- Stefan_BC
- 2,652 mesaje
- din 19 Oct 2009
- Zafira 2008 Z19DT
- Bacau
Stefan_BC
- Mesaje scrise: 2,652
- Masina: Zafira 2008 Z19DT
- Cont inregistrat: 19 Oct 2009
stiam ca la masinile mai noi din 2006 incoace nu se poate nici macar cu tech2-ul,la celelalte se tinea apasat butonul de inchidere usi apasat timp de 10 sec si gata usile se inchideau la plecarea de pe loc
dar uitati ce am gasit ,poate incearca cineva care are tech2 si ne spune si noua daca merge activata functia asta si la masinile de dupa 2006
How to:
Connect and turn on Tech 2 as usual.
Select the following in order:
-Diagnostics
-Model Year
-Astra H
-F4 Body
-REC Rear electrical Centre (scroll down)
-Turn on Ignition - confirm
-REC Rear Electrical centre - confirm
-F5 Programming
-Program variant configuration
-Enter security code (PIN) - confirm
-Check that the equipment list is accurate for vehicle specification. In particular, check that Anti Theft Warning System (ATWS) and Parking Heater are shown as "Not Present", otherwise modify to "Not Present". Note that "invalid" must also be modified to "not present".
-Speed dependant locking (scroll down)
-Modify to present
-Program
-Confirm program successful
Exit as usual
How to:
-Diagnostics
-Model Year
-Astra H
-F4 Body
-F5 Programming
-Modify to present
-Program
Exit as usual
- Edwin
- 5,986 mesaje
- din 27 Nov 2008
- Zafira 2006 z19dt
- Bistrita-Nasaud
Edwin
- Mesaje scrise: 5,986
- Masina: Zafira 2006 z19dt
- Stefan_BC
- 2,652 mesaje
- din 19 Oct 2009
- Zafira 2008 Z19DT
- Bacau
Stefan_BC
- bbmt
- 512 mesaje
- din 29 Aug 2007
- Astra 2010 Z17DTJ
- Timis
bbmt
- Mesaje scrise: 512
- Masina: Astra 2010 Z17DTJ
- Cont inregistrat: 29 Aug 2007
- Edwin
- 5,986 mesaje
- din 27 Nov 2008
- Zafira 2006 z19dt
- Bistrita-Nasaud
Edwin
- Stefan_BC
- 2,652 mesaje
- din 19 Oct 2009
- Zafira 2008 Z19DT
- Bacau
Stefan_BC
- bbmt
- 512 mesaje
- din 29 Aug 2007
- Astra 2010 Z17DTJ
- Timis
bbmt
- Stefan_BC
- 2,652 mesaje
- din 19 Oct 2009
- Zafira 2008 Z19DT
- Bacau
Stefan_BC
- 89dam
- 1,152 mesaje
- din 03 Feb 2008
- Astra 2006 z16xep
89dam
- Mesaje scrise: 1,152
- Masina: Astra 2006 z16xep
- Cont inregistrat: 03 Feb 2008
- Edwin
- 5,986 mesaje
- din 27 Nov 2008
- Zafira 2006 z19dt
- Bistrita-Nasaud
Edwin
89dam a scris:Stimabililor pana la urma cum fac sa se blocheze usile la plecarea de pe loc la o astra h caravan din 10/2005 adica masina mea
Incearca sa tii apasat pe butonul de inchidere de pe consola centrala cateva secunde. Daca se aude un "ding" atunci ai noroc: s-a activat functia. Daca nu, atunci nu se poate ativa doar cu modul suplimentar. Numai bine.
- 89dam
- 1,152 mesaje
- din 03 Feb 2008
- Astra 2006 z16xep
89dam
Adica tin pur si simplu apasat pe butonul de pe consola apasat cateva secunde?
Nu trebuie alta combinatie, gen cheia in contact la prima pozitie, apasat pe butonul de inchidere usi - consola concomitent cu cel de inchidere usi - cheie apoi piciorul drept incrucisat cu cel stang si apasat pe acceleratie cu stangu iar cu dreptul pe ambreiaj la orele serii, imediat dupa ce a fost luna plina cu doua seri inainte si intre al treilea si al patrulea latrat al cainelui vecinului si mai mult de atat sa nu aiba masina parcursi in ziua aia mai mult de 13,13 km?
Si daca nu bipaie de x ori atunci nu ai noroc si tre sa mergi cu masina la Tech2 ori la reprezentanta, unde le curg balele din gura alora doar daca ii intrebi care e diferenta dintre bid si gid ori la cineva care se pricepe si iti cere pe o chestie din asta de iti intra chilotii in (trei litere) plus unghiile de la doua degete in gat si atunci afirmi in gandul ta "ce mi-a trebuit? de ce nu am putut sa stau eu linistit si sa nu fiu atat de tipicar / exigent / fixist / nebun incat sa fac treaba asta, ce m-a durea mana daca apas pe consola de la bord sa inchid usile manual?"
Dar deh asta e, asa suntem pardon sunt, imi doresc masina daca se poate cu comanda vocala sa consume 4 picaturi la 100 de km, sa nu imi stea nimeni in fata chiar daca e Passat, BMW, audi etc (clasa lux)!
Hai ca am aberat destul si tocmai ca m-am trezit, in continuare am sa tin la opelul meu drag!
- Edwin
- 5,986 mesaje
- din 27 Nov 2008
- Zafira 2006 z19dt
- Bistrita-Nasaud
Edwin
Am verificat astãzi cu Tech2 dacã se poate activa funcþia urmând paºii descrisi de @Stefan_BC. Raspunsul: nu se poate activa Nu se poate da comanda "Present" in dreptul acestei funcþii deoarece acolo nu este "Not present" ci "Not available". La apasarea butonului "SET" pe Tech 2 apare eroarea: "programing failed". Aºadar, s-a adeverit cã acesta functie a fost "retrasã" de cei de la Opel.
- Stefan_BC
- 2,652 mesaje
- din 19 Oct 2009
- Zafira 2008 Z19DT
- Bacau
Stefan_BC
- B74LEL
- 498 mesaje
- din 11 Sep 2008
- Astra 2008 Z17DTL
B74LEL
- Mesaje scrise: 498
- Masina: Astra 2008 Z17DTL
- Cont inregistrat: 11 Sep 2008
Salut ,
Am o idee in legatura cu problema asta .Nu se poate face ceva electronic care sa citeasca viteza sau dupa un anumit timp sa dea comanda la inchiderea centralizata pentru a inchide usile ? Mi se pare ceva realizabil . Pilotul automat se activeaza la o anumita viteza .La Megane se inchid usile tot la viteza .Se poate face ceva similar cu avertizarea cu avarii la franare brusca . In loc sa se aprinda avariile sa dea comanda la inchiderea centralizata . Poate mai vin alti electronisti pasionati .
Bafta,
Bafta,
- Stefan_BC
- 2,652 mesaje
- din 19 Oct 2009
- Zafira 2008 Z19DT
- Bacau
Stefan_BC
- ionut4683
- 230 mesaje
- din 04 Nov 2008
- Corsa 2005 Z13DT
- Bacau
ionut4683
- Mesaje scrise: 230
- Masina: Corsa 2005 Z13DT
- Cont inregistrat: 04 Nov 2008
- Edwin
- 5,986 mesaje
- din 27 Nov 2008
- Zafira 2006 z19dt
- Bistrita-Nasaud
Edwin
- craetos
- 328 mesaje
- din 03 Sep 2009
- Astra 2002
- Gorj
craetos
- Mesaje scrise: 328
- Masina: Astra 2002
- Cont inregistrat: 03 Sep 2009
- Edwin
- 5,986 mesaje
- din 27 Nov 2008
- Zafira 2006 z19dt
- Bistrita-Nasaud
Edwin
- bx3m
- 827 mesaje
- din 25 Mai 2009
- Vectra 1997 X18XE
bx3m
- Mesaje scrise: 827
- Masina: Vectra 1997 X18XE
- Cont inregistrat: 25 Mai 2009
