xuser222
- Mesaje scrise: 11
- Masina: Astra 2002
- Cont inregistrat: 02 Jan 2012
pe bord mi se aprinde un led cu un motor pe el,am fost cu masina la un tester si am schimbat bobina, egr, mai am sa ii desfac motorul si sa vad ce este in cilindrul NR 1, testerul acolo indica ca ar fi o problema, masina merge in 3 pana la o anumita turatie apoi merge normal. Cand astept la semafor incepe sa mearga in 3 daca opresc motorul si il pornesc iar merge normal... nustiu ce sa ii mai fac.
Daca stie cineva cum as putea sa rezolv problema , va multumesc anticipat.
- popa petru
- 50 mesaje
- din 24 Feb 2011
- Vectra 1996 x 16xel
- Tulcea
popa petru
- Mesaje scrise: 50
- Masina: Vectra 1996 x 16xel
- Cont inregistrat: 24 Feb 2011
- popa petru
- 50 mesaje
- din 24 Feb 2011
- Tulcea
popa petru
- Mesaje scrise: 50
xuser222
- Mesaje scrise: 11
- dancuciureanu
- Moderator
- 16,454 mesaje
- din 26 Jun 2006
- Agila 2001 Z10XE + Z12XE
dancuciureanu
- Mesaje scrise: 16,454
xuser222
- Mesaje scrise: 11
- cangri
- 5,294 mesaje
- din 24 Sep 2010
cangri
- Mesaje scrise: 5,294
Description
Cylinder 1, 2, 3 & 4 Misfire Detected Conditions
Cause
DTC P0105, P0107, P0112, P0113, P0117, P0118, P0122, P0123, P0125, P0131, P0132, P0133, P0134, P0171, P0172, P0325, P0335, P0341, P0342, P0502, P0503, P0506, P0507, P0601, P0740, P0742, P1133 and P1621 not set, engine runtime over 5 seconds, engine speed from 469-6400 rpm, system voltage from 9-17v, ECT input from 20-254°F, throttle position has not increased more than 8% in one second or throttle position has not decreased more than 1.5% in one second, then the PCM determined that the Misfire total for Cylinder 1, 2, 3 or 4 was more than 8 counts.
- luciraica
- 2,001 mesaje
- din 29 Oct 2011
luciraica
- Mesaje scrise: 2,001
xuser222
- Mesaje scrise: 11
- CORBU
- 1,669 mesaje
- din 01 Dec 2006
- Zafira Tourer 2015 b16dth
CORBU
- Mesaje scrise: 1,669
- Masina: Zafira Tourer 2015 b16dth
- Cont inregistrat: 01 Dec 2006
xuser222
- Mesaje scrise: 11
- alexx_gan
- 806 mesaje
- din 18 Feb 2010
- Astra 2013 A14NET
alexx_gan
- Mesaje scrise: 806
- Masina: Astra 2013 A14NET
- Cont inregistrat: 18 Feb 2010
- CORBU
- 1,669 mesaje
- din 01 Dec 2006
CORBU
xuser222
- Mesaje scrise: 11
- CORBU
- 1,669 mesaje
- din 01 Dec 2006
CORBU
- Doru Lucian
- 330 mesaje
- din 29 Dec 2011
- Astra 2001 z16xe
Doru Lucian
- Mesaje scrise: 330
- Masina: Astra 2001 z16xe
- Cont inregistrat: 29 Dec 2011
Ultima modificare făcută de Doru Lucian la Joi 12 Jan, 2012 3:54 pm
- Doru Lucian
- 330 mesaje
- din 29 Dec 2011
- Astra 2001 z16xe
Doru Lucian
- alexx_gan
- 806 mesaje
- din 18 Feb 2010
- Astra 2013 A14NET
alexx_gan
Daca e de le ECU eu zic sa nu te bagi du-te la un specialist eu m-am "bagat" si a trebuit sa duc masina pe platforma la Iasi la un mester de ECU-uri.
astefy
- Mesaje scrise: 3
- Masina: Vectra 1996 X16XEL
- Cont inregistrat: 14 Oct 2009
Iata ce am facut pana acum:
1-verificat aprinderea,schimbat bujii,verificat fise,schimbat filtru aer,filtru benzina,suflat returul,curatat EGR,pus pe tester si cu motorul rece si cu motorul cald (totul functioneaza normal nici o eroare) la bord nu se aprinde nici un martor pe calc nu are nici o eroare stocata.-Si totusi nu merge bine!
Daca poate cineva sa-mi spuna ce-ar putea avea ca nu mai stiu ce sa-i fac.Masina are 168 000km reali iar distributia a fost schimbata la 163 000.
- luciraica
- 2,001 mesaje
- din 29 Oct 2011
luciraica
