paulista
- Mesaje scrise: 75
- Masina: Zafira 2001 Z16XE
- Cont inregistrat: 22 Nov 2008
- gigi haios
- 240 mesaje
- din 15 Feb 2008
- Astra 2007 Z17dtl
gigi haios
- Mesaje scrise: 240
- Masina: Astra 2007 Z17dtl
- Cont inregistrat: 15 Feb 2008
- petrecila
- 1,096 mesaje
- din 25 Apr 2007
- Bacau
petrecila
- Mesaje scrise: 1,096
- Cont inregistrat: 25 Apr 2007
In niciun caz. Vascozitatile trebuie respectate chiar daca producatorii sunt diferiti (si aici cu indulgenta).
LE Adica daca ai in motor 5w40 tot de ala pui pana faci din nou schimbul. Vascozitatea uleiului din motor trebuie respectata, altfel face spuma sau alte minuni, ungerea devenind precara si e pacat.
- PALLL
- 482 mesaje
- din 01 Apr 2009
- Astra 1995 1,6 16v x16xel
PALLL
- Mesaje scrise: 482
- Masina: Astra 1995 1,6 16v x16xel
- Cont inregistrat: 01 Apr 2009
WHH
- Mesaje scrise: 54
- Masina: Astra 2002 z20let
- Cont inregistrat: 06 Feb 2008
Aceeasi nedumerire am avut-o si eu. Uite mai jos un pasaj dintr-un interviu cu un nene pe nume John Rowland, care a fost chief R&D Chemist for Fuchs/Silkolene for many years and previously developed ahead of their time ester based oils for the RR Jet industry. Banuiesc ca raspunsul de mai jos l-a dat pe baza experintei pe care o are in domeniu:
"If you need to top up your engine oil, how important is it to use exactly the same brand and type?
Not very important at all. Unfortunately, due to ‘arse covering’ reasons we cannot print this advice on the can! Although officially all manufacturers advise against mixing different makes and grades, in fact there is very little chance of any harm being done, even if one is a mineral 20W/50 and the other is a 5W/30 synthetic. Obviously, avoid this if you can, but do not panic if there’s no other alternative. Just don’t mix 2 stroke and 4-stroke oil!"
Alegerea ramane a ta.
paulista
- Mesaje scrise: 75
Daca atunci cand schimbati tipul de ulei la masina, credeti ca intodeauna
se curata motorul cu solutie ( nu stiu cum se numeste ) si numai dupa accea se pune noul ulei ?
Intodeauna ramane 300-400 ml din uleiul vechi care se amesteca cu cel nou .
Eu oricum trebuie sa trec pe un ulei mai vascos datorita Km acumulati,
iar cu uleiul din motor am in jur de 10 000 si peste putin timp trebuie sa-l schimb. AM sa ma risc
- BuBuFaM
- 970 mesaje
- din 20 Jun 2008
- Corsa 2001 Z10XE
- Timis
BuBuFaM
- Mesaje scrise: 970
- Masina: Corsa 2001 Z10XE
- Cont inregistrat: 20 Jun 2008
paulista
- Mesaje scrise: 75
Am mai comletat cu mai mult de 1L pana acum ( motor 1,6 , 1L cumparat + ce mi-a ramas in bidon cand am facut schimbul ) , zic ca ar mai merge un 2-3000 , tinand cont ca in carte zice de 15 000 KM.
Vreau sa trec pe un ulei mai gros, dar mai spre primavara,( uleiul subtire - pt timp rece ) de asta nu as mai da 30 lei pt alt bidon
- BuBuFaM
- 970 mesaje
- din 20 Jun 2008
- Corsa 2001 Z10XE
- Timis
BuBuFaM
paulista
- Mesaje scrise: 75
