- AIordache532
- 1 mesaje
- din 23 Oct 2020
AIordache532
- Cont inregistrat: 23 Oct 2020
- deleted-30842
- 1,416 mesaje
- din 06 Mar 2009
deleted-30842
- Mesaje scrise: 1,416
- Cont inregistrat: 06 Mar 2009
Daca folosea-i functia cautare , lupa , stanga sus cu eroarea care o ai, gasea-i multe discutii pe tema ,asta ...
Verifica furtunele de la senzorul diferential de la dpf.
P1901 Particulate Filter Pressure Sensor Low Voltage C-030
P1901 Particulate Filter Pressure Sensor Low Differential Pressure C-030
P1901 Particulate Filter Pressure Sensor High Differential Pressure B-056
P1901 Particulate Filter Pressure Sensor High Voltage C-030
P1901 Particulate Filter Pressure Sensor Range/Performance B-056
P2003 Particulate Filter Pressure Sensor Much too High Differential Pressure C-030
P1901 Particulate Filter Differential Pressure Signal not Plausible with Mass Air Flow C-030
P1901 Particulate Filter Pressure Sensor Hose Line Malfunction
