  2. Opel Zafira
  3. Zafira A
  • T.ion
  • Mesaje scrise: 3,454
  • Masina: Zafira 2001 Z16XE
Group "J" Engine and Engine Aggregates
Torque guide values (DOHC-I)
        Nm
 Starter to transmission                                                          40
 Starter to cylinder block                                                        25
 Drive disc to crankshaft                                                         60  1)
 Exhaust manifold to cylinder head (X 16 XEL)                                     22  2)
 Exhaust manifold to cylinder head (Z 16 XE, Z 16 YNG)                            12  3)
 Exhaust manifold to cylinder head (X 18 XE1)                                     29  2)
 Exhaust manifold to cylinder head (Z 18 XE)                                      12  4)
 Battery support to body                                                          15
 Cover to oil filter housing (X 18 XE1, Z 18 XE)                                  15
 Throttle body to intake manifold                                                  8
 Fuel pressure regulator to fuel distributor pipe (clamp) (X 16 XEL)               8
 Dynamic oil level control to oil pan                                              8  5)
 Intake manifold to intake manifold flange (X 16 XEL, Z 16 XE, Z 16 YNG)           8
 Intake manifold to cylinder head (X 18 XE1, Z 18 XE)                             20  2)
 Intake manifold flange to cylinder head (X 16 XEL, Z 16 XE, Z 16 YNG)            20  2)
 Engine vent flange to cylinder block (X 16 XEL, Z 16 XE, Z 16 YNG)                8
 Accelerator pedal to bulkhead                                                    12
 Alternator to alternator shackle                                                 20
 Transmission to cylinder block                                                   60
 Alternator support to cylinder block                                             35
 Left engine damping block support to transmission                                35
 Right engine damping block support to cylinder block                  65 + 45° + 15° 1)
 Crankshaft pulse pickup bracket to oil pump / cylinder block                     10
 Rear engine damping block bracket to transmission                                80
 Engine damping block bracket to engine damping block support (left)              55
 Engine damping block bracket to engine damping block support (right)             55
 Engine control unit bracket to cylinder head                                      8
 Rear toothed belt cover to cylinder head and oil pump                             6
 Heat shield to exhaust manifold                                                   8
 Crankshaft pulse pickup to bracket/oil pump/cylinder block                        8
 Increment disc (torsional vibration damper) to crankshaft             95 + 45° + 15° 1)
 Bulkhead cover plate insulation to body                                           9
 Wiring trough to cylinder block                                                  35
 Refrigerant line to receiver-dryer                                               20
 Refrigerant line to refrigerant line                                             20
 V-belt tensioner to alternator support                                           35
 Knock sensor to cylinder block                                                   20
 Fuel line(s) to fuel distributor pipe                                            15
 Fuel distributor pipe to intake manifold (X 18 XE1, Z 18 XE)                      8
 Fuel distributor pipe to intake manifold flange (X 16 XEL, Z 16 XE, Z 16 YNG)     8
 Coolant flange to cylinder head                                                  20
 Coolant line to intake manifold and cylinder head cover (X 18 XE1, Z 18 XE)       8
 Coolant pump to cylinder block                                                    8
 Coolant pipe to cylinder block/ transmission                                     60
 Crankshaft bearing cap to cylinder block                              50 + 45° + 15° 1)
 Oxygen sensor to exhaust manifold (X 16 XEL)                                     40
 Mixture regulating oxygen sensor to exhaust manifold (Z 16 XE, Z 16 YNG)         40
 Oxygen sensor to front exhaust pipe (X 18 XE1)                                   40
 Oxygen sensor for mixture control to exhaust manifold (Z 18 XE)                  30
 Catalytic converter control oxygen sensor to front exhaust pipe (Z 16 XE, Z 16   40
 YNG,Z 18 XE)
 Alternator shackle to intake manifold, coolant flange and alternator             20
 Air cleaner housing to body                                                       3
 Fan housing to radiator                                                           5
 Rear engine damping block to bracket                                             55
 Rear engine damping block to front axle body                                     55
 Left engine damping block to body (side member)                                  20
 Right engine damping block to body (side member)                                 35
 Front engine damping block to transmission                                       60
 Front engine damping block to front axle body                                    55
 Engine control unit to cylinder head holder (X 16 XEL, Z 16 XE, Z 16 YNG)         8
 Engine control unit to intake manifold (X 18 XE1, Z 18 XE)                        8
 Engine transport shackle to exhaust manifold                                     12
 Engine transport shackle to cylinder head                                        25
 Camshaft bearing caps to cylinder head                                            8
 Camshaft pulley to camshaft                                           50 + 60° + 15° 1)
 Camshaft sensor to cylinder head                                                  8
 Upper alternator fastening bolt to alternator shackle                            20
 Oil drain bolt to oil pan (inner Torx bolt)                                      14
 Oil drain bolt to oil pan (hex bolt)                                             45
 Oil pressure switch to oil pump                                                  30
 Oil filter to cylinder head (X 16 XEL, Z 16 XE, Z 16 YNG, Z 18 XE starting MY    15
 2002)
 Oil filter housing to cylinder block (X 18 XE1, Z 18 XE up to MY 2001)           45
 Oil lines (automatic transmission) to radiator                                   25
 Oil dipstick guide tube to exhaust gas recirculation adapter
 (X18XE1, Z18XE)        8
 Oil pump to cylinder block                                                       10
 Oil pump cover to oil pump                                                        6
 Oil intake pipe to oil pump                                                       8  5)
 Oil intake pipe to cylinder block                                                 8
 Oil baffle plate to oil pan (X 16 XEL, Z 16 XE, Z 16 YNG)                         8
 Oil pan to transmission housing                                                  40
 Oil pan to cylinder block and oil pump                                           10  5)
 Swing arm to spring strut                                                        65  2)
 Con-rod bearing cap to con-rod                                              25 + 30° 1)
 Wheel to wheel hub                                                              110
 Hose clamps for intake system                                                   3.5  Nm
 Flywheel to crankshaft                                                35 + 30° + 15° 1)
 Coolant temperature sensor to thermostat housing                                 20
 Intake manifold support to intake manifold                                       20
 Intake manifold support to cylinder block                                        35
 Thermostat housing to cylinder head                                              20
 Thermostat housing cover to thermostat housing (X16XEL, Z16XE, Z16YNG)            8
 Lower alternator fastening bolt to alternator support                            35
 Lower radiator bracket to front axle body                                        15
 Condenser to radiator                                                             5
 Closure bolt, safety valve to oil pump                                           50
 Front axle body to body (all bolts)                                   90 + 45° + 15° 1)
 Front exhaust pipe to exhaust manifold                                           20
 Toothed belt cover – upper part to rear toothed belt cover                        4
 Toothed belt cover, lower part to rear toothed belt cover                         4
 Toothed belt tension roller to oil pump                                          20
 Toothed belt – guide roller (exhaust side) to engine damping block support       25
 Toothed belt guide roller (intake side) to cylinder head                         25
 Spark plugs to cylinder head                                                     25
 Ignition module to cylinder head (X 16 XEL, Z 16 XE, Z 16 YNG)                    8
 Ignition module to cylinder head cover (X 18 XE1, Z 18 XE)                        8
 Auxiliary fan housing to radiator/ condenser                                      5
 Intermediate spindle to steering intermediate spindle                            22  6)
 Cylinder head to cylinder block                           25 + 90° + 90° + 90° + 45° 1)
 Cylinder head cover to cylinder head                                              8
1) Use new fastening bolt(s).
2) Use new fastening nut(s).
3) Retightening to a torque of 12 Nm is required
4) An additional tightening sequence to 12 Nm / 9.6 lbf. ft. is necessary – note tightening sequence.
5) Clean threads and insert fastening bolts with screw locking compound (red). The installation time including
torque checking must not exceed 10 min.
6) Insert new fastening nut(s) with screw locking compound (red).
  • T.ion
Group "E" Front Wheel Suspension, Wheels and Tyres
Recommended Torque Values
        Nm
 Axle shaft to wheel hub                                                  --  1) 2)
 Centre muffler to rear exhaust (M8x1)                                    12  3)
 Front exhaust pipe to exhaust manifold (M8)                              20  3)
 Front exhaust pipe to exhaust manifold (Z 20 LET)                         8
 Front exhaust pipe to exhaust manifold (Z 22 SE)                         16
 Triangular plate for front axle body to body                  90 + 45° + 15° 3) 4) 5)
 Spring strut to steering knuckle                                         --  2) 3) 6)
 Spring strut to wheel well                                               55  2)
 Guide joint to steering knuckle                                         100  2)
 Radiator bracket to front axle body                                      15
 Bracket for rear of engine damping block bracket to transmission         80  7)
 Bracket for rear of engine damping block bracket to engine damping block 55  8)
 Shift guide bracket to front axle body                                   20
 Stabiliser retaining bracket to front axle body                          20
 Axle shaft heat shield to rear engine damping block bracket              18
 Wiring trough to camshaft housing                                         8
 Piston rod to support bearing                                            50  8)
 Castellated nut to tie rod end                                           60
 Front and rear of control arm to front axle body              90 + 75° + 15° 9) 10) 11)
 Engine cover to engine                                                    8
 Rear engine damping block to front axle body (M10)                       55 11)
 Lower section of engine compartment panel to vehicle underbody            5
 Engine transport shackle to cylinder head (M8)                           25
 Swing arm to spring strut and stabiliser                                 65 11)
 Wheel bearing unit to steering knuckle                        90 + 30° + 15° 9)
 Vibration damper to axle shaft                                           10
 Tie rod joint end to steering knuckle                                    50 11)
 Front axle body to body                                       90 + 45° + 15° 12)13)14)
 Intermediate spindle to steering gear                                    22 15)
1) Tighten castellated nut with 120 Nm, then loosen until it can be turned by hand. Tighten castellated nut
again with 20 Nm + 80° and secure with new split pin.
3) Use new fastening bolt(s).
4) Attaching and detaching the fastening bolts with impulse or impact driver is not permissible.
5) See operation "Front Axle Body, Remove and Install".
6) Adjusting the camber is necessary - see operation "Vehicle Alignment" and "Adjust Camber". After
adjusting the camber, first of all tighten both screwed joints to 50 Nm, retighten to 90 Nm and then turn a
further 45° + 15°.
7) Clean thread and insert fastening bolt with locking compound.
8) Use new fastening nut.
9) Use new fastening bolt(s).
10) Tightening the screwed joint is undertaken in the presence of the load from the vehicle whereby both front
seats are each loaded with 70 kg.
11) Use new fastening nut(s).
12) Use new fastening bolt(s)
13) see operation "Front Axle Body, Remove and Install".
14) Attaching and detaching the fastening bolts or nuts with impulse or impact screwdrivers is not permissible.
15) Clean thread and insert fastening bolt with locking compound.
  • T.ion
Group "F" Rear Axle and Rear Wheel Suspension
Note:  Fastening bolts which are fitted using the torque and angle method (beyond the elastic limit) must not
be re-used in Service after they have been released,
        Nm
 Brake hose to brake line                                                16
 Brake line bracket to rear axle                                          8
 Parking brake cable bracket to rear axle                                 8
 Rear axle bracket to damping bushing                               90 + 60° + 15° 1) 2)
 Rear axle bracket to vehicle underbody                             90 + 30° + 15° 1) 3)
 Brake proportioning valve actuation spring bearing to bracket           20
 Wheel bearing unit to rear axle                                    50 + 30° + 15° 2)
 Shock absorber to vehicle underbody                                     90
 Shock absorber to rear axle                                            110
1) Use new fastening bolts.
2) Use new fastening nuts
3) Installation and removal with an impulse or impact screwdriver are not permitted.
  • T.ion
Group "H" Brakes
        Nm
 ABS control unit to hydraulic modulator                                          2.6 1)
 Brake servo to pedal support (brake pedal) and bulkhead                         20   2)
 Brake line to wheel brake cylinder                                              16
 Rear brake calliper to rear brake carrier                                       25
 Front brake calliper to front brake carrier                                     27.5
 Rear brake disc to rear wheel hub                                                4
 Front brake disc to front wheel hub                                              4
 Brake hose to rear brake calliper                                               40
 Brake carrier to steering knuckle                                              100   3)
 Rear brake carrier to rear brake carrier                                       100   3)
 Brake drum to wheel hub                                                          4
 Crash box to bulkhead                                                           25
 Pressure sensor to hydraulic modulator                                          20
 Bleeder screw to brake calliper                                                 10
 Bleeder screw to wheel brake cylinder                                            6
 Yaw rate/acceleration sensor to retaining plate                                  6
 Bracket for load-dependent brake proportioning valve to body                    20
 Hydraulic modulator bracket to body                                             20
 Parking brake lever to vehicle underbody                                        10
 Heat shield for centre silencer to vehicle underbody                             2
 Hydraulic modulator/relay carrier bracket to hydraulic modulator                10   4)
 bracket
 Bearing for tension spring (load-dependent brake proportioning                  20   4)
 valve) to bracket
 Load-dependent brake proportioning valve to bracket                             20   5)
 Pedal support to steering crossmember (fastening nuts and bolts)                20   6)
 Pedal support (brake pedal) to bulkhead                                         20   6)
 Wheel brake cylinder to brake anchor plate                                       9
 Parking brake telltale switch to parking brake lever                             2.5
 Stop bolt for load-dependent brake proportioning valve                          11.5
 Union nuts for brake lines (M10x1, M12x1)                                       16
 Branch to branch bracket                                                         5
3) Clean thread and insert bolts with locking compound.
4) Use new fastening nuts
5) Use new fastening bolts.
6) Use new fastening nuts
  • T.ion
Group "L" Fuel and Exhaust System
        Nm
 Exhaust gas recirculation valve to exhaust gas recirculation adapter (X 18           20
 XE1, Z 18 XE)
 Exhaust gas recirculation valve to intake manifold flange (X 16 XEL, Z 16 XE)        20
 Exhaust gas recirculation valve to cylinder head (Z 22 SE)                           25
 Exhaust gas recirculation valve to upper part of intake manifold (Y 20 DTH            8
 from MY 2003, Y 22 DTR)
 Crash box to dashboard                                                               25
 Rear muffler spring bolts                                                             8
 Engine cover bracket to exhaust gas recirculation pipe                               10
 Fuel tank retaining strap to chassis                                                 20
 Fuel filler pipe to rear frame (M8)                                                  13
 Fuel filler pipe to inner rear quarter panel (ST4.8)                                  3
 Fuel supply line to fuel distributor pipe                                            15
 Solenoid valve - exhaust gas recirculation to bracket (X 20 DTL, Y 20 DTH up          4
 to MY 2003)
 Oil dipstick guide tube to intake manifold                                           10
 Exhaust gas recirculation pipe in intake manifold (Z 22 SE)                          10
 Front exhaust pipe to exhaust manifold (hexagon nut)                                 20
 Central bolt to fuel filter housing (X 20 DTL, Y 20 DTH, Y 22 DTR)                    6
  • T.ion
Group "M" Steering
(beyond the elastic limit) must not be re-used in Service after they have been released,
        Nm
 Airbag unit to steering wheel                                                  8
 Pressure line to electro-hydraulic supply unit (Delphi)                       27.5
 Pressure line to electro-hydraulic supply unit (TRW)                          30
 Pressure line to steering gear (Delphi)                                       27.5
 Pressure line to steering gear (TRW)                                          30
 Damping bush to bracket and electro-hydraulic supply unit (TRW)                7
 Pressure and return line bracket to steering gear                              4
 Electro-hydraulic supply unit bracket to steering gear                        22
 Electro-hydraulic supply unit bracket to front axle body                      22
 Engine damping block bracket to rear of transmission                          80
 Engine damping block bracket to rear of engine damping block                  55
 Heat shield to steering gear                                                   4
 Heat shield for steering gear lines to front axle body                         6
 Clamp bolt for steering column assembly                                       22
 Tie rod to tie rod end lock nut                                               60
 Steering gear to front axle body                                   45 + 45° + 15°  1)
 Steering gear lines to steering gear                                          30
 Steering wheel to steering shaft                                              20
 Steering column assembly to crossmember                                       22
 Return line to steering gear (Delphi)                                         27.5
 Return line to steering gear (TRW)                                            30
 Tie rod to steering gear rack                                                 90  2)
 Tie rod end to steering knuckle                                               50  3)
 Intermediate shaft to steering gear shaft                                     22  4)
 Intermediate shaft to steering shaft                                          22  4)
1) Use new fixing bolts and nuts
2) Clean rack thread and coat with locking compound
3) Use new fastening nut
4) Clean thread and insert clamp screw with locking compound
  • T.ion
Group "K" Clutch and Transmission F17/F17+
        F17/F17+
        Nm
 Drain plug to transmission                                                        --
 Drive gear (driven) to differential housing                                       85
 Drive shaft to transmission                                                        7
 Bridge for sliding fork to end shield                                              7
 Differential cover to transmission (sheet metal version)                          30
 Differential cover to transmission (light alloy version)                          18
 Transmission end piece cover to transmission housing                              --
 End shield cover to transmission, all transmissions         M7 x 1.0              15
                                                             M8 x 1.25             20
 Shift cover to transmission                                                       12
 Pressure line to central release                                                  14
 Filler bolt to transmission                                                       --
 Clutch actuation bleed valve                                                       9
 Odometer sensor to transmission                                                   --
 Transmission to engine                                                            60
 Left engine damping block main bracket to transmission                            --
 Shift Bowden cable bracket to transmission                                        --
 Main shaft to transmission                                                        --
 Shift guide clamp to shift rod                                  12 + 90° + 90° - 225°
 Transmission fluid checking bolt to transmission                 4 + 45° + 90° + 90°
 Clutch to flywheel        15
 Clutch housing to transmission housing                                            --
 Clutch master cylinder with pedal bracket to bulkhead                             20
 Bearing support for pawl to end shield                                             7
 Main shaft bearing ring to clutch housing                                         --
 Steering wiring harness ground to body                                            15
 Left engine damping block to engine damping block main bracket                    55
 Right engine damping block to engine damping block bracket                        55
 Oil sump to transmission                                                          40
 Shift mechanism assembly fit bolt to transmission                                 --
 Pedal bracket to steering crossmember                                             20
 Positive cable to battery positive terminal                                       12
 Crankcase ventilation pipe to cylinder block                                       8
 Reversing lamp switch to transmission                                             20
 Shift control housing to vehicle underbody                                        10
 Retaining plate to adjustment nut for tapered roller bearing                       9
 (differential)        --
 Inlet manifold support to inlet manifold                                          20
 Inlet manifold support to cylinder block                                          35
 Central release to transmission                                                    5
 Shift mechanism assembly to transmission                                          --
Ultima modificare făcută de T.ion la Mar 15 Jan, 2019 2:49 pm
  • T.ion
Group "K" Clutch and Transmission F23
        F23
        Nm
 Drain plug to transmission                                                    35
 Drive gear (driven) to differential housing                                   90
 Drive shaft to transmission                                                  100
 Bridge for sliding fork to end shield                                         --
 Differential cover to transmission (sheet metal version)                      --
 Differential cover to transmission (light alloy version)                      --
 Transmission end piece cover to transmission housing                          25
 End shield cover to transmission, all transmissions         M7 x 1.0          --
                                                             M8 x 1.25         --
 Shift cover to transmission                                                   --
 Filler bolt to transmission                                                   35
 Odometer sensor to transmission                                                5
 Left engine damping block main bracket to transmission                        55
 Shift Bowden cable bracket to transmission                                    20
 Main shaft to transmission                                                   100
 Shift guide clamp to shift rod                                                --
 Transmission fluid checking bolt to transmission                              35
 Clutch housing to transmission housing                                        28
 Main shaft bearing ring to clutch housing                                     10
 Shift mechanism assembly fit bolt to transmission                             25
 Crankcase ventilation pipe to cylinder block                                  --
 Reversing lamp switch to transmission                                         15
 Retaining plate to adjustment nut for tapered roller bearing                  --
 (differential)
 Inlet manifold support to inlet manifold                                      --
 Inlet manifold support to cylinder block                                      5
 Shift mechanism assembly to transmission                                      25
  • T.ion
Group "K" Clutch and Transmission F35
        Nm
        F35
 Drain plug to transmission                                                       50
 Drive gear (driven) to differential housing                                      20
 Drive shaft to transmission                                                      --
 Transmission end piece cover to transmission housing                             24
                                                             M8 x 1.25            --
 Filler bolt to transmission                                                      50
 Shift guide clamp to shift rod                                                12 + 200°
 Transmission fluid checking bolt to transmission                                 50
 Clutch housing to transmission housing                                           24
 Bearing support for pawl to end shield                                           --
 Reversing lamp switch to transmission                                            24
 (differential)
  • T.ion
Group "C" Body Equipment
Technical Data – Recommended Torque Values
                                                        Nm
 Airbag unit to steering crossmember                     5
 Reel retractor to B-pillar                             35
 Reel retractor to C- and D-pillars                     35
 Actuation unit to roof                                  4
 Outer seat bench guide rail to underbody               18
 Centre seat bench guide rail to underbody              18
 Glass cover to actuation unit                           4
 Belt lock to seat bench                                35
 Seat belt tensioner to front seat                      35
 Active headrest lever to front seat backrest frame      6.5
Recommended Torque Values (Continued)
                                                        Nm
 Rear seat to underbody                                 20
 Height adjuster to pillar                              20
 Side airbag to front seat backrest                      5
 Seat belt to height adjuster                           35
 Seat belt to underbody                                 35
 Seat belt to front seat                                20
 Seat bench to outer seat bench guide rail              35
 Seat bench backrests to seat bench                     25
 Front seat console to front seat                       25
 Seat upholstery to seat bench                          25
 Airbag control unit to underbody                       10
                                                        Nm
 Seat belt guide clamp to D-pillar                      35
 Front seat to underbody                                20
 Front seat backrests to front seat                     35
 Active headrest assembly to active headrest lever       6
  • T.ion
Group "D" Heating, Ventilation, Air Conditioning
Torque guide values - rear A/C
        Nm
 Refrigerant line to body                                                           5.5
 Rear left refrigerant line union nut for vacuum side of rear AC to AC module       13
 Rear left refrigerant line union nut for overpressure side of rear AC to AC module 32
 Separation points for rear AC refrigerant lines (all M8)                           18
 Rear left refrigerant line for rear AC to block connector                          18
 Rear AC module to body                                                              3
 Front axle body bracket (only install new fastening bolts)                    90 + 45° + 15°
 Torque guide values - general
                                               Nm
 Pressure sensor to receiver-dryer           7 to 9
 Expansion valve to evaporator              4.5 to 6
 Compressor bracket to engine                  35
 Refrigerant line to:
    - Receiver-dryer                           20
    - Expansion valve                           7
    - Compressor                               20
    - Condenser                                20
 Condensation drain to bulkhead                 5
 Compressor to compressor main bracket         20
 Torque guide values - compressor (not Z 22 SE, Y 22 DTR)
                                           Nm
 Drain plug, compressor lubricant       37 to 41
 Safety valve to compressor                20
 Compressor clutch to compressor shaft     20
 Guide Values for Torque, Auxiliary Heating (Webasto System)
                                                 Nm
 Recirculation pump to combustion air fan unit   3.5
 Combustion air fan unit to burner housing       4
  • T.ion
Group "N" Electrical
                          Nm
 Antenna base to roof      5
 Windscreen wiper arm     14
 Rear screen wiper arm     9
 Headlamp to front panel  2.5
  • T.ion
Daca doreste cineva sa le traduca ne-ar fi mult mai usor.
Google Translate - Nu traduce prea bine.
Cineva cu engleza buna.
Mersi.
PS: Le puteti timite in PM si le asez eu in pagina.
  • T.ion
Starter, Remove and Install
   Remove
Deconectati cablul de împãmântare de la baterie,
Demontati suportul pentru galeria de admisie (1),
Deconectati conexiunile cablurilor (2) si (3) de la starter,
Detasati cablul de împãmântare (5) de la surubul superior de fixare,
Demontati surubul de fixare (4) si surubul de fixare (6) - scoateti demarorul în jos,
   Install
Atasati demarorul la transmisie. Piulitã de fixare (4) - cuplu de strângere de 40 Nm
Atasati surubul de fixare (6) - cuplul de strângere de 25 Nm
Atasati cablul de împãmântare la surubul superior de fixare,
Conectati starterul electric,
Atasati suportul galeriei de admisie la galeria de admisie - cuplu de strângere de 20 Nm
Atasati suportul galeriei de admisie la blocul cilindrului - cuplu de strângere de 35 Nm
Conectati cablul de împãmântare la baterie.
https://www.clubopel.com/viewtopic.php?p=1797883
  • T.ion
Suportul alternatorului pe blocul motor             35 Nm
Surubul superior de fixare al alternatorului        20 Nm
Surubul inferior al alternatorului                  35 Nm
Dispozitivul de intindere a curelei de transmisie pe suportul alternatorului 35 Nm
  • T.ion
 Bujiile de aprindere la chiulasã               25 Nm
 Modulul de aprindere la chiulasã                8 Nm
  • therealovy77
  • Mesaje scrise: 245
  • Masina: Zafira 2001 Z18XE
  • Cont inregistrat: 31 Mar 2007
Salut. Am rugãmintea sã îmi spui ce cuplu au cele 4 șuruburi de la pivotul fata (3 + 1 șuruburi) și de la bieleta antiruliu fata (2 suruburi), cã nu știu cum se numesc in engleza.
Mulțumesc.
  • T.ion
Prinderea pivotului la bratul trapez prin suruburi (cele 3 suruburi.) - 35 Nm
Prinderea pivotului la fuzeta - 100 Nm (surubul se introduce din fata spre spate)
Bieleta Antiruliu - 65 Nm
Ultima modificare făcută de T.ion la Vin 07 Jun, 2019 1:36 pm
  • therealovy77
Mulțumesc mult pt amabilitate si promptitudine!
  2. Opel Zafira
  3. Zafira A
