- diablo46
- 174 mesaje
- din 09 Jan 2015
- Astra 2011 A14XER
diablo46
- Mesaje scrise: 174
- Masina: Astra 2011 A14XER
- Cont inregistrat: 09 Jan 2015
Odata cu venirea caldurii am observant ca atunci cand pornesc ventilator de habitaclu, baga aer rece, porneste si AC-ul.
Daca apas e butonul de ac sa-l pornesc/opresc, nu se intampla nimic, baga aer rece incontinuare.
A mai intampinat cineva aceasta problem? Modelul este 2009 hatchback, an fabricatie 2011 si am clima bizonala pe masina.
Ma poate ajuta cineva cu schema electrica a AC-ului si cea mecanica (sistemul care cupleaza si decupleaza compresorul)?
Pareri despre care ar putea fi cauza problemei?
Multumesc anticipat.
- lexandrei10
- 495 mesaje
- din 21 Jun 2017
- Astra 2017 B14NET
lexandrei10
- Mesaje scrise: 495
- Masina: Astra 2017 B14NET
- Cont inregistrat: 21 Jun 2017
- diablo46
- 174 mesaje
- din 09 Jan 2015
- Astra 2011 A14XER
diablo46
- Silviu Mustata
- 1,199 mesaje
- din 28 Mai 2017
- Astra 2017 B14NET
Silviu Mustata
- Mesaje scrise: 1,199
- Cont inregistrat: 28 Mai 2017
- lexandrei10
- 495 mesaje
- din 21 Jun 2017
- Astra 2017 B14NET
lexandrei10
- Silviu Mustata
- 1,199 mesaje
- din 28 Mai 2017
- Astra 2017 B14NET
Silviu Mustata
- clau70
- 3,336 mesaje
- din 11 Apr 2013
- Astra 2010 A20DTH
clau70
- Mesaje scrise: 3,336
- Masina: Astra 2010 A20DTH
Led-ul care semnalizeaza functionarea compresorului (fulgul) sta aprins... conducta de freon de la compresor e rece (cea groasa)?
"When the A/C switch or the AUTO switch is pressed, the HVAC controls send a signal to the HVAC control module via LIN-Bus. The HVAC control module evaluates this signal and sends an A/C request signal to the ECM via CAN-Bus. The ECM checks all preconditions before releasing and if all conditions are met sends a release signal back to the HVAC control module. The A/C compressor is activated by the HVAC control module. The HVAC control module supplies battery voltage to the A/C compressor. When the A/C switch is pressed, the HVAC control module provides a pulse width modulation (PWM) signal to the A/C compressor in order to command the performance of the A/C compressor. The performance of the A/C compressor is regulated according to adjusted interior temperature on the basis of characteristic lines. Therefore the HVAC control module grounds the A/C compressor with the PWM signal."
L.E. Silviu, la Astra J clima nu se autocupleaza daca e cald afara... in setari poti selecta ca la pornirea motorului clima sa fie "on", "off" sau "last setting" (adica, la repornirea motorului clima se reporneste si ea sau nu, functie de cum ai lasat-o la oprirea motorului).
Ultima modificare făcută de clau70 la Mie 12 Jul, 2017 4:06 pm, modificat de 2 ori în total
silvio27
- Mesaje scrise: 18
- Masina: Astra 2014 A14XER
- Cont inregistrat: 24 Jan 2015
- clau70
- 3,336 mesaje
- din 11 Apr 2013
- Astra 2010 A20DTH
clau70
- deleted-109714
- 176 mesaje
- din 18 Apr 2016
deleted-109714
- Mesaje scrise: 176
- Cont inregistrat: 18 Apr 2016
@Silviu Mustata, la C4 e un pic mai complex sistemul, la astra sunt facute toate la limita minima a calitatii, de ex uneori cifra de pe buton nu corespunde cu cea de pe display pentru ca nu face bine contact, etc.Sau desi dezactivezi sa nu-ti mai bata in fata aerul pana nu inchizi grilele mecanic tot mai vine ceva aer pe acolo.
- diablo46
- 174 mesaje
- din 09 Jan 2015
- Astra 2011 A14XER
diablo46
Cat timp ventilatorul e oprit conducta de la ac din conpartimentul motorului e calda. Cand pornesc ventilatorul de habitaclu, se raceste si conducta porneste si ventilatorul de la radiator. Daca ma joc la butoanele de dezaburire sau la fulg, nu reusesc sa.l decuplez sub nicio forma desi ledurile butoanelor se aprind si se sting la apasarea butoanelor. Se opreste doar cand opresc ventilatorul. Abea atunci se incalzeste iar si conducta de freon.
Asta ma face sa cred ca e ceva de comuter sau vro atingere de fire.
- clau70
- 3,336 mesaje
- din 11 Apr 2013
- Astra 2010 A20DTH
clau70
- diablo46
- 174 mesaje
- din 09 Jan 2015
- Astra 2011 A14XER
diablo46
- clau70
- 3,336 mesaje
- din 11 Apr 2013
- Astra 2010 A20DTH
clau70
- diablo46
- 174 mesaje
- din 09 Jan 2015
- Astra 2011 A14XER
diablo46
- deleted-45341
- 39 mesaje
- din 14 Feb 2010
deleted-45341
- Mesaje scrise: 39
- diablo46
- 174 mesaje
- din 09 Jan 2015
- Astra 2011 A14XER
diablo46
Eu zic sa citesti topical inainte sa scrii. Am explicat ca daca pornesti ventilatorul baga aer rece, si indifferent daca apesi pe butonul "fulg" nu se intampla nimic, ramane pornit, chiar daca luminita aceea se aprinde si se stinge la apasare. Stiu si eu ce scrie in carte si care sunt setarile masinii.
Am scos borna la baterie si am lasat masina cateva minute si se pare ca si-a revenit. O sa vad daca eroarea revine.
Multumesc tuturor colegilor pentru incercarea de a ma ajuta.
- asdhj
- 241 mesaje
- din 27 Aug 2008
- Astra 2011 A17DTJ
- Dambovita
asdhj
- Mesaje scrise: 241
- Masina: Astra 2011 A17DTJ
- Cont inregistrat: 27 Aug 2008
CLAULUCAS
- Cont inregistrat: 05 Sep 2017
- Tai-Pan
- 2,957 mesaje
- din 15 Jun 2017
- Astra 2017 B14NET
Tai-Pan
- Mesaje scrise: 2,957
- Cont inregistrat: 15 Jun 2017
Verifica in meniul climatizarii si vezi starea AC-ului : Cuplat tot timpul ,mentinere ultima setare sau decuplat .
Nu exista "cuplat tot timpul"!
On inseamna ca la porinirea motorului AC va fi mereu on;
Off inseamna ca la pornirea motorului AC va fi mereu off;
Mentine ultima setare inseamna ca la pornirea motorului AC va fi on sau off, in functie de cum era cand ai oprit motorul.
La mine baga aer rece daca pornesc ventilatorul, fara sa apas butonul cu fulg, doar daca fluxul de aer este orientat NUMAI spre parbriz (cele 2 posibilitati).
