  • marius_cret
  • Mesaje scrise: 56
  • Masina: Vectra 2001 z16xe
  • Cont inregistrat: 13 Jan 2008
Am o mica nedumerire. Poate ma ajutati voi. Am schimbat recent kitul de ambreaj si atunci cand am luat-o de la mecanic mi-a spus sa o incerc. Dupa cateva ture am tras frana de mana si am vrut sa plec cu demaraj dar spre surprinderea mea tragea dar nu scartaiau rotile.Am intrebat mecanicul si el mi-a zis ca se aseaza dupa 1,2000 km. Am facut 1500 km si tot asa cand plec dupa loc nu scartaie rotile sub nici o forma, desi am fugit cu 180 km/ h fara probleme. A mai patit cineva asa ceva. Ce parere aveti este o problema sau nu?
  • DB77AAA
  • Mesaje scrise: 6,677
nu cumva ai TC?
  • marius_cret
  • Mesaje scrise: 56
Este posibil dar nu sunt sigur.Cand am intrat intro curba cu mare viteza am simtit ceva,ca se aseza masina singura ceva ca si cum ar fi mers abs singur sau asa ceva.Dar are vreo legatura TC cu demarajul la masina,adica nu permite sa demareze cu scartait?
  • murzick
  • Mesaje scrise: 1,007
  • Masina: Vectra 2001 Z18XE
marius_cret, ai buton TC in bord?
Electronic Traction Control
In modern vehicles, traction-control systems utilize the same wheel-speed sensors employed by the antilock braking system. These sensors measure differences in rotational speed to determine if the wheels that are receiving power have lost traction. When the traction-control system determines that one wheel is spinning more quickly than the others, it automatically "pumps" the brake to that wheel to reduce its speed and lessen wheel slip. In most cases, individual wheel braking is enough to control wheel slip. However, some traction-control systems also reduce engine power to the slipping wheels. On a few of these vehicles, drivers may sense pulsations of the gas pedal when the system is reducing engine power much like a brake pedal pulsates when the antilock braking system is working.
  • marius_cret
  • Mesaje scrise: 56
M-am intors din drum sa scriu ca mi-am dat seama ca am scris o prostie.TC nui tot una cu ESP,desi am avut pe mana atatea masini niciodata nu ma pasionat functiile lor ca nu ma gandeam vreodata sa am si eu Razz .
Daca tot v-am deranjat cu problema mea spunetimi si mie va rog ce inseamna in bord un martor ca un soare cu un S inauntrul lui(ce functie are,ce detecteaza) si mai am un semn care este greu de descris ca doua mingi ovale cu codite legate intre ele.
  • murzick
marius_cret, ai cutie automata? Daca da, atunci martorul "ca un soare cu un S inauntru" cred semnifica regimul sport al cutiei automate.
  • marius_cret
  • Mesaje scrise: 56
NU este manuala!Inseamna ca este standard pentru toate si celalalt semn am inteles de la cineva cu vw ca ar fi de parte electrica(un fir incurcat asa arata martorul din bord).
