agk
- Mesaje scrise: 12
- Masina: Astra 2007 Z13DTH
- Cont inregistrat: 21 Apr 2012
Am un Opel Astra H 1.3 cdti din 2006.
De un timp sesizez multe probleme la ea.
1. Uneori AC-ul pornea si se oprea cand vroia el chiar daca nu racea cum trebuie, uneori dadea are (sa zic cam la 70% rece fata de cum dadea de obicei) si se oprea, iar pornea si tot asa.
2. Uneori pronesc masina si se tureaza pana in 900-1000-1100 de turatii osciland intre acestea. Chiar si dupa 100 de km. Daca o turam in rosu si o opream dupa cand o porneam iar isi revenea 750-800 de turatii.
3. Ceva mai grav: cand am vrut sa depasesc am bagat a 2-a la 40 km/h si sa turat pana in rosu dar putere deloc. viteza ramanea constanta dar turatiile cresteau pana la rosu. chiar in orice treapta. am patit de vreo 3 ori asta. se tura in viteza ca si cum era pe liber.
O lista de erori care le are este urmatoarea:
P0622 Generator Field "F" Control Circuit Malfunction IPC (Instrument) C-021
P0683 Glow Plug Circuit Low Voltage B-038
P0683 Glow Plug Circuit Open B-038
P0621 Generator Lamp "L" Control Circuit Malfunction IPC (Instrument) C-021
P0217 Engine Overtemperature Condition Engine Cooling B-007
P1901 Particulate Filter Pressure Sensor High Voltage C-032
P1901 Particulate Filter Pressure Sensor Low Voltage C-032
P1901 Particulate Filter Pressure Sensor Hose Line Malfunction B-031
P1901 Particulate Filter Pressure Sensor High Differential Pressure B-031
P1901 Particulate Filter Pressure Sensor Low Differential Pressure B-031
P1901 Particulate Filter Pressure Sensor Pressure not Plausible with Barometric Pressure B-031
P1901 Particulate Filter Pressure Sensor High Pressure C-032
P1901 Particulate Filter Pressure Sensor Low Pressure B-031
P2003 Particulate Filter Pressure Sensor Much too High Differential Pressure C-030
P0243 Boost Pressure Valve High Voltage B-019
P0243 Boost Pressure Valve Low Voltage B-019
Rog pe oricine care a mai patit sau care stie despre ce este vorba sa ma ajute.
Multumesc.
- buldozer2
- 679 mesaje
- din 01 Feb 2011
- Astra 2014 A14NET
- Buzau
buldozer2
- Mesaje scrise: 679
- Masina: Astra 2014 A14NET
- Cont inregistrat: 01 Feb 2011
agk
- Mesaje scrise: 12
- DB77AAA
- 6,620 mesaje
- din 19 Jan 2007
- Vectra 2005 Z19DTH 200CP
- Dambovita
DB77AAA
- Mesaje scrise: 6,620
Din ce coduri ai pus acolo, reiese destul de clar ca ai probleme cu DPF, ma gamndesc ca probabil nu e acolo si nici senzorii lui.
- alex_paval
- 619 mesaje
- din 22 Aug 2009
- Signum 2005 Z19DTH
- Bacau
alex_paval
- Mesaje scrise: 619
- Masina: Signum 2005 Z19DTH
- Cont inregistrat: 22 Aug 2009
agk
- Mesaje scrise: 12
