BOA
- Mesaje scrise: 19
- Masina: Astra 2011
- Cont inregistrat: 09 Aug 2006
daca cineva dintre voi a mai demontata o oglinda electrica (de la un Corsa C) va rog sa-mi spuneti ce/cum se face.....sau poate aveti un manual de service de Corsa C in care sa fie explicata si kestia asta.
Merci aniticipat.Bafta!
P.S. : orice manual de service pt Corsa C este super-binevenit 😃
cretu-v
- Mesaje scrise: 43
- Masina: Astra 2000 y 17dt
- Cont inregistrat: 11 Apr 2006
BOA
- Mesaje scrise: 19
Doar ca mi-e mila sa trag asa de tare de acel triunghi de plastic si ma gindeam la o metoda mai "blanda" de a demonta oglinda.Oare se poate demonta tot panoul interior al usii ,dupa care acel triunghi se scoate mai usor?
Am cautat pe net un manual de service de Corsa C dar inca nu am gasit...eventual in RO de cumparat de undeva.
- dr_dumi
- 144 mesaje
- din 26 Jan 2006
dr_dumi
- Mesaje scrise: 144
- Cont inregistrat: 26 Jan 2006
BOA
- Mesaje scrise: 19
- eugen
- 121 mesaje
- din 11 Jul 2006
- Astra 2001 Z18XE
eugen
- Mesaje scrise: 121
- Masina: Astra 2001 Z18XE
- Cont inregistrat: 11 Jul 2006
cretu-v
- Mesaje scrise: 43
BOA
- Mesaje scrise: 19
Si merci de sugestiile date, ca au fost folositoare.
zsolth83
- Mesaje scrise: 18
- Masina: Astra 2004 Z17DTL
- Cont inregistrat: 14 Feb 2008
- strutzzy
- 236 mesaje
- din 19 Jul 2007
- Corsa 2008 Z14XEP
strutzzy
- Mesaje scrise: 236
- Masina: Corsa 2008 Z14XEP
- Cont inregistrat: 19 Jul 2007
Mirror assembly
1 Unclip the exterior mirror inner trim panel from the door, on manually-adjusted mirrors detach the knob from the adjustment lever (see illustration).
2 Disconnect the wiring connector from the speaker in the trim panel (see illustration).
3 On electrically-operated mirrors, disconnect the wiring connector to the mirror assembly.
4 Undo the three retaining bolts, and remove the mirror assembly from the outside of the door (see illustrations).
5 Refitting is a reverse of the removal procedure.
Mirror glass
6 While pressing against the top face of the mirror, insert a wide plastic or wooden wedge between the lower edge of the mirror glass and mirror housing, and carefully prise the glass from its balljoints (see illustrations).
Take great care when removing the glass; do not use excessive force, as the glass is easily broken (use a rag or wear thick gloves, particularly if removing an already-broken mirror).
7 Remove the glass from the mirror. Where applicable, disconnect the wiring connector from the mirror heating element as it become accessible.
8 When refitting, carefully clip the glass back into position, ensuring that it is correctly located on each of its balljoints (see illustration).
Mirror motor
9 Remove the mirror glass as described above.
10 Undo the three screws and remove the motor assembly, disconnecting its wiring connectors as they become accessible.
11 Refitting is the reverse of removal.
Mirror cover
12 Fold the mirror in partially, then carefully unclip the cover from the mirror housing
13 Refitting is the reverse of removal.
bastard
- Mesaje scrise: 95
- Masina: Corsa 2002 z12xe 16v
- Cont inregistrat: 14 Sep 2007
Corbu'
- Mesaje scrise: 28
- Masina: Corsa 2003 1.2 75CP Z12XE
- Cont inregistrat: 06 Dec 2007
M-am uitat un pic la cum e prinsa, cochilia oglinzii pare a avea la baza o bila ce se pivoteaza intr-un suport (ceva in genul unei articulatii umane).
Cochilia nu este rupta, dar este rupt suportul ala ce face parte din triunghiul negru nevopsit pus pe geamul lateral. A desfacut cineva oglinda, pot shimba numai baza sau trebuie schimbata cu totul? Sla baza ce sustine bila cochiliei, din cate vad nu e dintr-o bucata ci este o portiune mica ca un dreptunghi, dar nu imi dau seama cum vine ala prins in suport.
Help !
moshwu90
- Mesaje scrise: 7
- Masina: Corsa 2004
- Cont inregistrat: 12 Mai 2008
Corbu'
- Mesaje scrise: 28
- kalu
- 437 mesaje
- din 18 Oct 2007
- Corsa 2004 z13dt
kalu
- Mesaje scrise: 437
- Masina: Corsa 2004 z13dt
- Cont inregistrat: 18 Oct 2007
Corbu'
- Mesaje scrise: 28
G3t_Burn
- Mesaje scrise: 17
- Masina: Corsa 2005 1.2 twinport
- Cont inregistrat: 18 Mai 2008
- iuliusdobre
- 67 mesaje
- din 28 Nov 2006
- Vectra 1997 X 20DTL
- Spania
iuliusdobre
- Mesaje scrise: 67
- Masina: Vectra 1997 X 20DTL
- Cont inregistrat: 28 Nov 2006
- SorinXP
- 590 mesaje
- din 27 Aug 2007
- Astra 2006 z19dt
SorinXP
- Mesaje scrise: 590
- Masina: Astra 2006 z19dt
- Cont inregistrat: 27 Aug 2007
Corbu'
- Mesaje scrise: 28
M-am hotarat sa repar si haionul spate un pic infundat, am pus impreuna cu oglinda si asa scap cu doar 100 EU dati in loc de 200 Eu (2 evenimente).
