  3. Motoare benzină
  • zsoltiboss
  • Masina: Astra 2001 z20let
  • Cont inregistrat: 12 Feb 2013
daca aiti intlanit errorile de mai sus ajutor multumesc
  • luciraica
  • Mesaje scrise: 1,999
  • Masina: Astra 2006 Z16XEP
uite ce am gasit:
Subject: Column Integration Module (CIM) - Engine does not start, DTC P1614 / P1616 and/or B3055 set
Models: Engines: Option:
Astra-H 2004...2007,Zafira-B 2005...2007 All,All
Complaint: Engine does not start, DTC P1614 / P1616 and/or B3055 set.
Cause: Software weakness of the Column Integration Module (CIM).
Production: As of MY 2008 improved CIMs with new software have been introduced in production.
Remedy:
In case of customer complaint reprogram the CIM as described in TIS 2000
with TIS 2000-DVD, version 83 or higher.
Important: For a successful programming follow the instructions in
TIS 2000 and set up the CIM for programming by Tech-2 before reprogram.
Procedure for CIM SPS programming:
--> After selection of MY and Vehicle "Enter"
--> Body "Enter"
--> CIM "Enter"
--> Additional Funktions "Enter"
--> SPS programming set up "Enter" - CIM SPS programming will be performed
--> Exit
Afterwards carry out the CIM SPS programming (Old software version:
M: --.57; New software version: M: --.62).
Important: During the CIM set up ignore all "switch off ignition" messages,
otherwise the programming of the CIM won´t be successful.
Note: Vehicles with PEPS are not affected and therefore it is not possible
to program a CIM with PEPS.
FunctionalGroup: N - Electrical Equipment
Complaint Group: 04 - Electrical failures,21 -Poor Startability
Trouble Code: P1614,P1616,B3055
ptr. eroarea 2:P0136 HO2S Circuit Bank 1 Sensor 2
iar eroarea 3 e incompleta
  3. Motoare benzină
