ferry79
- Mesaje scrise: 42
- Masina: Astra 2009 Z18XER
- Cont inregistrat: 20 Apr 2011
Salutare,
Vreau sa stiu daca masina a avut din fabrica spalatoare de faruri. Eu sunt al doilea proprietar si din cate am putut sa aflu de la Edwin dotarile masinii sunt:
W0L:General Motors
0:Normal Vehicle
A:Astra Platform
H:2004 Platform Generation
L69:4 Door Saloon (F69)
9:2009
G:Gliwice
006549:SERIAL NUMBER
data fabr. 02.09.2008
1RU = VOPSEA EXTERIOR,VEZI DIAGRAMA CU TIPURI DE VOPSEA DIN INTRODUCEREA LA CATALOG 20S = CULOARE CUSÃTURÃ, ARGINTIU STELAR 2H0 = MOTOR PE BENZINà C18SEL,Z18XER,A18XER 2J1 = CAPAC INTERIOR UªÃ STANDARD 80I = INTERIOR - NEGRU 80X = ORNAMENT INTERIOAR CAROSERIE-NEGRU 80Y = CAPITONAJ PANOU UªÃ, NEGRU A51 = BUZUNAR SCAUN FAÞà A90 = CAPOTà PORTBAGAJ,DEBLOCARE PRIN TELECOMANDà AF8 = COMANDà BLOCARE UªÃ LATERALÃ,PROTECÞIE ANTIFURT AH4 = SCAUN FAÞÃ,ªOFER,REGLARE MANUALà CU 6 ACÞIONÃRI AHA = CU SUPORT LOMBAR REGLABIL AJ7 = PENTRU AIRBAGURI ªOFER, PASAGER ªI LATERAL AQ0 = TETIERÃ,SCAUN DREAPTA SPATE,ÎNVELIT CU VINIL,DOUÃ, EXTERIOR AY9 = TETIERÃ,SPATE,VINIL, CENTRU B70 = CAPAC PLACà PRAG UªÃ B86 = CULOARE MULAJ LATERAL CAROSERIE BKX = CU MULAJ SEMI-LUCIOS ªI CROM MAT BS9 = ETANªARE PRINCIPALÃ, UªI, INFERIOR BSS = MULAJ INTERIOR UªÃ, CROM MAT SEMI-LUCIOS BW4 = CU CHENAR CROMAT BW7 = APLICE ORNAMENTALà EXTERIOARà STÂLP C68 = PENTRU INSTALAÞIE DE CLIMATIZARE ELECTRONICà C95 = LAMPÃ, ANS., PLAFON, CU LAMPà DE CITIT DUALà CE1 = ªTERGÃTOR,FAÞÃ,SISTEM CU IMPULSURI CE4 = SPÃLÃTOR FAR CR7 = PENTRU UNGARIA CR7 D75 = MÂNER, ANS., EXTERIOR DA7 = COTIERà SCAUN FAÞÃ, LH DD8 = PENTRU OGLINDà INTERIOARà HELIOMATICà DDG = OGLINDà ELECTRICÃ, RH-LH DDU = ANSAMBLU OGLINDà DH6 = PARASOLAR CU OGLINDà ILUMINATÃ, RH-LH DP6 = CARCASà DT4 = SCRUMIERà ªI BRICHETà DVA = TABLOU DE BORD, NEGRU, INELE PE NEGRU CU PARTE SUPERIOARà ARGINTIE E4R = PACHET VÂNZARE ECHIPAMENTE - COSMO ECA = CHEIE FX1 = RAPORT FINAL PUNTE 3,94 G62 = 5 FIXARE ªURUB ROATà JL9 = ABS K60 = ALTERNATOR, 100 A KA1 = PENTRU SCAUNE FAÞà ÎNCÃLZITE KCL = CONDUCTà ÎNCÃLZIRE, PASAGER SPATE POZIÞIA 2 LHD = VEHICUL CU VOLANUL PE PARTEA STÂNGà M25 = TRANSMISIE MANUALÃ, 5 VITEZE, TIP F17 MM3 = UTILIAZAT CU CUTIE DE VITEZE MANUALà N34 = ANS. VOLAN, TREI SPIÞE, PIELE NC0 = ECHIPAMENT, UNIUNEA EUROPEANà NS2 = PENTRU SERVODIRECÞIE CU EFORT VARIABIL NT4 = EMISII, EEC 05 OHB PXF = CAPITONAJ, ALPHA/VINIL QGF = ANVELOPE, 205/55 R 16-91H QQ0 = JANTà 16X6,5, ALUMINIU, 7 SPIÞE DUBLE QQ5 = PENTRU ROATà DE REZERVà DE DIMENSIUNE NORMALà T2Q = FARURI, PORNIRE-OPRIRE AUTOMATà T6K = PANOU CAPITONAJ, INTERIOR, VINIL T96 = LAMPà DE CEAÞà FAÞà T9S = LAMPÃ, ANS., INTERIOR, UªÃ FAÞà TN6 = BATERIE, 55 AH TPV = GRILà RADIATOR, NEGRU, CU BARà CROMATà TR0 = LAMPà INTERIOARÃ, PLAFON, SPATE, CURTOAZIE ªI CITIRE DUALà TRP = CADRU,RADIO TSQ TTX = PENTRU CONECTOR AUXILIAR LA ECHIPAMENTUL RADIO U07 = CLAXON, TIP GOARNà U3F U55 U66 = DIFUZOR,7 U68 = COMPUTER DE INFORMAÞII UA6 = SISTEM DE AVERTIZARE ANTIFURT UAG = INFORMAÞII GRAFICE - MONOCROM UCH = RADIO AM/FM STEREO,CÃUTARE, CD, ETR, ESTOMPARE, MP3 UJ3 VG9 = CEARà DE PROTECÞIE VK8 = SUPORT, OCHELARI VVH = CENTRU TABLOU DE BORD, CÃRBUNE PIANO W1Y = PENTRU FUNCÞIONAREA RADIO A VOLANULUI W4Y W5T = INSIGNà MOTOR, ªTEARSà W7Z = ECHIPAMENT, IARNà WBE = ECHIPAMENT APARAT RECEPTOR, RADIO XA3 = OPEL XB2 = PENTRU UNGARIA XJ9 = PENTRU UNGARIA XL4 = UTILIZAT CU KIT PROTECÞIE ªASIU, COMPARTIMENT MOTOR Y67 = CERUT CÂND ESTE MONTAT AFIªAJUL DE AVERTIZARE REVIZIE Z1F = SENZOR, SISTEM DE REÞINERE, LH Z1O = PENTRU UNGARIA
Ce am boltit va rog sa-mi spuneti daca ar trebui sa am spalatori faruri, (sau ce inseamna pentru ungaria?)
Faza este ca dupa o spalare a masinii unul din acele plastice mi-a zburat si am observat pe acolo un fel de instalatie?
Cumva trebuie adaugate doar duzele? Daca doriti o sa pun o poza si fara acel capacel de protectie.
Daca nu am spalator de far atunci se gaseste sa cumpar acel capac de mascare si eventual de unde anume?
W0L:General Motors
0:Normal Vehicle
A:Astra Platform
9:2009
G:Gliwice
- alexx1402
- 1,752 mesaje
- din 16 Aug 2010
- Astra 2017 B16DTH
alexx1402
- Mesaje scrise: 1,752
- Masina: Astra 2017 B16DTH
- Cont inregistrat: 16 Aug 2010
Din poze si din VIN, pare ca are.
Ca sa vezi daca e functional, pornesti farurile si actionezi 4-5 secunde sistemul de spalare a parbrizului si automat ar trebui sa porneasca si cel pentru faruri.
"pentru Ungaria" - e tara pentru care a fost produsa masina, probabil de acolo a fost cumparata de primul proprietar din Ro.
ferry79
- Mesaje scrise: 42
alexx1402 a scris:Din poze si din VIN, pare ca are.
Masina a fost inmatriculata in Romania de noua ... mie sa nu fi fost busita, schimbata bara si improvizate acele plastice de acoperire. Ideea e ca pe langa alea nu are loc sa iasa apa, nu are duze daca te uiti atent la ele. Doara daca este un sistem de iesire din locas si stropire! O sa ma duc sa fac o poza sa se vada ce mecanism este inauntru.
- alexx1402
- 1,752 mesaje
- din 16 Aug 2010
- Astra 2017 B16DTH
alexx1402
ferry79
- Mesaje scrise: 42
alexx1402 a scris:Nu e mai simplu sa incerci cum ti-am spus?
Ce tare, am facut si tot nimic, am tras de maneta de sters parvrizul si am tinut apasat mai mult de 5 sec in timpul asta tot stropeam pe parbriz. Pare si improvizatie conform cu poza locul este taiat la mana nu cred ca asa vine din fabrica.
Sper ca am facut corect daca nu ... pls help
Ultima modificare făcută de ferry79 la Vin 12 Aug, 2011 10:23 am
- dew
- 1,077 mesaje
- din 07 Jun 2008
- Astra 2002 Y22DTR
- Dolj
dew
- Mesaje scrise: 1,077
- Masina: Astra 2002 Y22DTR
- Cont inregistrat: 07 Jun 2008
- Blebeanu Lorin
- 1,077 mesaje
- din 04 Aug 2010
- Astra 2005 Z17DTH
Blebeanu Lorin
- Masina: Astra 2005 Z17DTH
- Cont inregistrat: 04 Aug 2010
- cangri
- 5,412 mesaje
- din 24 Sep 2010
cangri
- Mesaje scrise: 5,412
- Blebeanu Lorin
- 1,077 mesaje
- din 04 Aug 2010
- Astra 2005 Z17DTH
Blebeanu Lorin
- alexx1402
- 1,752 mesaje
- din 16 Aug 2010
- Astra 2017 B16DTH
alexx1402
ferry79
- Mesaje scrise: 42
Super tareee.. eu am observat ca am farurule mereu relativ curate dupa drum lung dar.... nu mi-am imaginat ca ies alea din locas,(am facut si un filmulet ca sa ma simt bine ) in sfarsit stiu ca sunt functionale.
Acum intervine problema estetica, gasesc sa cumpar la culoare capace de protectie sau cum se numesc?
- Blebeanu Lorin
- 1,077 mesaje
- din 04 Aug 2010
- Astra 2005 Z17DTH
Blebeanu Lorin
@alexx-Nu cumva instalatia de spalatoare e montata ulterior? Atat cangri cat si eu stim ca doar masinile cu Xenon de fabrica au aceasta optiune la dotarile initiale. Mai poti verifica daca ai spalatoare verificand capacitatea vasului de stropgel, ceva mai mult de 2 l. la masinile fara spalatoare si ceva mai mult de 4 l. la cele care au. Nu cumva ai farurile schimbate?
Ultima modificare făcută de Blebeanu Lorin la Vin 12 Aug, 2011 12:44 pm
- lucio85
- 4,964 mesaje
- din 14 Feb 2010
- Astra 2010 a17dtr
- Gorj
lucio85
- Mesaje scrise: 4,964
- Masina: Astra 2010 a17dtr
@ferry79
din cate stiu eu si sper sa nu gresesc la astra h, spalatorul de faruri este intergrat in bara a se vedea clipul de mai sus si poza, se pare ca in cazul tau masina a fost lovita si acele spalatoare de faruri au fost montate pe o bara normala, verifica sa ai pompa pe bidonas, furtunele si nu in ultimul rand sigurantele din tablou
ferry79
- Mesaje scrise: 42
Blebeanu Lorin a scris:@alexx-Nu cumva instalatia de spalatoare e montata ulterior? Atat cangri cat si eu stim ca doar masinile cu Xenon de fabrica au aceasta optiune la dotarile initiale.
Se poate deoarece conform cu poza atasat mai sus se vede cum este bara decupata. Cred ca a fost adaugata instalatia de proprietarul de dinainte! Oricum bine ca functioneaza. Ce am observat e ca are o temporizare, presupun, deoarece dupa ce se sterg o data nici dupa aprox 5 minute nu am reusit sa-l fac sa functioneze. Trebuie oprit motorul si apoi testat din nou.
- lucio85
- 4,964 mesaje
- din 14 Feb 2010
- Astra 2010 a17dtr
- Gorj
lucio85
- Blebeanu Lorin
- 1,077 mesaje
- din 04 Aug 2010
- Astra 2005 Z17DTH
Blebeanu Lorin
- alexx1402
- 1,752 mesaje
- din 16 Aug 2010
- Astra 2017 B16DTH
alexx1402
Blebeanu Lorin a scris:@alexx-Nu cumva instalatia de spalatoare e montata ulterior? Atat cangri cat si eu stim ca doar masinile cu Xenon de fabrica au aceasta optiune la dotarile initiale. Mai poti verifica daca ai spalatoare verificand capacitatea vasului de stropgel, ceva mai mult de 2 l. la masinile fara spalatoare si ceva mai mult de 4 l. la cele care au. Nu cumva ai farurile schimbate?
E originala (reiese si din decodare VIN)
La mine a venit spalatorul pentru faruri a venit la pachet (winter pack) cu scaune incalzite si parking heater.
Ultima modificare făcută de alexx1402 la Vin 12 Aug, 2011 12:51 pm
ferry79
- Mesaje scrise: 42
Blebeanu Lorin a scris:Instalatia are si o temporizare din cate stiu, iar intervalul de pauza intre stropiri e mare.
Intrebarea e: am senzor de ploaie, daca farurile sunt aprinse se sterg si acestea cand lucreaza stergatoarele?
La intrebarea daca se gasesc acele capacele ma poate ajuta cineva?
Masina este Astra H 2009 1.8 140cp
ferry79
- Mesaje scrise: 42
- Blebeanu Lorin
- 1,077 mesaje
- din 04 Aug 2010
- Astra 2005 Z17DTH
Blebeanu Lorin
