rebotea
- Mesaje scrise: 28
- Masina: Vectra OPC 2003
- Cont inregistrat: 14 Apr 2013
- catastefan
- 5,918 mesaje
- din 21 Jan 2012
- Corsa 2001 Z12XE
catastefan
- Mesaje scrise: 5,918
- Masina: Corsa 2001 Z12XE
rebotea
- Mesaje scrise: 28
- catastefan
- 5,918 mesaje
- din 21 Jan 2012
- Corsa 2001 Z12XE
catastefan
- jgyprime
- 9,951 mesaje
- din 22 Dec 2010
- Vectra 2005 Z19DT
jgyprime
- Mesaje scrise: 9,951
- Masina: Vectra 2005 Z19DT
then you need to program front fog lights in UEC, BCM and Instrument (if you have the LED, if not there is no problem but when you have fog lights on you will not see anything on the instrument).
also you will need to change the controls that command the outer lighting with one that has the button.
check this topic: https://www.clubopel.com/vie...76804&start=0
some of the pics are missing...
the topic was complete some time ago...
rebotea
- Mesaje scrise: 28
here is all the data include opcom soft https://drive.google.com/fol...M&usp=sharing
- jgyprime
- 9,951 mesaje
- din 22 Dec 2010
- Vectra 2005 Z19DT
jgyprime
- DB77AAA
- 6,621 mesaje
- din 19 Jan 2007
- Vectra 2005 Z19DTH 200CP
- Dambovita
DB77AAA
- Mesaje scrise: 6,621
I fix it whith OPcom 2012.
Do you have OPcom 120309a? If not, I can give you that version - work fine whith 2010 hardware.
rebotea
- Mesaje scrise: 28
- jgyprime
- 9,951 mesaje
- din 22 Dec 2010
- Vectra 2005 Z19DT
jgyprime
I changed the front fog lamps on my car with the "China Clone" version and did not have problems.
on another vectra c, almost identical to mine (another engine (z18xe petrol), but still the same year, the same month) I did not manage to change front fog lamps to present in BCM. UEC changed front fog lamps to present without problems...
@rebotea
I would advise you to check BCM and UEC and see if front fog lamps is enabled on both of them.
if not you shoud enable them both.
if op-com throws error when accessing "variant config" on any of them you should try some other software or another proigramming interface.
op-com might not be able to correctly program front fog lamps on your car.
- DB77AAA
- 6,621 mesaje
- din 19 Jan 2007
- Dambovita
DB77AAA
Rebotea, I send PM whith 2012 software.
- jgyprime
- 9,951 mesaje
- din 22 Dec 2010
- Vectra 2005 Z19DT
jgyprime
Daca in bcm nu e present masina nu stie ca are buton in controale si deci il ignora.
Si dupa cum am zis eu pe masina mea am programat fara probleme si proiectoarele, si geamurile electrice spate, si cc...
Pe alte masini programam present functii, imi zicea ca s-a programat si cand intram din nou in modil aparea not present. Banui ca si la tine era ceva similar... si asta probabil din cauza ca op-com nu are tot ce ii trebuie pentru a programa acele functii...
Poti te rog sa imi trimiti si mie softul de op-com 2012? As vrea sa incerc sa-l decompilez sa vad ce iese din el...
rebotea
- Mesaje scrise: 28
flyer1sst
- Mesaje scrise: 37
- Masina: Vectra 2004 Z19DT
- Cont inregistrat: 04 Dec 2007
- DB77AAA
- 6,621 mesaje
- din 19 Jan 2007
- Dambovita
DB77AAA
flyer1sst
- Mesaje scrise: 37
- corsa.timis
- 490 mesaje
- din 29 Dec 2014
- Corsa 2001 Z12XE
- Timis
corsa.timis
- Mesaje scrise: 490
- Cont inregistrat: 29 Dec 2014
- DB77AAA
- 6,621 mesaje
- din 19 Jan 2007
- Dambovita
DB77AAA
- corsa.timis
- 490 mesaje
- din 29 Dec 2014
- Corsa 2001 Z12XE
- Timis
corsa.timis
