  2. Opel Corsa
  3. Corsa D
  • soorin2002
  • Masina: Corsa 2007 Z10XE
  • Cont inregistrat: 08 Apr 2016
Salutare tuturor!
A mai intampinat cineva aceasta eroare C0551 ?
Am schimbat modulul ABS cu altul de la mana doua (are acelasi cod), am programat VIN-ul masinii cu OP-COM, resetat BCM,ECU...programat din nou, acelasi lucru > C0551.
DTC C0551 5A: Option Configuration Plausibility Failure
Read Info...
Identifier: 0x0580
VIN: W0L0SDL0876132696
Hardware number:65950402
System name: BOSCH ESP8.1
Part Number:13236013
Software version number: 6100118000000
Programming Date: 20070713
Hardware key number: *A:MFT-173
System description: BOSCH0300
Alpha code: AR
Manufacturing date: 20070621
Software Freeze Date: 26.09.2006
Total number of fault codes: 1
C0551 - <Unknown DTC>
(5A) - Present
pompa de ABS veche
ECU inited!
Read Info...
Identifier: 0x0580
Programming Date: 20070523
Hardware key number: *A:MFT-170
Alpha code: AR
Manufacturing date: 20070430
pompa de ABS noua
ECU inited!
Read Info...
Identifier: 0x0580
Alpha code: AR
  • Mesaje scrise: 7,066
  • Masina: Astra 2008 Z19DTH
Programare incorecta a modulului ABS.
C0551 Variant Configuration Not Programmed Hard- and Software
C0551 Wrong Variant Configuration Programmed Hard- and Software
C0551 Vehicle Identification Number Not Programmed
  • soorin2002
Pai da, am observat lucrul acesta...dar cum am mentionat am reprogramat VIN, reinitializat ECU&BCM.
Posibil sa fi scapat ceva in Program Variant Config, High Speed, Mid Speed, Low Speed...
  • janicahd
  • Mesaje scrise: 34
  • Masina: Astra OPC 2007 h
  • Cont inregistrat: 20 Oct 2007
Care este rezolvare acestei Probleme?
Am aceeasi eroare ..C0551..
Dupã schimbarea modulului abs ..
Ce trebuie facut ca nu se sting becurile din bord? Ajutor
  • janicahd
  • Mesaje scrise: 34
Opel corsa D 1.2 benzina 2007
  2. Opel Corsa
  3. Corsa D
