  2. Discuții generale
  • Amilo2727
  • Mesaje scrise: 184
  • Masina: Astra 2002 Z16SE
  • Cont inregistrat: 08 Feb 2016
Salutare Dragi Opelisti,
Deoarece detin un Astra G,2002,nu am stiut unde in acest imens forum sa incadrez acest topic,imi cer scuze daca nu este incadrat bine si rog a se muta unde trebuie.
Deci,cer un sfat de la cei profesionisti in legatura cu achizitionarea unei platforme OBD 2 dupa cum urmeaza :
1. Op-Com Auto Diagnostic Interface for Opel V1.45 Can Bus
Pret : 18 USD
General :
Special function: Full status information (present, not present, intermittent)
Voltage: 12V
Language: English
Color: Black
Material: Plastic, Electronic components
Specificatii :
Full status information (present, not present, intermittent).
● Clear fault codes, show you live data, let you to perform output test.
● Can print out, save, or copy the fault codes to any other application.
● From the fault codes window, can directly measure blocks window.
● Small Bluetooth interface with a 16 pin socket.
● Need the vehicle security code, which can be found on the CAR-PASS.
● Covering almost all Opel cars, even new cars with CAN - BUS based diagnostic, such as Vectra - C, Astra - H, Zafira - B.
● USB port based diagnostic interface, with serial interfaces to USB converters.
● Enough to handle the awesome speed of the high-speed CAN-BUS systems, which is currently 500kbps.
● Covers almost all Opel cars from 1992 - 2008, even new cars with CAN-BUS based diagnostic, such as Vectra-C, Astra-H, Zafira-B
● Fault codes will be shown with all available information.
Data measurements: OBD II repair information
Supports OBD2 protocols: ISO15765-4 (CAN),ISO14230-4 (KWP2000),ISO9141-2,J1850 VPW,J1850 PWM
Cable length: 1.5m
2.Op - com OBD2 Vehicles Diagnostic Device Set
Pret : 20 USD
General :
Model : Op-com
Color : Black
Specificatii :
Cam atatea info am gasit despre acest produs,insa sunt curios ce face acesta de la nr 2 si cel de mai sunt fiind Nr 1
3. AUTOPHIX OBDMATE OM123 OBD Code Scanner OBD II / EOBD + CAN Car Diagnostics Tool
Pret : 25 USD
General:
Brand: AUTOPHIX
Model : OBDMATE OM123
Voltage : DC 12V
Language : Russian, German, Spanish, English, Finnish, French, Dutch, Portugal
Color : Black
Specificatii :
Screen: LCD
Data measurements: calculated engine load, reads and clears trouble codes, OBD II repair information, engine rotational speed, engine coolant temp, engine temperature, reas live PCM datastream, live data, view freeze frame data
Supports OBD2 protocols: ISO9141-2, ISO14230-4 (KWP2000), ISO15765-4 (CAN), J1850 PWM, J1850 VPW
Cable length: 85 cm
Easily determins the cause of the Check Engine Light (MIL)
Turns off Check Engine Light (MIL)
Reads live datastream
Supports multilingual menu options and code definitions
Built-in OBD II fault code library
Retrives vehicle information (VIN / CIN / CVN)
I/M monitor readiness test
Views freeze frame data
Easy-to-read LCD display
Designed with 16 PIN
No batteries supply power through detachable OBD II cable
Highly reliable and accurate read fault code and vehicle information
Supports all OBD II protocols: CAN / J1850 PWM / J1850 VPW / ISO9141 and KWP2000
It works on all after 1996 OBD II compatible with US, European and Asian vehicles
Cable length: 85cm
4.Vgate VS600 OBDII Car Diagnostic Tool
Pret : 45 USD
General:
Brand: Vgate
Model : VS600
Voltage : 12V
Language : English
Color : Orange
Material : ABS
Specificatii :
Screen: LCD
Adaptable automobile mode : All 1996 and later OBD2 compliant US, European and Asian vehicles
Data measurements: reads and clears trouble codes, view freeze frame data, memory/bettry backup, display live O2 sensor test data, fuel consumption, reas live PCM datastream
Supports OBD2 protocols: ISO14230-4 (KWP2000), ISO9141-2, ISO15765-4 (CAN)
Cable length: 136cm
Protocols supported: ISO9141-2 ( CARB ), ISO14230 ( KWP-2000 ), ISO-15765 ( CAN )
Diagnose interface: 16pin
Compatible cars: General
Cable length: 136cm
Working voltage: 12V
Language: English
Battery type: 9V, 1 6LR61 ( not included )
Works on all 1996 and later OBD2 compliant US, European and Asian vehicles
Easily determines the cause of the "Check Engine Light ( MIL )"
Retrieves generic ( P0, P2, P3, U0) and manufacturer specific ( P1, P3, and U1 ) codes
Turns off Check Engine Light, clears codes and resets monitors
Displays DTC definitions onscreen
Displays monitor and I/M readiness status ( emissions )
Identifies pending codes
Reads live PCM datastream
Displays live O2 sensor test data
Graphs data ( 1996 and newer )
Reads, stores and playbacks live sensor data
Memory / battery backup for off-vehicle data review and analysis
Bilingual interface and definitions English / Spanish
Performs modules present test
Retrieves vehicle information ( VIN, CID and CVN )
Supports CAN ( Controller Area Network ) and all other current OBD2 protocols
Built-in OBD2 DTC lookup library
Large easy-to-read backlit LCD screen
Software upgradeable via internet
Prints data via PC
Suitable for most band car, it is widely-used and practical
Compact and lightweight design, it is convenient for you to carry
Multiple index can be detected, easily to operate
Color big screen with LCD backlight display, it is clearly and easy to read
Indicators with curve icon, it is simple and clearly
Nu am lucrat niciodata cu asemenea "scule" , ma intereseaza achizitionarea unuia dintre ele pentru uz personal si as merge catre produsul Nr 1.
Astept parerile voastre,multumesc !
  • Amilo2727
Nimeni ?
  • Lotg
  • Mesaje scrise: 1,633
  • Masina: Astra 2004 Z14XEP
Pentru uz personal e buna varianta 1.
OFF: Nu ai stiut unde sa incadrezi acest subiect, deoarece detii un opel astra? 👽
  • Amilo2727
hehe colegu carcotash mai esti 😊
subiectul l-am deschis in topicul de Astra G,cat despre masina pe care o detin,m-am gandit sa spun ce model am in speranta ca sa primesc cel mai bun raspuns pentru produsele prezentate mai sus.
Oricum iti multumesc pentru parere,o alta parere ?
  • jE
  • Mesaje scrise: 8,413
Pai pruima intrebare e: tu ce vrei sa faci cu interfata?
  • Amilo2727
jE say :
Pai cam tot ce se poate face cu op-com de exemplu.
Detesc pe circarii care iti iau banii pentru nici 5 minute,prefer sa ii tin in buzunar acei bani si de ce nu sa-mi ajut un vecin sau cineva de pe forum care este prin apropierea mea.
Insa pe viitor ca deocamdata nu stiu nimic 😊 insa cine s-a nascut invatat ? Sunt pregatit sa invat a folosit un astfel de gadget.
Am aflat fara a vrea ca pe op-com se pot face foarte multe chestii,exclus km dat inapoi,sunt contra la genul asta de escrocherii si presupun ca nu sunt singurul 😊 😃
  • Amilo2727
Am achizitionat produsul nr 1,abia astept sa ajunga in posesia mea 😃
  • iso
  • Mesaje scrise: 1,347
  • Masina: Insignia 2010
Ce bine este ca "detesci" ceva despre care n'ai habar numai pentru ca cineva iti cere bani pentru un serviciu oferit tie, in folosul tau. Stai linistit ca "circarii" despre care vorbesti au aparut pe piata exact la fel ca tine. 😂 Noroc cu gunoaiele ieftine de op-com chinezarie ca nu si'ar fi luat nimeni op-com'ul original ca sa munceasca degeaba. Acum ca ti'ai luat vioara sa vedem cum o sa cinti la ea. 😂
Apropos ce meserie ai ca poate incerc si eu sa ti'o fur,... eii numai asa din pasiune, ca sa'i ajut pe altii gratis si sa'ti iau tie painea de la gura, nu de altceva... 😂
  • Amilo2727
iso de la tine deduc ca te ocupi cu treburi nasoale si sa stii ca pentru 2 minute de folosit op-com sati arate erorile,asta este jaf la drumul mare !
Eu l-am luat pentru uz personal si chiar ma gandeam cand o sa apara cateva ganganii ca tine care le este frica ca inca cineva si-a luat op-com si le ia cei 50/60 de lei amarati de la gura,stai relax si veziti de treaba si cafeaua ta !
  • iso
Ce dragut esti, multumesc pentru gindurile frumoase si urarile de bine! Tinere' ai dedus gresit cu ce ma ocup din moment ce'ai cistigat un concediu gratuit de pe forum. Cind treci prin Galati sa vii sa vezi cum se face un tester asa cum trebuie facut.
Altfel iti doresc La multi ani!, sanatate si la mai mare!
  • jE
iso, cred ca iti scapa pinioanele in cutie... 😊 .. Ai vrut sa zici "cum se face o testare", banui. Sau ma insel?
  • iso
Nu, nu'mi scapa nimic, asa se zice pe la noi in argoul popular-mecanicos: "vreau sa fac un tester!" La inceput le'am raspuns ca n'au cunostintele necesare sa construiasca un tester 😂 , de la o vreme zic ca ei... 😉
😂 Da' stai bre' ca n'am inteles de ce te bagi in discutia noastra semidocta 😂 , vrei sa te conving ca ar fi timpul sa te banezi singurel? 😂
Ultima modificare făcută de iso la Mar 12 Apr, 2016 5:17 pm
  • jgyprime
  • Mesaje scrise: 9,951
  • Masina: Vectra 2005 Z19DT
s-a bagat din cauza ca autorul topic-ului e cam suspendat...
  • Amilo2727
Iso eu am spus destul de clar ca vreau pareri de la profesionisti si ceea ce voie face cu el nu-mi dau seama ce te-ar interesa.
Te rog cauta un alt topic de discutii care nu sunt in interesul intrebarii de la postul 1.
  • Amilo2727
Si ca o adaugare,op-com care nu'i chinezarie este in jur de 150/200 lei,bine...este limitat,iar cel pro este in jur la 2200/2500 ron ,soft in limba romana insa nu ma deranjeaza "chinezaria care am achizitionato" in limba engleza.
Bun...abia astept sa-mi vina "jucaria" 😃
  • jE
Amilo, ia-o usor, ca altfel iar o sa faci ture de incalzire in jurul stadionului.
1- iso stie destul de multe despre diagnoza auto. Cu certitudine mai multe decat banui tu acum ca ai avea de invatat
2- nu decizi tu cine are sau nu dreptul sa posteze pe un topic.
3- op-comul ala care l-ai luat tu cu 150/200 RON e tot o chinezarie, la fel cu celelalte op-coame care se vand cu 100-120 RON. In termeni de specialitate se numeste clona. Numele e destul de sugestiv, nu cred ca e cazul sa iti explic de ce li se zice asa. Singura diferenta e ca reseller-ul tau are adaos mai mare. Iti doresc sa il merite, altfel o sa te uiti la un ecran de parametri cam ca omida la sudura...
Ca observatie: desi va exista tentatia, NU INTRA LA PROGRAMMING! Cel putin in primele 500 ore de utilizare. Limiteaza-te la a citi parametri, si a incerca sa intelegi corelatiile dintre ei. Ca altfel te vad postand pe aici pe forum "nu stiu ce am facut, da' nu mai merge masina, pls hlp" si alte de-astea
  • jgyprime
@jE:
  • Amilo2727
Ms jE de info,doar ca nu-mi place cand sunt luat la rost pe banii mei,inebunesc.
Si da,nu o sa umblu prin cine stie ce,doar ce ma intereseaza.
Usor,usor invat eu.
Ma bucur cand vad pe cineva ca sare in ajutor insa urasc cand esti luat peste picior.
  • DB77AAA
  • Mesaje scrise: 6,623
Mie-mi place discutia.
Desi tot amator ma consider, sunt extrem de entuziasmat cand aud pe cineva ca a dat reset si nu mai porneste masina 😃 . Asta e una din cele mai frecvente erori, zic eu destul de grave, care pot duce la imobilizarea masinii.
Am pe unu care a dat reset la 4 ECU, cumparat un OPcom de la okazionisti, intalnit cu multi vecini la o bere in farta blocului, hai sa va sterg erorile. Diagnoza, selecta motorul, vedea erorile, intra in programare si dadea reset la ECU, fiind convins de cel ce i-a vandut interfata ca asta e procedura corecta. Dubios ca propietarii l-au lasat si nu au incercat sa pornesca masina imediat. Cred ca mai reseta el, da nu a avut codurile de securitate la toate masinile 😂
Nu vreau sa sperii pe nimeni, insa e de preferat sa cumperi direct cu suport sau sa o iei extrem de prudent la inceput.
Apropo, din aducere aminte de acum zeci de ani, prima mea interfata de diagnoza este construita piesa cu piesa de ISO 😉 Era epoca dinozaurilior cu interfete seriale.
  • jgyprime
eu fata de multa lume de aici de pe forum sunt extrem de incepator in ceea ce priveste diagnozele...
insa pana acum nu am stricat nici o masina...
am o vorba: cand intru in programare si chiar si stergere de erori il intreb pe proprietar: "esti sigur ca vrei sa facem asta? nu imi asum nici o raspundere pentru ca nu stiu cum reactioneaza masina ta"...
daca omu zice: da, da-i mai departe si programeaza doar asa programez sau sterg erori...
altfel doar citesc erori si i le dau omului sa si le interpreteze singurel si-i zic sa le "stearga" scotamd borna de la baterie 1-2 ore...
pana acum am cateva zeci de masini pe care am facut programari cu succes (prioectoare, geamuri electrice, pilot automat, drl, chei, prezenta diverse LED-uri prin bord, etc) dar si vreo 2-3 pe care programarea a dat cu virgula, dar nu s-a stricat nimic, masinile au plecat exact cum au venit la mine...
am un set de pdf-uri si alte documentatii luate de pe unde am gdsit si eu si cand e nevoie sa programez ceva, de fata cu omul deschid documentul si facem pas cu pas cum e acolo...
daca nu am documentatie, nu fac.
si chiar daca am documentatie fac doar pe raspunderea proprietearului masinii si cu acordul lui...
