  • skull
  • Mesaje scrise: 13
  • Masina: Astra 2001 Z16SE
  • Cont inregistrat: 24 Dec 2016
Am un FM Modulator, ai 2x USB port 1 pentru USB drive pentru musica si 1 pentru incarca mobilul. (Normal ca folosit port pentru USB drive inainte cineva intreb:P)
Am gasit un video ruski (1:27) cum pot sa play, am facut acelasi, modulatorul face asa ca in video dar muzica nu incepe, numai scrie USB, asculta o beep ca e conectat dar dupa o pauza asulta o beep ca disconectat si face asa din nou si din nou... Am vazut ca trebue sa formeaza USB pentru FAT32 si am incercat asa dar nu merge. Aux si bluetooth functioneaza dar uneori calitate nu e mai bine cu bluetooth si vreau sa incerca cum merge cu USB drive. (Eventual unele idei pentru face sunet mai clar?
Fisiere nu sunt in dosar, sunt in radacina pe USB drive.
Imi pare rau pentru greseli, nu sunt romanesc dar vreau sa invata limba pentru ca locuiesc in Romania 😊)
  • jgyprime
  • Mesaje scrise: 9,951
  • Masina: Vectra 2005 Z19DT
Sper sa se traduca corect.
1. Formateaza stick-ul fat 32 cu setarile implicite (nu modifica setarile cand formatezi, totul default).
2. Incearca stick cu dimensiune mai mica (exemplu 2 gb).
If you know english, post in english, many of us know english. Translation to romanian is very crappy and the post above does not quite sound like romanian... I had to struggle to understand what you wanted to say.
  • skull
  • Mesaje scrise: 13
Okey, my english is better a bit. When I set to default file system is going to be simple FAT. Should I keep that or change to FAT32 anyway?
  • jgyprime
Change it to fat 32 but leave the default allocation unit.
What is the size of your usb stick?
Also, is your usb stick 3.0 or 2.0?
  • skull
  • Mesaje scrise: 13
First I tried with 16GB usb stick, now I found an old 2GB stick, don't think its 3.0 so I hope it will work. I also have 4 more usb sticks, 2x4GB, 2x8GB.
Tomorow I'll try with 2GB and 4GB sticks and write here if them work.
Thanks.
  • jgyprime
You could try and format each one with differen settings (and remember the settings) and put a few songs on it.
The one that works does the trick.
  • Mesaje scrise: 7,150
Nice thing a foreigner wanting to learn romanian language ... Good luck!
  • skull
  • Mesaje scrise: 13
Okey, its working with 2 and 4 GB USB sticks, thanks.
@bibu16v should I comment this?
  • jgyprime
Probably your fm transmitter does not support all the usb stick types...
