kata-san
- Mesaje scrise: 38
- Cont inregistrat: 21 Jul 2005
A existat vreo versiune de motor 1,8 cu puterea asta sau e vorba doar de un chiptuning? si daca e tunat motorul, stie cineva daca sunt probleme de fiabilitate? nu de alta, dar de la 115 CP la 140 CP e totusi ceva..... 😕
Ultima modificare făcută de kata-san la Mar 08 Nov, 2005 9:14 pm, modificat de 2 ori în total
- VIPER
- 306 mesaje
- din 22 Sep 2004
VIPER
- Mesaje scrise: 306
- Cont inregistrat: 22 Sep 2004
Engine Specification
Engine, location: Front, transverse in front of axle, 7º 50' forward inclined
Cooling system: Liquid, sealed circuit
Cylinders, number: 4
Bore (mm) 80.5
Stroke (mm): 88.2
Displacement (cc): 1796
Compression ratio: 10.5: 1
Engine, type: In line; 5 main bearings
Cylinder block/ head, material: Cast iron/ aluminium
Camshaft (s), location: 2 overhead (DOHC), driven by toothed belt
Valve train: Hydraulic bucket tappets
Valve, arrangement: v; 4 per cylinder
Valve, adjustment: Automatic - hydraulic
Fuel system: Sequential multi point fuel injection
Ignition system: Electronic ignition map, ignition coil direct to spark plug
Fuel pump: Electric, in tank
Emission control system: 3 - way cat. conv. with 2 oxygen sensors
Output (kW/hp CEE at 1/min): 103/ 140 at 6300
Specific power (kW/l; hp/l): 57.3; 78.0
Max. torque (Nm at 1/ min): 175 at 3800
Specific torque (Nm/litre): 97.4
Mean effective pressure at max. power/ max. torque (kPa): 1092.4/ 1225.0
Average piston speed (m/ s): 18.5
Engine oil, capacity (l): 4.5
Cooling capacity (l): 5.9
Battery 12 V, capacity (Ah): 55
Alternator 14.2 V, capacity (W): 1420
Max. service interval: 20,000 miles or 1 year
Emission compliance: Euro 4
Engine mass (kg): tba
Charger system: n/a
Max. boost pressure (bar): n/a
Din pacate nu-i stiu codul...
- zafirul
- 1,442 mesaje
- din 22 Apr 2004
- Zafira 2001 Z18XE
zafirul
- Mesaje scrise: 1,442
- Masina: Zafira 2001 Z18XE
- Cont inregistrat: 22 Apr 2004
pe zafira B (sa-i zicem asa...) exista motorizarea 1.8 140 CP.
citind ce-ai scris tu ca e euro4 si tinind cont de
a) 1.8 ecotec 16 valve z18xe- adeka motoru meu e euro 4
b) nenea voinea (de pe vw forum ) care face chiptuning poate duce motoru' de la pct. a la 139 CP
c) kata-san zice de o vectra din 97 😶
atunci eu as trage concluzia ca motorul respectiv e oareshcum tunat.... 😂 😂 😂
ar mai fi totusi o mica ciudatenie- eu am acum 170Nm; daca-as face chip tuning s-ar duce la 140CP (ma rog, aia 139 si ceva) dar cuplul ar urca -cel putin teoretic- la 186Nm. ma mira atunci datele pe care le-ai pus.. doar 175??..
- LEXXX
- 1,019 mesaje
- din 25 Jan 2005
- Astra 2004 Z18XE
LEXXX
- Mesaje scrise: 1,019
- Masina: Astra 2004 Z18XE
- Cont inregistrat: 25 Jan 2005
- VIPER
- 306 mesaje
- din 22 Sep 2004
VIPER
Bestie
- Mesaje scrise: 69
- Cont inregistrat: 06 Aug 2004
Daca da, o stiu eu. Are un 1.8 16v, si are ~140 cp. Nu au fost masurati dar asa stiu de la fostul proprietar. Care a dat-o cam acum 2 luni. Voi unde ati vazut-o? Unde este anuntul cu ea?
kata-san
- Mesaje scrise: 38
Bestie
- Mesaje scrise: 69
kata-san
- Mesaje scrise: 38
"opel vectra berlina 2,0 I 140 CP argintiu,
rulaj 116.000 Km (yeah right), ..pe scurt toate dotarile + controlul tractiunii+ folie omologata+ jante si pneuri noi, tinuta in garaj...etc stare exceptionala, bla, bla..... domnul este din Constanta si se recomanda Simion, are adresa de mail "siticonstruct" ...s-ar putea sa fie pe firma masina....
Bestie, crezi ca e cea la care te referi tu?
kata-san
- Mesaje scrise: 38
kata-san
- Mesaje scrise: 38
Bestie
- Mesaje scrise: 69
- maiandrei
- 4,710 mesaje
- din 20 Dec 2004
- Insignia 2018 B20DTH
maiandrei
- Mesaje scrise: 4,710
- LEXXX
- 1,019 mesaje
- din 25 Jan 2005
- Astra 2004 Z18XE
LEXXX
- zafirul
- 1,442 mesaje
- din 22 Apr 2004
- Zafira 2001 Z18XE
zafirul
am din fabrica 125... 😂 😂
cresterea la benzinare -se spune- e 10-12%
si atunci ma incadrez in procente...
ai mai postat tu pe undeva chestia asta, vezi ca au existat 2 modele de motoare de 1.8 (cel putin la zafira) unul de 116 si altul de 125...
mi se pare ca mai recent l-au cam "degradat" si l-au facut 122 pe asta din urma; asa am vazut pe niste oferte de vectra C si parca si zafira
(insa nu zafira B; facelift -cum a zis viper 👽)
Bestie
- Mesaje scrise: 69
- LEXXX
- 1,019 mesaje
- din 25 Jan 2005
- Astra 2004 Z18XE
LEXXX
Daca nu ma insel e vorba de Z18XEL (116cp) si Z18XE (125cp), prezente de altfel si pe Astra si pe Vectra B iar Z18XE portat si pe Vectra C. XEL a fost primul aparut pe piata dintre acestea doua, in 2000 a aparut Z18XE, motoarele coexistand in oferta Opel pana prin 2002. Daca ma insel va rog corectati-ma.
Bestie
- Mesaje scrise: 69
G_e_O
- Mesaje scrise: 4
- Cont inregistrat: 21 Sep 2005
Bestie
- Mesaje scrise: 69
