- simplueu11
- 292 mesaje
- din 24 Mar 2012
- Vectra 2001 y20dth
- Mehedinti
simplueu11
- Mesaje scrise: 292
- Masina: Vectra 2001 y20dth
- Cont inregistrat: 24 Mar 2012
- cangri
- 5,412 mesaje
- din 24 Sep 2010
cangri
- Mesaje scrise: 5,412
- simplueu11
- 292 mesaje
- din 24 Mar 2012
- Mehedinti
simplueu11
- dorin-b
- 1,820 mesaje
- din 06 Sep 2007
- Astra 2000 Y20DTH
dorin-b
- Mesaje scrise: 1,820
- Masina: Astra 2000 Y20DTH
- simplueu11
- 292 mesaje
- din 24 Mar 2012
- Mehedinti
simplueu11
- dorin-b
- 1,820 mesaje
- din 06 Sep 2007
- Astra 2000 Y20DTH
dorin-b
- simplueu11
- 292 mesaje
- din 24 Mar 2012
- Mehedinti
simplueu11
- dorin-b
- 1,820 mesaje
- din 06 Sep 2007
- Astra 2000 Y20DTH
dorin-b
- simplueu11
- 292 mesaje
- din 24 Mar 2012
- Mehedinti
simplueu11
- Cipiotul
- 2,753 mesaje
- din 30 Dec 2008
- Astra 2000 Y20DTH
Cipiotul
- Mesaje scrise: 2,753
- Cont inregistrat: 30 Dec 2008
p0110 - Intake Air Temperature (IAT) Range/Performance /// Voltage High /// Voltage Low
p0100 - Critical system malfunction 1 (refer to checking procedure: trouble code description) - Mass air is less than 0.2 g/stroke. Engine speed is greater than 3100 rpm. Effect: Exhaust gas recirculation is limited to 1 % /// Mass Air Flow Sensor Circuit High/Low Input /// Mass Air Flow Sensor Voltage Supply Circuit High/Low Input
p0725 - Critical system malfunction 1 (refer to checking procedure: trouble code description) = Change of boost pressure detected. Engine speed is less than 1 rpm /// Engine-Speed Sensor Input Circuit Incorrect Signal /// Engine-Speed Sensor Input Circuit Signal Range/Performance(Overspeed) /// Engine-Speed Sensor Input Circuit no Signal
p1335 - Injection Pump: no Engine Speed Input Signal from Control Unit
p1110 - Variable Intake Air/Variable Swirl (Diesel) Circuit Open /// Variable Intake Air/Variable Swirl (Diesel) Circuit Open
p0400 - Exhaust Gas Recirculation Circuit High Input / Circuit Open => asta era de la furtunasul spart ...
codul la care apare si /// inseamna ca are mai multe cauze si defectul se poate manifesta in mai multe feluri...
- simplueu11
- 292 mesaje
- din 24 Mar 2012
- Mehedinti
simplueu11
Astazi am mai facut un mic test ....codurile aratate sunt :
p0725
p1335
p0110
p0100
Primele 2 vor disparea maine dupa schimbarea senzorului de turatie (sa speram ) .
Iar celalalte 2 momentan nu ma incurca dar o sa fac si o curatare debitmetrului + galeria de admisie .
Apoi speram sa nu mai fie nici un fel de probleme .
STIMA SI RESPECT PENTRU POSESORI DE OPEL !
p0725
p1335
p0110
p0100
- simplueu11
- 292 mesaje
- din 24 Mar 2012
- Mehedinti
simplueu11
- simplueu11
- 292 mesaje
- din 24 Mar 2012
- Mehedinti
simplueu11
- dorin-b
- 1,820 mesaje
- din 06 Sep 2007
- Astra 2000 Y20DTH
dorin-b
- dancuciureanu
- Moderator
- 16,465 mesaje
- Agila 2001 Z10XE + Z12XE
dancuciureanu
- Mesaje scrise: 16,465
- micky001
- 1,319 mesaje
- din 26 Dec 2007
- Omega 1997 x20se
micky001
- Mesaje scrise: 1,319
- Masina: Omega 1997 x20se
- Cont inregistrat: 26 Dec 2007
Subscriu Dancuciureanu.Am avut probleme(eroare senzor crankshaft),l-am schimbat cu unul nou,dar mai ieftin,rezultatul... pornire greoaie,vre-o patru secunde de invartit motorul...Am cumparat unul original,dupa ce m-am lamurit ca nu trebuie sa te joci cu ieftineala si totul a fost OK,sfert de cheie,erori disparute...Naspa totusi ca ieftineala m-a costat demontarea de 2 ori a curelei accesorii,fuliei,capacului distributie...
- simplueu11
- 292 mesaje
- din 24 Mar 2012
- Mehedinti
simplueu11
dancuciureanu a scris:Pune senzor crankshaft original si debitmetru original.
Senzor NOU original , debitmetrul nu l-am schimbat doar l-am verificat si nu mi se pare a avea probleme .... am inlocuit si cu altu de pe o vectra asemanatoare , aceleasi simptome ... de la ce ar putea fii .... nu pot sa imi dau seama ....
