Vin 28 Aug, 2015 8:53 pm
salutare,pun si eu parametrii motorului meu Z14XE ,are momente cand nu trage in sarcina.clapeta,valva egr curatate,bujii cu 2 elementi GM noi.poate vedeti ceva suspect ca sa stiu de unde sa incep cu reparatiile .
-vad ca apar si 2 misfire ,de la ce ar putea fi?
Identifier: 1591
CalibrationDate: P0201A05
Measuring blocks information:
Battery Voltage,14.0 V
Main Relay,Active
Fuel Pump Relay,Active
APP Sensor 1 (Accelerator Pedal Position),0.96 V
APP Sensor 2 (Accelerator Pedal Position),0.47 V
Calculated Pedal Position,0 %
APP at Idle Position (Accelerator Pedal Position),Active
TP Sensor 1 (Throttle Position),0.45 V
TP Sensor 2 (Throttle Position),4.55 V
Calculated Throttle Position,4 %
Throttle Position,Idle
Engine Speed,802 RPM
MAP Sensor (Manifold Absolute Pressure),1.09 V
MAP Sensor (Manifold Absolute Pressure),30 kPa
Coolant Temperature,1.23 V
Coolant Temperature,89 °C
Intake Air Temperature,2.82 V
Intake Air Temperature,38 °C
Tank Sensor,6.49 V
Tank Sensor,6 L
A/C Information Switch (Air Conditioning),Not Programmed
A/C Pressure (Air Conditioning),0 kPa
Brake Switch 1,Inactive
Brake Switch 2,Inactive
Clutch Switch,Not Programmed
Vehicle Speed,0 km/h
Cruise Control Tip Switch,Not Programmed
Cruise Control,Not Programmed
Vehicle Speed in Cruise Control Range,Not Programmed
EGR Valve (Exhaust-Gas Recirculation),Inactive
EGR Position Command (Exhaust- Gas Recirculation),0 %
EGR Position Feedback (Exhaust Gas Recirculation),1.31 V
Fuel Tank Ventilation Valve,0 %
Knock Control,Inactive
B1S1 O2 Sensor Heater (Bank 1 Sensor 1),Active
B1S1 O2 Sensor (Bank 1 Sensor 1),69 mV
B1S1 Air/Fuel Ratio (Bank 1 Sensor 1),Lean
B1S2 O2 Sensor Heater (Bank 1 Sensor 2),Active
B1S2 O2 Sensor (Bank 1 Sensor 2),733 mV
B1S2 Air/Fuel Ratio (Bank 1 Sensor 2),Lean
O2 Sensor Loop,Closed
B1 Long Term Fuel Trim (Bank 1),11 %
B1 Short Term Fuel Trim (Bank 1),1 %
A/C Relay (Air Conditioning),Not Programmed
A/C Cutoff Mode (Air Conditioning),System OK
Fan Relay 1,Inactive
Fan Relay 2,Inactive
Fan Relay 3,Not Programmed
Malfunction Indicator (MI),Off
Service Vehicle Soon (SVS) Indicator,Off
Desired Idle Speed,787 RPM
Idle Speed Offset,Inactive
Ignition Dwell Angle,2.1 ms
Injector Time,2.2 ms
Ignition Spark Angle,4.2 °CA
Knock Retard Cylinder 1,0 °CA
Knock Retard Cylinder 2,0 °CA
Knock Retard Cylinder 3,0 °CA
Knock Retard Cylinder 4,0 °CA
Ignition Status,On 12V
ETC Limp Home Mode (Electronic Throttle Control),Inactive
Total Misfire,2
Dec. Fuel Cutoff (Deceleration),Active
Fuel Tank Ventilation Valve,Inactive
