ZotaIoan
- Mesaje scrise: 12
- Masina: Astra 2003 Z17DTL
- Cont inregistrat: 08 Nov 2012
baiku
- Mesaje scrise: 70
- Masina: Astra 2002 Z16XE
- Cont inregistrat: 20 Jun 2012
Symptoms may include:
- the engine may be harder to start
- the engine may stumble / stumble, and/or hesitate other symptoms may also be present
A code P0308 may mean that one or more of the following has happened:
- Faulty spark plug or wire
- Faulty coil (pack)
- Faulty oxygen sensor(s)
- Faulty fuel injector
- Burned exhaust valve
- Faulty catalytic converter(s)
- Running out of fuel
- Poor compression
- Defective computer
If there are no symptoms, the simplest thing to do is to reset the code and see if it comes back.
If there are symptoms such as the engine is stumbling or hesitating, check all wiring and connectors that lead to the cylinders (i.e. spark plugs). Depending on how long the ignition components have been in the car, it may be a good idea to replace them as part of your regular maintenance schedule. I would suggest spark plugs, spark plug wires, distributor cap, and rotor (if applicable). Otherwise, check the coils (a.k.a. coil packs). In some cases, the catalytic converter has gone bad. If you smell rotten eggs in the exhaust, your cat converter needs to be replaced. I've also heard in other cases the problems were faulty fuel injectors.
Google translate :
Un cod P0308 înseamnã cã, computerul masinii a detectat cã unul dintre cilindrii motorului nu este ardere în mod corespunzãtor. În acest caz, este cilindrul # 8.
Simptomele pot include:
- Motorul poate porni mai greu
- Motorul poate poticni sau ezita, alte simptome pot fi de asemenea prezente
Un P0308 cod poate însemna cã una sau mai multe dintre urmãtoarele s-a întâmplat:
- Bujie defectã sau sârmã
- Bobina defectã (pachet)
- Senzor defect de oxigen (s)
- Injector de carburant defect
- Supapã de evacuare arsa
- Convertor catalitic defect (e)
- Combustibul putin in rezervor
- Compresie slabã
- Calculator Defect
- iulian1971
- 7,047 mesaje
- din 21 Dec 2006
- Ilfov
iulian1971
- Mesaje scrise: 7,047
Efraim
- Mesaje scrise: 4
- Masina: Astra 2004 Z17DTL
- Cont inregistrat: 19 Mar 2012
Efraim
- Mesaje scrise: 4
- iulian1971
- 7,047 mesaje
- din 21 Dec 2006
- Ilfov
iulian1971
Efraim
- Mesaje scrise: 4
- iulian1971
- 7,047 mesaje
- din 21 Dec 2006
- Ilfov
iulian1971
Efraim
- Mesaje scrise: 4
- dan cristi
- 436 mesaje
- din 04 Aug 2014
- Astra 2002 y17dt
dan cristi
- Mesaje scrise: 436
- Masina: Astra 2002 y17dt
- Cont inregistrat: 04 Aug 2014
