isovea
- Mesaje scrise: 21
- Masina: Astra 2006
- Cont inregistrat: 05 Nov 2014
liviu2004- Suspendat
- 2,322 mesaje
- din 28 Sep 2005
liviu2004- Mesaje scrise: 2,322
- jE
- 8,413 mesaje
- din 04 Jun 2006
jE
- Mesaje scrise: 8,413
isovea
- Mesaje scrise: 21
isovea
- Mesaje scrise: 21
- jE
- 8,413 mesaje
- din 04 Jun 2006
jE
isovea
- Mesaje scrise: 21
- 2,322 mesaje
- din 28 Sep 2005
isovea
- Mesaje scrise: 21
- 2,322 mesaje
- din 28 Sep 2005
1. Astra H nu are MID..doar TID, BID, GID si CID. Banuiesc ca tu ai BID. Ar fi bine sa postezi o poza cu display-ul..sa vedem exact ce ai.
2. Daca am inteles bine tu vrei ca pe display sa vezi si consumul instant, nu numai "range" si "consum mediu"
Daca e asa iti spun ca pe BID nu se poate. Pe GID si CID se poate dar nu cu Op-com. Se face upgrade de soft si astfel vei avea afisare pe trei linii: range, consum instant si consum mediu.
- vlad-OPC
- 1,053 mesaje
- din 23 Jan 2011
- Astra 2008 Z16XER
vlad-OPC
- Mesaje scrise: 1,053
- Masina: Astra 2008 Z16XER
- Cont inregistrat: 23 Jan 2011
isovea
- Mesaje scrise: 21
- 2,322 mesaje
- din 28 Sep 2005
isovea
- Mesaje scrise: 21
- 2,322 mesaje
- din 28 Sep 2005
isovea
- Mesaje scrise: 21
- jgyprime
- 9,951 mesaje
- din 22 Dec 2010
- Vectra 2005 Z19DT
jgyprime
- Mesaje scrise: 9,951
- Masina: Vectra 2005 Z19DT
- 2,322 mesaje
- din 28 Sep 2005
OBD-II
OBD-II is an improvement over OBD-I in both capability and standardization. The OBD-II standard specifies the type of diagnostic connector and its pinout, the electrical signalling protocols available, and the messaging format. It also provides a candidate list of vehicle parameters to monitor along with how to encode the data for each. There is a pin in the connector that provides power for the scan tool from the vehicle battery, which eliminates the need to connect a scan tool to a power source separately. However, some technicians might still connect the scan tool to an auxiliary power source to protect data in the unusual event that a vehicle experiences a loss of electrical power due to a malfunction. Finally, the OBD-II standard provides an extensible list of DTCs. As a result of this standardization, a single device can query the on-board computer(s) in any vehicle. This OBD-II came in two models OBD-IIA and OBD-IIB. OBD-II standardization was prompted by emissions requirements, and though only emission-related codes and data are required to be transmitted through it, most manufacturers have made the OBD-II Data Link Connector the only one in the vehicle through which all systems are diagnosed and programmed. OBD-II Diagnostic Trouble Codes are 4-digit, preceded by a letter: P for engine and transmission (powertrain), B for body, C for chassis, and U for network.
- alexx1402
- 1,751 mesaje
- din 17 Aug 2010
- Astra 2017 B16DTH
alexx1402
- Mesaje scrise: 1,751
- Masina: Astra 2017 B16DTH
- Cont inregistrat: 17 Aug 2010
- jE
- 8,413 mesaje
- din 04 Jun 2006
jE
