- dimucosmin
- 19 mesaje
- din 01 Apr 2010
- Astra 2004 z16XEP
- Gorj
dimucosmin
- Mesaje scrise: 19
- Masina: Astra 2004 z16XEP
- Cont inregistrat: 01 Apr 2010
Salut. Am un astra h, benzina, Z16XEP SI AM PROBLEME CU CLIMA. NU IMI PORNESTE COMPRESORUL. AM MASINA IN SERVICE, SI MECENICUL S-A APUCAT SA DESFACA TOATE MUFELE CE PLEACA DE LA COMPRESOR SI PANA LA TABLOUL DE SUB CAPOTA. IMI SPUNE CA IMI AJUNGE IN PERMANENTA + LA COMPRESOR SI NU E NORMAL, CA CICA TREBUIA SA AJUNGA -. VERIFICA DECI TOATE MUFELELE, SI TOATE FIRELE SI AJUNSE LA CONCLUZIA CA PROBLEMA AR FI DE LA TABLOUL DIN MASINA (UNDE ESTE COMUTATORUL DE LA CLIMA SI TOATE BUTOANELE). ACUM IMI DESFACU AICI IN FATA TOT SI IMI SPUSE CA ESTE O PLACA ELECTRONICA MARE, CE ARE PE EA TOATE COMENZILE SI ASTA ESTE UMEZITA, SI A INCEPUT SA SE CORODEZE PRIN UNELE LOCURI. CARE SA FIE CAUZA CONDENSULUI? ACUM ASTEPT SA VAD CE IMI SPUNE MECANICUL CA A REZOLVAT CU ACEA PLACA ELECTRONICA DE LA CLIMA, SI DACA IMI REZOLVA CLIMA SAU NU.... SPER SA NU AM MARI PROBLEME...
CAND STAU IN MASINA, SI NU AM MOTORUL PORNIT, SE AUDE PRIN BORD UN FASAIT CATEVA SECUNDE. ACEST ZGOMOT SE REPETA IN PERMANENTA LA UN INTERVAL DE TIMP. DIN CE CAUZA SE AUDE?
CU CEVA TIMP IN URMA (CAM 2 LUNI), IMI PORNEA SINGUR CASETOFONUL, IL GASEAM DIMINEATA PORNIT, CAM 3-4 ZILE A TINUT ASTA, INSA APOI NU A MAI FACUT.
MA PUTETI AJUTA SI PE MINE CU ACESTE PROBLEME, ATI MAI AUZIT DE ASA CEVA.... ORICUM INCA NU SUNT SIGUR CA ASTA AR CAUZA PENTRU CARE NU IMI MERGE CLIMA.
ASTEA SUNT PROBLEMELE CU MASINA MEA.VA MULTUMESC
- stx
- 256 mesaje
- din 10 Apr 2010
- Astra 2005 Z17DTH
stx
- Mesaje scrise: 256
- Masina: Astra 2005 Z17DTH
- Cont inregistrat: 10 Apr 2010
- dimucosmin
- 19 mesaje
- din 01 Apr 2010
- Astra 2004 z16XEP
- Gorj
dimucosmin
- Mesaje scrise: 19
da, din cauza ambreiajului nu imi mergea compresorul si mi*a zis mecanicul ca acum nu imi mai merge nici tabloul de comanda clima ca eu am tot incercat sa pornesc clima si de asta am distrus si comanda. acum mi-a zis ca o sa imi programeze masina sa imi mearga cu compresor fara ambreiaj si asa nu o sa fiu nevoit sa schimb si tabloul de comanda ci numai compresorul. maine o sa ma duk sa imi iau masina cu un compresor second montat.,... sper sa imi mearga clima acum
- dimucosmin
- 19 mesaje
- din 01 Apr 2010
- Astra 2004 z16XEP
- Gorj
dimucosmin
- Mesaje scrise: 19
adept2ska
- Mesaje scrise: 93
- Masina: Astra 2004 Z14XEP
- Cont inregistrat: 13 Mar 2009
Buna,
Recent mi-am achizitioat un Z14XEP cu clima automata. Toate bune si frumoase pana intr-o zi cand am pornit clima si am constatat ca nu-mi baga aer rece, doar ventilatie. Dupa 2-3 zile am pornit din nou clima si a functionat. Dupa ce am mai folosit-o de inca 2 ori si a mers ok, acum iarasi nu mai am clima, decat ventilatie. Nu se mai simte nici senzatia de "scadere a puterii motorului" si nici zgomotul specific climei, doar cel al ventilatiei normale. De 2 ori aceasta problema a coincis cu faptul ca potentiometrul de volum al muzicii ramane blocat la acelas volum indiferent cat de tare as da muzica.
Care ar putea fi cauza? multumesc
adept2ska
- Mesaje scrise: 93
- jE
- 8,418 mesaje
- din 04 Jun 2006
- Astra 2005 Z18XE
jE
- Mesaje scrise: 8,418
- Masina: Astra 2005 Z18XE
- Status: Online
adept2ska
- Mesaje scrise: 93
Rocco03- Mesaje scrise: 41
- Masina: Astra 2006 Z17DTH
- Cont inregistrat: 19 Jul 2009
Salutare! Am urmatoarea problema: am un Astra H cu clima automata (nu climatronic...nu stiu foarte bine diferenta), care nu functioneaza; am verificat instalatia si freonul e ok; electricianul a tras un fir de la baterie la borna compresorului si clima a inceput sa mearga! Am mers la diagnoza si apare ca senzorul de vacuum (sau de la vaporizator) indica -40 grade si de aseea nu ar porni! S-au desfacut multe de sub bord in cautarea senzorului si fizic nu a fost de gasit...stiti unde e pozitionat si care e cauza? (se poate shunta senzorul?) Multumesc!
- dimucosmin
- 19 mesaje
- din 01 Apr 2010
- Astra 2004 z16XEP
- Gorj
dimucosmin
- Mesaje scrise: 19
adept2ska a scris:Buna,
Aceasta problema cu clima am avut-o si eu, dupa ce am scos masina din service. imi mergea clima cand vroia ea, si am miscat de mufa ce intra in compresor. am avut surpriza sa vad ca in momentul in care miscam , pornea compresorul si ventilatorul, apoi se oprea. am scos mufa, am strans putin papucii din interiorul ei, si de atunci imi merge ok.
Problema cu sonorul la muzica o am si eu uneori si aceasta problema coincide si cu faptul ca nu mai am claxon. chiar saptamana trecuta mi s-a intamplat. am observat ca daca merg cu farurile aprinse nu imi functioneaza claxonul, iar daca le sting imi merge. Asta nu tot timpul mi se intampla, desigur. daca afli ceva in legatura cu potentiometrul de la muzica sa ma anunti si pe mine.
- dimucosmin
- 19 mesaje
- din 01 Apr 2010
- Astra 2004 z16XEP
- Gorj
dimucosmin
- Mesaje scrise: 19
Rocco03 a scris:Salutare! Am urmatoarea problema: am un Astra H cu clima automata (nu climatronic...nu stiu foarte bine diferenta), care nu functioneaza; am verificat instalatia si freonul e ok; electricianul a tras un fir de la baterie la borna compresorului si clima a inceput sa mearga! Am mers la diagnoza si apare ca senzorul de vacuum (sau de la vaporizator) indica -40 grade si de aseea nu ar porni! S-au desfacut multe de sub bord in cautarea senzorului si fizic nu a fost de gasit...stiti unde e pozitionat si care e cauza? (se poate shunta senzorul?) Multumesc!
La problema ta nu stiu ce sa zic, dar oricum sunt sigur ca nu o sa fie ceva complicat si scump, cum a fost la mine compresorul. sigur e senzorul cum iti zice mecanicul, dar eu nu stiu pe unde ar putea fi, sper sa te poata ajuta cineva. Bafta cu solutionarea problemei!
- dimucosmin
- 19 mesaje
- din 01 Apr 2010
- Astra 2004 z16XEP
- Gorj
dimucosmin
- Mesaje scrise: 19
- george_eu25
- 666 mesaje
- din 17 Sep 2010
- Astra 2012 A1.7 DTR
george_eu25
- Mesaje scrise: 666
- Masina: Astra 2012 A1.7 DTR
- Cont inregistrat: 17 Sep 2010
adept2ska
- Mesaje scrise: 93
am facut diagnoza... totul ok (exact in ziua repectiva s-a intamplat sa functioneze clima). Am reincarcat cu freon, apoi ceva teste, etc.
Rezultatul final: in 70% cand vreau clima am clima,iar in celalalte 30.. ventilatie calda...
cat despre cheia de la roata de rezerva, ma abtin sa comentez (sarcasmul meu nu are limita)
raresa
- Mesaje scrise: 5
- Cont inregistrat: 28 Jan 2012
Am si eu , ca si voi, o problema cu clima masinii. Am un Opel Astra H 1,7 CDTI. Acum cateva zile compresorul a scos fum, iar dupa verificare s-a constatat ca bobina era intrerupta. Am inlocuit bobina si a mers 10 minute si apoi a scos iar fum. Am schimbat compresorul, a mers iar bine pentru 10 minute si iarasi a scos fum. Am verificat pe direct si nu se invarte ambreiajul, compresorul primeste curent. Cineva mi-a sugerat sa schimb conducta de clima cu filtru dezhidrator si supapa de destindere. Ce sa fac? Filtrul acela nu se poate curata, ci trebuie schimbat? A mai patit cineva acelasi lucru ca si mine? Orice idee de rezolvare a problemei m-ar ajuta. Va multumesc
- dimucosmin
- 19 mesaje
- din 01 Apr 2010
- Astra 2004 z16XEP
- Gorj
dimucosmin
- Mesaje scrise: 19
- dimucosmin
- 19 mesaje
- din 01 Apr 2010
- Astra 2004 z16XEP
- Gorj
dimucosmin
- Mesaje scrise: 19
adept2ska
- Mesaje scrise: 93
raresa
- Mesaje scrise: 5
karma2005
- Mesaje scrise: 55
- Masina: Astra 2003 Y20DTH
- Cont inregistrat: 19 Mar 2010
Salut!
Am si eu o problema cu clima.De ceva vreme cand o pornesc /opresc se aude un zgomot ciudat asemanator cu cel de cd invartit repede , problema este ca nu imi mai baga deloc aer rece.Astazi am fost la un service sa-mi bage freon.A bagat rece cateva minute dupa care a inceput sa bage cald din nou .Nu a pierdut freon , iar compresorul functioneaza.
In schimb , conducta in loc sa fie rece, era fierbinte.
A patit vreunul dintre voi asta sa ma poata ajuta cu niste sfaturi?
Mi-ar fi de mare ajutor!
