  3. Vectra C/Signum
  • cristian andrei
  • Mesaje scrise: 8
  • Masina: Astra 2001 Y17DT
  • Cont inregistrat: 30 Dec 2014
Buna ziua,stie cineva cu ce tip de rulmenti este dotata Vectra c break din 2007 ? Ma refer la specificatia IDS,dotare din fabrica cu sau fara IDS ? Multumesc !
  • Mesaje scrise: 7,144
Se pare ca sunt prevazute (doar) 2 variante de butuc( cu rulment incorporat), cu IDS+ si fara:
1 93175327 16 03 243 HUB,ASSY.,FRONT,WITH ABS SENSOR (EXCEPT IDS+) (NLS.- USE 93186387 16 03 294) (PRODUCTION NO. 12796081) (C) 31000001-41999999 (C)38000001-48999999 (fara IDS+), aftermarket 350-650Ron, orig. spre 1.000Ron.
1 93186388 16 03 295 HUB,ASSY.,FRONT,WITH ABS SENSOR (PRODUCTION NO. 13224331) (C) 51000001- (C)58000001- (cu IDS+), aftermarket 360-820Ron, orig. spre 1.050Ron.
  3. Vectra C/Signum
