  3. Motoare diesel
  • rebotea
  • Mesaje scrise: 28
  • Masina: Vectra OPC 2003
  • Cont inregistrat: 14 Apr 2013
Hi i have changed my instrumente painel but now i have this massage and it is not working ok what do i have to do
3925 - Wrong Environment Identifier Received IPC (Instrument)
(00) - Present
U2102 - CAN-Bus (Low Speed) Maximum Configuration List Not Programmed
(0F) - Present
B2991 - Passenger Door Switch Circuit Open or High Voltage
(05) - Present
TPMs sinilzion is also presente
Thank´s
  • Mesaje scrise: 7,066
  • Masina: Astra 2008 Z19DTH
You have to reset and program IPC instrument. You`ll need both security codes.
Check and reconfigure Can Bus (Low Speed) List.
Check passenger door conector-switch.
  • rebotea
  • Mesaje scrise: 28
Thank´s
Before anything i have to get the car code without that i can´t do anything more or is there a work oround for this?
Is the door conector-switch dificult to acess becau-se the door work´s fine.
Thank´s
You need the code from IPC`s donor car and the code from your car.
If the door works ok leave it be.
  • rebotea
  • Mesaje scrise: 28
But i by the instrument painel from a person that doesn´t have the last owner code , i will get my code is it possible to learn the code?
thank´s
Only if IPC was reseted in delivery mode before dismantle.
  • rebotea
  • Mesaje scrise: 28
Ok Thank´s
When i try to force the signal with opcom like belt insert work fine , like odmetor miles , but if i dont bukle my belt sign wont came one ony the belt and the TPMS is apearing...... is it better look for another instrument painel?
Thank´s
No, find somebody who can read the IPC security code from IPC`s EEPROM. Then reset it and reprogramm it.
  • cristi_bv
  • Mesaje scrise: 344
  • Masina: Insignia 2015 A20dth
What's wrong with the original IPC?
  • rebotea
  • Mesaje scrise: 28
I don´t now how but they changed:
the airbag informacion don´t now how ( light comes on and go OFF)
B0021 - Passenger Side Airbag Squib Circuit High Resistance(0D) - Present
B0023 - Passenger Curtain Airbag Squib Circuit High Resistance(0D) - Present
the motor informacion wasen´t working
the velocity was not corrected.
  • rebotea
  • Mesaje scrise: 28
Does this cable do the work ?
http://www.chinasinoy.com/w...-airbag-1070.html
No, you need something like:
https://www.clubopel.com/viewtopic.php?t=86534
https://www.clubopel.com/viewtopic.php?t=96349
  • rebotea
  • Mesaje scrise: 28
I have OP-COM V2010 but after reset the ECU and try to conect IPC the passcode for the IPC i bought was not reset so with what ca i reset that code and chang for the ECU?
or is there a simple way?
Thank´s again
Why did you reset the ECU ? Only IPC need that.
Without IPC code, it won`t work properly.
Try to talk to CristianTM and see if he can help you read IPC security code:
https://www.clubopel.com/viewtopic.php?t=82321
  • rebotea
  • Mesaje scrise: 28
thank´s again
  • DB77AAA
  • Mesaje scrise: 6,677
Are Vectra din 2003, nu are pin in IPC din cate retin.
You have Vectra from year 2003, that not have IPC whith Pin Code.
3925 - Wrong Environment Identifier Received IPC (Instrument) - that means IPC is not fully configurated and maybe is from diferent engine.
You can't use OPcom 2010 to make good configuration, if I know good but tomorow I can check.... Maybe OPcom 2012
  • marcone1
  • Mesaje scrise: 54
  • Masina: Vectra 2002 1.8 l 122 hp
aceeasi treaba o am si eu, am schimbat ceasurile, si porneste tot decat cand vrea , mentionez ca am dat reset si dupaia program la ipc pe masina mea, am bagat si seria de sasiu in ele, daca ma puteti ajuta , nu stiu ce sa ii fac, ms
  3. Motoare diesel
