  3. Motoare benzină
  • gabimilo1
  • Mesaje scrise: 2,268
  • Masina: Zafira 2002 y20dth
If the mechanic has made a change to make the compressor work directly, this change does not affect the ECU but affects the compressor because it works regardless of the amount of freon and its pressure and then it may fail (the compressor).
At this point I think you no longer have freon.
  • EJuncosa
  • Masina: Zafira 2003 Z16XE
  • Cont inregistrat: 30 Mai 2021
Llavors el portare perquè li carreguin gas.Sempre sera mes econòmic que reparar la ecu.
Moltes gràcies per la teva aportació.
Salutacions.
Then I'll take it to load gas. It will always be cheaper than repairing the ecu.
Thank you very much for your contribution.
Greetings.
  3. Motoare benzină
