  • LIacob144
  • Mesaje scrise: 9
  • Cont inregistrat: 16 Mai 2022
Buna seara. Ma aflu in Franta cu masinuta mea si nu reusesc sa gasesc la magazine placute de frana fata si tamburi spate la nici un magazin frantuzesc.
Eu nu stiu ce tip de placute a avut masina si as dori sa imi cumpar singur online pt ca francezii nu sunt gasesc nimic.
Ma intereseaza ceva nu prea scump dar nici prea ieftin si nu stiu ce dimensiuni sa cumpar. Multumesc pt ajutor.
MODEL: Opel Astra G Clasic 2009 T98N8/HX11
MOTOR: Z16XEP
  • Mesaje scrise: 7,149
Cu un VIN încercãm sã rezolvãm...
  • LIacob144
  • Mesaje scrise: 9
VIN: W0L0TGF699G015199
1) Discuri frânã fațã 5 69 059 9117677 SET,DISC,256 X 24 MM,FRONT BRAKE,VENTILATED (PRODUCTION NO. 90497879) cu echivalențe:
Brake Disc 17210 FEBI BILSTEIN
Brake Disc 1815203629 sbs
Brake Disc 203629 NK
Brake Disc 24.0124-0152.1 ATE
Brake Disc 24.0324-0152.1 ATE
Brake Disc 313629 NK
Brake Disc 313629 sbs
Brake Disc 3815203629 sbs
Brake Disc 424152 ATE
Brake Disc 430 1482 00 ZIMMERMANN
Brake Disc 430.1482.20 ZIMMERMANN
Brake Disc 562069B BENDIX
Brake Disc 562069BC BENDIX
Brake Disc 562069J JURID
Brake Disc 562069JC JURID
Brake Disc 569059 OPEL
Brake Disc 615 521 6014 MEYLE
Brake Disc 6155216014PD MEYLE
Brake Disc 812024126 TRISCAN
Brake Disc 89004800 TEXTAR
2) Plãcuțe frânã fațã
a. 7X 16 05 000 9195607 SET,FRICTION PADS,BRAKE,ASBESTOS FREE (NLS.- USE 93171035 16 05 070) cu echivalențe:
rake Pad Set, disc brake 025 230 6317 MEYLE
Brake Pad Set, disc brake 025 230 6317/PD MEYLE
Brake Pad Set, disc brake 05P698 LPR
Brake Pad Set, disc brake 0684.02 REMSA
Brake Pad Set, disc brake 0 986 424 456 BOSCH
Brake Pad Set, disc brake 0 986 495 223 BOSCH
Brake Pad Set, disc brake 10289 OPTIMAL
Brake Pad Set, disc brake 13.0460-7115.2 ATE
Brake Pad Set, disc brake 13.0470-7115.2 ATE
Brake Pad Set, disc brake 1501223618 sbs
b. 7X 16 05 034 9195144 SET,FRICTION PADS,BRAKE,ASBESTOS FREE (AFTERMARKET SPECIFICATION) cu echivalențe:
Brake Pad Set, disc brake ADB3584 COMLINE
Brake Pad Set, disc brake ADZ94228 BLUE PRINT
Brake Pad Set, disc brake BBP1563 BORG & BECK
Brake Pad Set, disc brake BP983 QUINTON HAZELL
Brake Pad Set, disc brake CBP3584 COMLINE
Brake Pad Set, disc brake FDB1293 FERODO
Brake Pad Set, disc brake GDB1351 TRW
Brake Pad Set, disc brake JCP1293 JURATEK
Brake Pad Set, disc brake LP1673 DELPHI
Brake Pad Set, disc brake MDB1908 MINTEX
Brake Pad Set, disc brake P59030 BREMBO
Brake Pad Set, disc brake PA1174 Brake ENGINEERING
Brake Pad Set, disc brake PAD1022 APEC braking
Brake Pad Set, disc brake 0006.60 REMSA
Brake Pad Set, disc brake 0006 60 KAWE
Brake Pad Set, disc brake 0007.00 METZGER
3. Discuri frânã spate 21X 5 69 111 9196587 KIT,REAR BRAKE DISC,240 X 10 MM (PRODUCTION NO. 24432189) cu echivalențe:
Brake Disc 92092000 TEXTAR
Brake Disc 92092003 TEXTAR
Brake Disc 955823 Brake ENGINEERING
Brake Disc 98200092001 TEXTAR
Brake Disc ADC1106 COMLINE
Brake Disc BDC4815 QUINTON HAZELL
Brake Disc BDC4815P QUINTON HAZELL
Brake Disc BG3403 DELPHI
Brake Disc BS-5700 OPTIMAL
Brake Disc DDF1043 FERODO
Brake Disc DDF1043-1 FERODO
Brake Disc DDF1043C-1 FERODO
Brake Disc DF4050 TRW
Brake Disc DI955823 Brake ENGINEERING
Brake Disc DSK297 APEC braking
Brake Disc LVBE142 MOTAQUIP
Brake Disc MDC1051 MINTEX
Brake Disc O1421P LPR
Brake Disc VAU102 JURATEK
Brake Disc 01.17.42.121036 ST-TEMPLIN
Brake Disc 08.7626.75 BREMBO
Brake Disc 14.0447 PEX
Brake Disc 14.0447N PEX
Brake Disc 142.495 CAR
Brake Disc 15372 METZGER
Brake Disc 15372 AP
Brake Disc 15858 MAPCO
4) Plãcuțe frânã spate
a. sistem Bosch 4X 16 05 093 9198598 SET,FRICTION PADS,BRAKE,ASBESTOS FREE,REAR BRAKE DISC CALIPER cu echivalențe:
b. sistem Lucas 16X 16 05 995 93179164 SET,FRICTION PADS,BRAKE,ASBESTOS FREE,REAR BRAKE DISC CALIPER (NLS.- USE 93169143 16 05 625).
Poți sã folosești autodoc.co.uk ptr achiziții, dar și ptr echivalare piese, etc...
  • ahappyuser
  • Mesaje scrise: 6,772
@LIacob144
Fix ca la catalog, nimic de zis in plus... cam asta e puterea unui forum monomarca (prin contributia membrilor ce apartin).
Si as zice (fara sa gresesc) ca acum chiar ai de unde alege. 😊 😊 😊
  • LIacob144
  • Mesaje scrise: 9
Multumesc foarte mult pt ajutor!
Ptr puțin...ar trebui sã reușești...succes!
O singurã observație: ziceai de tamburi spate, dar feru” ãsta pare dotat cu discuri...poți sã ne lãmurești?
  • LIacob144
  • Mesaje scrise: 9
pe spate franele sunt cu tamburi.
Se pare cã e o inadvertențã în catalogul folosit de mine...se mai întâmplã...
