  • zighy
  • Masina: Astra 2005
  • Cont inregistrat: 23 Jul 2013
Fuel/Ignition (Z16XEP - Multec MT35E)
Fault codes - DTC Description
Vehicle: Opel/Vauxhall - Astra H - 2005
Car licence no:SB
U2139 - Communication with CIM (Steering column module)
- Intermittent
U2108 - CAN: No communication with ABS/TC
- Intermittent
U2104 - CAN-BUS reset counter overrun
- Intermittent
U2103 - (CAN) communication bus fault
- Intermittent
P1600 - Replace electronic control unit (ECU)
- Permanent
P1550 - Electronic throttle control reduced power
- Intermittent
P0650 - CAN: Instrument pack message fault
- Intermittent
P0230 - Fuel pump primary circuit low
- Intermittent
P0204 - Injector Circuit Malfunction - Cylinder 4
- Permanent
P0203 - Injector Circuit Malfunction - Cylinder 3
- Permanent
P0202 - Injector Circuit Malfunction - Cylinder 2
- Permanent
P0201 - Injector Circuit Malfunction - Cylinder 1
- Permanent
orice idee e bine venita
  • Mesaje scrise: 7,066
  • Masina: Astra 2008 Z19DTH
Bine ai venit.
Cred ca ai ECU busit. Nu are nimic softul.
Poti gasi rezolvare aici:
https://www.clubopel.com/viewtopic.php?t=98958
  • catalinpav66
  • Mesaje scrise: 759
  • Masina: Vectra 2006 z30dt
verifica punctele de masa 18 si 23, poz 739 si 741. Le gasesti in TIS. Ai nevoie doar de o tubulara de 10(strangi bine). Calculatorul nu are nimic! Strange si prinderea de la tabla pe care sunt puse astea doua.
  • ciprianos
  • Mesaje scrise: 34
  • Masina: Astra 2004 Z16XEP
  • Cont inregistrat: 08 Jun 2014
ai mai rezolvat ceva ?
