEL
bibu16v
adiroz
- Mesaje scrise: 14
