Cred ca senzor arborelui cotit. | Senzor impulsuri arbore cotit.
Din ce scrie aici "new O-rings" probabil este copt si trebuie schimbat.
http://workshop-manuals.com...ll_%28z_16_se%29/ a scris:Crankshaft Pulse Pick-up, Remove and Install (Z 16 SE)
Remove
Disconnect wiring harness plug (2) from crankshaft pulse pick-up.
Remove fastening bolts (1) and remove crankshaft pulse pickup.
Install
Insert crankshaft pulse pickup with new O-rings and attach with fastening bolts.
Connect wiring harness plug to crankshaft pulse pick-up.
![](//s3-eu-west-1.amazonaws.com/2013.clubopel.com/images/2013/blank.gif)
Poate ne ajuta colegi cu o traducere mai buna - "Crankshaft pulse pick-up"
Dupa mine nu curge vad ca vine de mai sus de la filtru de ulei poate, il poti strange ompic, nu exagerat sa nu ii strici filetul.
Si daca esti sigur ca curge pe la senzor arborelui cotit, ii schimbi O-ringul.
