- DDanyel364
- 3 mesaje
- din 05 Jan 2022
DDanyel364
- Mesaje scrise: 3
- Cont inregistrat: 05 Jan 2022
MODEL: Opel Astra H 2005
MOTOR: 77kv 105 16 16v
CODURI EROARE: P0320
- alex_arhire
- 988 mesaje
- din 10 Sep 2006
- Astra 2001 Z20LET
alex_arhire
- Mesaje scrise: 988
- Masina: Astra 2001 Z20LET
- Cont inregistrat: 10 Sep 2006
https://www.obd-codes.com/p0320
dacai ai misfire pe toti 4 cilindri cu bobina noua, te sfatuiesc sa verifici ECU si cablajele.
cel mai bine mergi la un electrician priceput si o diagnosticheaza imediat
- catastefan
- 5,918 mesaje
- din 21 Jan 2012
- Corsa 2001 Z12XE
catastefan
- Mesaje scrise: 5,918
- Masina: Corsa 2001 Z12XE
- DDanyel364
- 3 mesaje
- din 05 Jan 2022
DDanyel364
- Mesaje scrise: 3
- corsablue
- 3,036 mesaje
- din 18 Feb 2008
corsablue
- Mesaje scrise: 3,036
poate te lamuresti...
zic astia ca bujiile trebuiau si ele inlocuite...
Opel Cd P0320 Possible Solution :
Disconnected, dirty or fouled spark plugs are common causes for engines that won't start. Spark plugs typically need to be replaced every season or 25 hours of use. You should also check that the spark plug gap is set properly. If your spark plugs look good, problems with your ignition system can also preventing a spark. These can range from a faulty spark plug lead, shorted kill switch or flywheel key damage.
Daaar, nu tre sa faci ce scrie aici! Stii tu mai bine ce si cum...
- DDanyel364
- 3 mesaje
- din 05 Jan 2022
DDanyel364
- Mesaje scrise: 3
