alinpascani- Suspendat
- 38 mesaje
- din 23 Mai 2014
- Zafira 2000
alinpascani- Mesaje scrise: 38
- Masina: Zafira 2000
- Cont inregistrat: 23 Mai 2014
- 38 mesaje
- din 23 Mai 2014
- Zafira 2000
OP-COM 100219a - PC based diagnostic tool
OP-COM - KW2000 Communication Window> 2000|Astra-G|Engine|Y 20 DTH
Keyword #1: 6B
Keyword #2: 8F
Normal timing parameter set.
VIN: W0L0TGF35Y8132911
vehicleManufacturerECUHardwareNumber 09181243 DY
systemSupplierECUHardwareNumber: BOS 010503
systemSupplierECUHardwareVersionNumber: FF
systemSupplierECUSoftwareNumber: VT1M3050
systemSupplierECUSoftwareVersionNumber: 0002
exhaustRegulationOrTypeApprovalNumber: B00007
systemNameOrEngineType: Y20DTH D3
RepairShopCodeOrTesterSerialNumber: Not programmed
ProgrammingDate: FFFFFFFF
Identifier: 0540
VehicleManufacturerSpecific: 0281010050
Total number of fault codes: 3
P1345 - Critical system malfunction 1 (refer to checking procedure: trouble code description)
(0A) - Not present
P0110 - Intake Air Temperature (IAT) Signal Voltage High
(01) - Present
P1635 - Glow Device Circuit General Error
(0A) - Not present
Keyword #1: 6B
Keyword #2: 8F
Identifier: 0540
(0A) - Not present
(01) - Present
(0A) - Not present
- 38 mesaje
- din 23 Mai 2014
- Zafira 2000
OP-COM 100219a Program de diagnoz? bazat pe PC
OP-COM-Fereastra de comunicare -KW2000> 2000|Astra-G|Motor|Y 20 DTH
Keyword #1: 6B
Keyword #2: 8F
Setare timpi de parametri normali
Num?r ?asiu VIN: W0L0TGF35Y8132911
NumeSistemSauTipMotor: Y20DTH D3
CodAtelierSauNumarTester: Nu este programat
Data de programare: FFFFFFFF
Identificare: 0540
Specific marcii: 0281010050
Num?rul codurilor: 10
P0725 - Semnal de intrare senzor tura?ie motor - lips?
(0D) - Nu este prezent
P0115 - Senzor temperatur? motor - semnal prea mare
(01) - Nu este prezent
P0105 - Senzor presiune turbo - semnal prea mic
(02) - Nu este prezent
P1651 - CAN: prime?te defecte
(0B) - Nu este prezent
P1220 - Defec?iune critic? 1 de sistem(vezi descrierea codului ?n tabela de defecte)
(0A) - Nu este prezent
P1345 - Defec?iune critic? 1 de sistem(vezi descrierea codului ?n tabela de defecte)
P0100 - Circuit senzor mas? aer - semnal prea mare
P1335 - Pomp? de injec?ie - lips? semnal de tura?ie motor de la ECU
P0110 - Semnal temperatur? aer admisie(IAT) - tensiune mare
(01) - Prezent
P1635 - Circuit pre?nc?lzire - defect general
Keyword #1: 6B
Keyword #2: 8F
Identificare: 0540
(01) - Prezent
- 38 mesaje
- din 23 Mai 2014
- Zafira 2000
- iulian1971
- 7,066 mesaje
- din 21 Dec 2006
- Astra 2008 Z19DTH
- Ilfov
iulian1971
- Mesaje scrise: 7,066
- Masina: Astra 2008 Z19DTH
