rebotea
- Mesaje scrise: 28
- Masina: Vectra OPC 2003
- Cont inregistrat: 14 Apr 2013
Hi i have changed my instrumente painel but now i have this massage and it is not working ok what do i have to do
3925 - Wrong Environment Identifier Received IPC (Instrument)
(00) - Present
U2102 - CAN-Bus (Low Speed) Maximum Configuration List Not Programmed
(0F) - Present
B2991 - Passenger Door Switch Circuit Open or High Voltage
(05) - Present
TPMs sinilzion is also presente
Thank´s
(00) - Present
(0F) - Present
(05) - Present
Thank´s
- iulian1971
- 7,066 mesaje
- din 21 Dec 2006
- Astra 2008 Z19DTH
- Ilfov
iulian1971
- Mesaje scrise: 7,066
- Masina: Astra 2008 Z19DTH
rebotea
- Mesaje scrise: 28
- iulian1971
- 7,066 mesaje
- din 21 Dec 2006
- Astra 2008 Z19DTH
- Ilfov
iulian1971
rebotea
- Mesaje scrise: 28
- iulian1971
- 7,066 mesaje
- din 21 Dec 2006
- Astra 2008 Z19DTH
- Ilfov
iulian1971
rebotea
- Mesaje scrise: 28
- iulian1971
- 7,066 mesaje
- din 21 Dec 2006
- Astra 2008 Z19DTH
- Ilfov
iulian1971
- cristi_bv
- 344 mesaje
- din 11 Mai 2008
- Insignia 2015 A20dth
cristi_bv
- Mesaje scrise: 344
- Masina: Insignia 2015 A20dth
- Cont inregistrat: 11 Mai 2008
rebotea
- Mesaje scrise: 28
I don´t now how but they changed:
the airbag informacion don´t now how ( light comes on and go OFF)
B0021 - Passenger Side Airbag Squib Circuit High Resistance(0D) - Present
B0023 - Passenger Curtain Airbag Squib Circuit High Resistance(0D) - Present
the motor informacion wasen´t working
the velocity was not corrected.
rebotea
- Mesaje scrise: 28
- iulian1971
- 7,066 mesaje
- din 21 Dec 2006
- Astra 2008 Z19DTH
- Ilfov
iulian1971
No, you need something like:
https://www.clubopel.com/viewtopic.php?t=86534
https://www.clubopel.com/viewtopic.php?t=96349
rebotea
- Mesaje scrise: 28
- iulian1971
- 7,066 mesaje
- din 21 Dec 2006
- Astra 2008 Z19DTH
- Ilfov
iulian1971
Why did you reset the ECU ? Only IPC need that.
Without IPC code, it won`t work properly.
Try to talk to CristianTM and see if he can help you read IPC security code:
https://www.clubopel.com/viewtopic.php?t=82321
rebotea
- Mesaje scrise: 28
- DB77AAA
- 6,682 mesaje
- din 19 Jan 2007
- Vectra 2005 Z19DTH 200CP
- Dambovita
DB77AAA
- Mesaje scrise: 6,682
Are Vectra din 2003, nu are pin in IPC din cate retin.
You have Vectra from year 2003, that not have IPC whith Pin Code.
3925 - Wrong Environment Identifier Received IPC (Instrument) - that means IPC is not fully configurated and maybe is from diferent engine.
You can't use OPcom 2010 to make good configuration, if I know good but tomorow I can check.... Maybe OPcom 2012
marcone1
- Mesaje scrise: 54
- Masina: Vectra 2002 1.8 l 122 hp
- Cont inregistrat: 15 Sep 2008
