- newmedia_ltd
- 16 mesaje
- din 27 Apr 2006
- Astra 2003 Y20DTH
newmedia_ltd
- Mesaje scrise: 16
- Masina: Astra 2003 Y20DTH
- Cont inregistrat: 27 Apr 2006
masina la variatii de temperatura ramane turata
si de fiecare data cand e sa intre in service merge bine
throttle body a fost curata in urma cu 10.000 ++km
si motorasul pas cu pas a fost schimbat cu unul nou (sau asa stie stapanu masinii)
* mai apar diferente in functie de benzina folosita
ce poate sa aiba ?
ar fi binevenita o noua curatare a throttle body
si cu map-ul ce trebuie facut
va multumesc anticipat pentru raspunsuri
p.s. am cautat in TIS motorul asta si nu l-am gasit
parametri scanati in timp ce masina se manifesta
Opel Corsa - B (Vita) 1996 (T)
1.2 [X12SZ] - Multec SZ (pin 7)
Trouble Codes:
22 Throttle position sensor voltage low - Present
33 MAP sensor, voltage high - Not Present
Live Parameters Data:
1 Engine Speed 3000 RPM
2 EGR Position Command 0 %
3 EGR Position Feedback 0 %
4 O2 Sensor 522 mV
5 O2 BLM Cell Number 2 steps
6 O2 BLM Cell Content 128 steps
7 O2S Integrator 117 steps
8 O2-Loop BLM Enable Inactive
9 O2 Sensor Loop Closed
10 IAC Control Enable Inactive
11 Idle Air Control 43 steps
12 Desired Idle Speed 913 RPM
13 MAP Sensor 1.00 V
14 MAP Sensor 0.29 Bar
15 TPS Signal 12 %
16 TPS Signal 0.06 V
17 Battery Voltage 13.7 V
18 Coolant Temperature 1.95 V
19 Coolant Temperature 92 °C
20 Idle Adjust Inactive
21 Spark Table 91 Inactive
22 Spark Table 95 Active
23 Fuel Pump Relay Active
24 Diag. Request Inactive
25 Injection Pulse 0.9 ms
26 Spark Angle before TDC 35 °CA
27 Cyl.1 Knock Retard 0 °CA
28 Cyl.2 Knock Retard 0 °CA
29 Cyl.3 Knock Retard 0 °CA
30 Cyl.4 Knock Retard 0 °CA
31 Knock Pulses 3 Counts
32 Knock Signal 2.42 V
33 Vehicle Speed 0 km/h
34 Vehicle Speed Pulse Not Received
35 Fuel Tank Ventilation Valve 0 %
36 Clear Flood Mode Inactive
37 Dec. Fuel Cutoff Inactive
38 Air/Fuel Ratio Lean
39 Power Enrichment Inactive
40 Desired P/N Idle Speed 0 RPM
41 Torque Control Active
42 Park/Neutral Switch P-N
ce poate sa aiba ?
Trouble Codes:
4 O2 Sensor 522 mV
15 TPS Signal 12 %
- alexandru.ast
- 34 mesaje
- din 22 Mar 2007
- Corsa 1994 X12SZ
alexandru.ast
- Mesaje scrise: 34
- Masina: Corsa 1994 X12SZ
- Cont inregistrat: 22 Mar 2007
doycer
- Mesaje scrise: 4
- Masina: Corsa 1993 1.2
- Cont inregistrat: 13 Jan 2009
- alexey
- 851 mesaje
- din 01 Dec 2007
- Astra 2001
- Botosani
alexey
- Mesaje scrise: 851
- Masina: Astra 2001
- Cont inregistrat: 01 Dec 2007
