zighy
- Mesaje scrise: 1
- Masina: Astra 2005
- Cont inregistrat: 23 Jul 2013
Fuel/Ignition (Z16XEP - Multec MT35E)
Fault codes - DTC Description
Vehicle: Opel/Vauxhall - Astra H - 2005
Car licence no:SB
U2139 - Communication with CIM (Steering column module)
- Intermittent
U2108 - CAN: No communication with ABS/TC
- Intermittent
U2104 - CAN-BUS reset counter overrun
- Intermittent
U2103 - (CAN) communication bus fault
- Intermittent
P1600 - Replace electronic control unit (ECU)
- Permanent
P1550 - Electronic throttle control reduced power
- Intermittent
P0650 - CAN: Instrument pack message fault
- Intermittent
P0230 - Fuel pump primary circuit low
- Intermittent
P0204 - Injector Circuit Malfunction - Cylinder 4
- Permanent
P0203 - Injector Circuit Malfunction - Cylinder 3
- Permanent
P0202 - Injector Circuit Malfunction - Cylinder 2
- Permanent
P0201 - Injector Circuit Malfunction - Cylinder 1
- Permanent
orice idee e bine venita
Car licence no:SB
- Intermittent
- Intermittent
- Intermittent
- Intermittent
- Permanent
- Intermittent
- Intermittent
- Intermittent
- Permanent
- Permanent
- Permanent
- Permanent
- iulian1971
- 7,083 mesaje
- din 21 Dec 2006
- Astra 2008 Z19DTH
- Ilfov
iulian1971
- Mesaje scrise: 7,083
- Masina: Astra 2008 Z19DTH
Bine ai venit.
Cred ca ai ECU busit. Nu are nimic softul.
Poti gasi rezolvare aici:
https://www.clubopel.com/viewtopic.php?t=98958
catalinpav66- Suspendat
- 759 mesaje
- din 29 Oct 2008
- Vectra 2006 z30dt
catalinpav66- Mesaje scrise: 759
- Masina: Vectra 2006 z30dt
- Cont inregistrat: 29 Oct 2008
ciprianos
- Mesaje scrise: 34
- Masina: Astra 2004 Z16XEP
- Cont inregistrat: 08 Jun 2014
