JHirlav
- Mesaje scrise: 4
- Cont inregistrat: 12 Nov 2017
- deleted-103883
- 125 mesaje
- din 20 Aug 2015
deleted-103883
- Mesaje scrise: 125
- Cont inregistrat: 20 Aug 2015
JHirlav
- Mesaje scrise: 4
JHirlav
- Mesaje scrise: 4
Am montat corect bateria, porneste foarte usor, dar am permanent acel mesaj pe bord, bateria veche m-a lasat complet, am dat de cateva ori curent de la alt autoturism pornea dupa care nu mai avea curent deloc. Pe bord nu apare nici un fel de mesaj cu voltajul. Multumesc. Bateria noua am schimbat-o ieri 11.11 2017.
- deleted-103883
- 125 mesaje
- din 20 Aug 2015
deleted-103883
JHirlav
- Mesaje scrise: 4
- mikyboy
- 5,734 mesaje
- din 08 Dec 2006
- Insignia 2014 A20TDH
mikyboy
- Mesaje scrise: 5,734
- clau70
- 3,336 mesaje
- din 11 Apr 2013
- Astra 2010 A20DTH
clau70
- Mesaje scrise: 3,336
- Masina: Astra 2010 A20DTH
Charge Indicator Operation
The instrument panel cluster illuminates the charge indicator and displays a warning message in the driver information center if equipped, when the one or more of the following occurs:
• The engine control module (ECM) detects that the generator output is less than 11 V or greater than 16 V. The instrument panel cluster receives a GMLAN message from the ECM requesting illumination.
• The instrument panel cluster determines that the system voltage is less than 11 V or greater than 16 V for more than 30 seconds. The instrument panel cluster receives a GMLAN message from the body control module (BCM) indicating there is a system voltage range concern.
• The instrument panel cluster performs the displays test at the start of each ignition cycle. The indicator illuminates for approximately 3 seconds.
Display Message: BATTERY NOT CHARGING SERVICE CHARGING SYSTEM or SERVICE BATTERY CHARGING SYSTEM
The BCM and the ECM will send a serial data message to the driver information center for the BATTERY NOT CHARGING SERVICE CHARGING SYSTEM or SERVICE BATTERY CHARGING SYSTEM message to be displayed. It is commanded ON when a charging system DTC is a current DTC. The message is turned OFF when the conditions for clearing the DTC have been met.
